Re: out with old headers
[Re: Clanton]
#1385226
03/08/13 08:26 PM
03/08/13 08:26 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
frt view,I left room to adjust the angle some on all pipes.
[Re: 1Fast340]
#1385227
03/08/13 10:40 PM
03/08/13 10:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am thinking of vee banding the #7 header tube to make the headers removable to get past the brake MC and equal length.your thaughts?
equal lengths are not allimportant on a blown engine but if you are anyway taking the time,you might aswell go for it! Vband joints are good when you need a split somewhere however fairly expensive,you could make the joint with flatflanges aswell or a sliptube or you could even if room and angles alow for it use flanges on a sliptube with a regual flatgasket the last version might be overkill but make for a superb seal at a much lower price than the vbands.
looks good this far
Correct... lengths dont matter on a blower motor... doesnt do anything... just get the exhaust out... if you didnt need to cap it or connect exhaust to the collector, you wouldnt need the collectors
[Re: MR_P_BODY]
#1385228
03/09/13 10:48 AM
03/09/13 10:48 AM
Clanton
northern,Ohio,USA
Thank for your input,Have you ever use the Vee band on a single tube? also I would ask if you get the time, how much argon/co2 is used when back gas prosess is done when welding? How much flow should there be inside the tube? Do you have a pic of a back gas connection in use? THX
[Re: Clanton]
#1385230
03/12/13 08:47 PM
03/12/13 08:47 PM
MR_P_BODY
Yes I have used a V-band before on a pipe.. I liked it better than a slip joint... on the back flowing I use about 50% more than for the welding cup... on my flow meter I weld at 20-22 back flow is 30... just use a rubber cork at one end and another rubber cork at the other but I have a 1/8" pipe nipple stuck through it... clamp the gas hose to it... make sure you shut the gas off when you finish the weld... when I get to about 1/4" of weld left to do at each joint I shut the gas off(there is plenty in there) and it wont blow a hole
[Re: Clanton]
#1385232
03/12/13 09:30 PM
03/12/13 09:30 PM
MR_P_BODY
Thanks,will the internal psi blow the weld out?
It can.. thats why I turn it off or the last 1/4"
