Page 3 of 7 1 2 3 4 5 6 7
Re: out with old headers [Re: Clanton] #1385222
02/28/13 09:30 PM
02/28/13 09:30 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
It sure isn't a walk in the park, is it? Sure seems like no matter what you do, there are either compromises in performance, spark plug clearance, etc.. I am fortunate to have a good friend that has both the skills and patience (thanks Sean). Keep up the good work and keep the pics coming! Here is some inspiration...
Randy
Re: out with old headers [Re: Dartin] #1385223
02/28/13 10:25 PM
02/28/13 10:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks,your #7 is what mine will do but mine goes between the 3/5 loop[I hope!]
Re: out with old headers [Re: Clanton] #1385224
03/06/13 10:00 PM
03/06/13 10:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I started tacking pipe togather.I cut the flange to help remove them.
exit
Re: out with old headers [Re: Clanton] #1385225
03/08/13 08:25 PM
03/08/13 08:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I started on the pass side even though I have to do 5,7 pipe yet.
Re: out with old headers [Re: Clanton] #1385226
03/08/13 08:26 PM
03/08/13 08:26 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
frt view,I left room to adjust the angle some on all pipes.
Re: out with old headers [Re: 1Fast340] #1385227
03/08/13 10:40 PM
03/08/13 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I am thinking of vee banding the #7 header tube to make the headers removable to get past the brake MC and equal length.your thaughts?
equal lengths are not allimportant on a blown engine but if you are anyway taking the time,you might aswell go for it!
Vband joints are good when you need a split somewhere however fairly expensive,you could make the joint with flatflanges aswell or a sliptube or you could even if room and angles alow for it use flanges on a sliptube with a regual flatgasket the last version might be overkill but make for a superb seal at a much lower price than the vbands.
looks good this far
Correct... lengths dont matter on a blower motor...
doesnt do anything... just get the exhaust out...
if you didnt need to cap it or connect exhaust to
the collector, you wouldnt need the collectors
Re: out with old headers [Re: MR_P_BODY] #1385228
03/09/13 10:48 AM
03/09/13 10:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank for your input,Have you ever use the Vee band on a single tube?
also I would ask if you get the time,
how much argon/co2 is used when back gas prosess is done when welding?
How much flow should there be inside the tube?
Do you have a pic of a back gas connection in use?
THX
Re: out with old headers [Re: Clanton] #1385229
03/12/13 08:24 PM
03/12/13 08:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I know you are tired of me posting pics!I am having SOO much fun I decided to get another set of flanges to make some zoomies or at least all unequal length tubes so I wont bvee near the master cylinder.
Re: out with old headers [Re: Clanton] #1385230
03/12/13 08:47 PM
03/12/13 08:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
THX
Yes I have used a V-band before on a pipe.. I liked
it better than a slip joint... on the back flowing
I use about 50% more than for the welding cup...
on my flow meter I weld at 20-22 back flow is 30...
just use a rubber cork at one end and another rubber
cork at the other but I have a 1/8" pipe nipple stuck
through it... clamp the gas hose to it... make sure
you shut the gas off when you finish the weld...
when I get to about 1/4" of weld left to do at each
joint I shut the gas off(there is plenty in there)
and it wont blow a hole
Re: out with old headers [Re: MR_P_BODY] #1385231
03/12/13 09:06 PM
03/12/13 09:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks,will the internal psi blow the weld out?
Re: out with old headers [Re: Clanton] #1385232
03/12/13 09:30 PM
03/12/13 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It can.. thats why I turn it off or the last 1/4"
Re: out with old headers [Re: MR_P_BODY] #1385233
03/12/13 09:39 PM
03/12/13 09:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
You have been very helpfull!THX!I don't have any gauges to adjust the flow but will put a valve in a tee to go to the pipe.I can not adjust the #7/8 pipe length with the room I have but I had fun trying but I will finish the build and then do the zoomies.
Re: out with old headers [Re: Clanton] #1385234
03/12/13 11:52 PM
03/12/13 11:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Use very little flow of your argon... it doesnt take much
(not pressure)
Re: out with old headers welding new,pics [Re: Clanton] #1385235
03/13/13 12:35 AM
03/13/13 12:35 AM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
i back perged my headers when i built them. the welds look the same inside as they do on the out side. wish i could have done all mine equal length but i had alot of stuff to go around so geting the pipes from point a to b was more importaint
Re: out with old headers welding new,pics [Re: 1974PW] #1385236
03/13/13 09:17 AM
03/13/13 09:17 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The driver side is the problem area with the MC in the way and I was not going to move it.
Mr P body thx I figured just to get some flow in there but I was limited on tools.[flow gauges]
PS:1974pw I see you retained the round tube form on the header flange so did you make the flanges?if not what is the part #thx.
Re: out with old headers welding new,pics [Re: Clanton] #1385237
03/13/13 09:33 AM
03/13/13 09:33 AM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
i had a good friend make me those. he has a cnc in his shop and made it match my head and go to the round tube all with in the thinkness of the flange
Re: out with old headers welding new,pics [Re: 1974PW] #1385238
03/13/13 10:55 AM
03/13/13 10:55 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Cool that you were able to do that,there are many ways to do things but few have the resources.
This is going to be interesting trying to make my 1st collectors.
This is just a test weld mockup.
Re: out with old headers welding new,pics [Re: Clanton] #1385239
03/17/13 06:35 PM
03/17/13 06:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made some slip tubes with a pipe expander in a press.
Re: out with old headers welding new,pics [Re: Clanton] #1385240
03/19/13 02:54 PM
03/19/13 02:54 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I've heard it's best to rout 'em like this.
Re: out with old headers welding new,pics [Re: Bill MeLater] #1385241
03/19/13 03:06 PM
03/19/13 03:06 PM
Wisconsin USA
Wisconsin USA
Ooops...
