Proportioning Valve #1384341
02/10/13 01:24 AM
02/10/13 01:24 AM
South Dakota
jsorensen Offline OP
South Dakota
Does anyone know of someone that rebuilds / restores proportioning valves?
Re: Proportioning Valve [Re: jsorensen] #1384342
02/10/13 02:02 AM
02/10/13 02:02 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
inline tubes sells rstored or brand new ones. Here is the link.
http://www.inlinetube.com/
1969 Dodge Dart Swinger
Re: Proportioning Valve [Re: MikeyT] #1384343
02/10/13 03:48 AM
02/10/13 03:48 AM
The two In Line Tube hold off / proportioning valves both failed on me a short time after I installed in on my charger. The replacement they sent me was defective right out of the box! They said to send it back and they would check it out which then said there was nothing wrong with it and sent it back only to still have the same problem with it. I located an original one and have had zero problems since!
Re: Proportioning Valve [Re: ] #1384344
02/10/13 10:46 AM
02/10/13 10:46 AM
california
Mr D21 Offline
Mr D21  Offline
california
Jules rebuilt mine....
Re: Proportioning Valve [Re: Mr D21] #1384345
02/10/13 01:20 PM
02/10/13 01:20 PM
South Dakota
South Dakota
Inline tube told me they no longer sell the Challenger valves and they are trying to find a new supplier due to problems. So I will check with Jules.
Re: Proportioning Valve [Re: jsorensen] #1384346
02/10/13 03:53 PM
02/10/13 03:53 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
A local member sells kits with seals to re=build yours or get the new ones from Fine Lines as they have the most correct looking ones.
Re: Proportioning Valve [Re: THESHAKERPROJECT] #1384347
02/11/13 08:32 AM
02/11/13 08:32 AM
MA
steve70 Offline
steve70  Offline
MA
Try here https://www.musclecarresearch.com/1970-76-mopar-combo-valve-autopsy They make an inexpensive rebuild kit.
1970 Challenger T/A 4 speed
