I screwed up and need help with fan/blower switch #1383270
02/07/13 09:01 PM
02/07/13 09:01 PM
Toronto, Ont, Canada
boydsdodge Offline OP
I was rebuilding my instrument cluster on my 67 Coronet Wagon.
Not really rebuilding but repairing and replacing what was need, when I found the heater blower switch and connector was completely toasted.
I had taken pictures of everything as I went along so I would know where it all went after, but I screwed up on the heater blower connector and took out the three wires (light green dark green and tan) from the melted connector.
When I found a new connector I found that I had not taken a clear enough angle of the three wires as they are installed in the connector to the switch.
Do any of you guys have access to 67 blower switch wiring?
I have the service manual diagram but it does not show what wires go where on the switch.
anything would be great
thanks
Re: I screwed up and need help with fan/blower switch [Re: boydsdodge] #1383271
02/07/13 09:12 PM
02/07/13 09:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Don't know if it helps, this is a 68 fury,
I have mechanical Aptitude.
I can screw up anything.
Re: I screwed up and need help with fan/blower switch [Re: boydsdodge] #1383272
02/07/13 10:15 PM
02/07/13 10:15 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Might have to go old school and check continuity vs. switch position and compare to where wires lead off to, to determine which wire goes on what plug location, if previous poster's pic doesn't help.
Re: I screwed up and need help with fan/blower switch [Re: bboogieart] #1383273
02/07/13 11:04 PM
02/07/13 11:04 PM
Perfect picture, but not what I have on my switch.
In my 67 wiring diagram it shows your switch wiring.
But in my 67 I have only three wires to the switch, I have a light green, a dark green and a tan wire. No black.
But what you sent is just what I need, a great picture but of a three wire connector.
Thanks.
