I was rebuilding my instrument cluster on my 67 Coronet Wagon.
Not really rebuilding but repairing and replacing what was need, when I found the heater blower switch and connector was completely toasted.
I had taken pictures of everything as I went along so I would know where it all went after, but I screwed up on the heater blower connector and took out the three wires (light green dark green and tan) from the melted connector.
When I found a new connector I found that I had not taken a clear enough angle of the three wires as they are installed in the connector to the switch.
Do any of you guys have access to 67 blower switch wiring?
I have the service manual diagram but it does not show what wires go where on the switch.
anything would be great
thanks
