Page 3 of 4 1 2 3 4
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HEMIFRED] #1382664
02/07/13 07:07 PM
02/07/13 07:07 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Many while ago, on a GM-car...
When swapping a radiator in your car, outside, in the near freezing winter cold, don't first disconnect the transmission coolinglines, and then decide it's a good idea to run the engine for a while to put some heat in the radiator, so your hands won't go numb from the cold...!
DAMHIK...
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: Just-a-dart] #1382665
02/07/13 07:09 PM
02/07/13 07:09 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Don't leave your trailer keys at home and tow to the track. Had to barrow a grinder from a buddy and remove pad locks from the ramp door to go play.
Done that at a rewards banquet at the end of the season.
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HemiDart68] #1382666
02/07/13 08:19 PM
02/07/13 08:19 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Household one. If you are working under the kitchen sink, and remove the entire drain plumbling, don't use that same sink to wash your hands. makes quite the mess.
I don't feel so much like a idiot now!!! I did that.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: Leon441] #1382667
02/07/13 08:33 PM
02/07/13 08:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Don't leave the reaction shaft support bolts loose when your wife calls you into dinner. I even left Five sticking out and one threaded in flush so I wouldn't forget. Don't ask.
Doug
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: dvw] #1382668
02/07/13 08:53 PM
02/07/13 08:53 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
this is getting real good.
home of the
Sox and Martin Hemi Duster
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HEMIFRED] #1382669
02/07/13 09:12 PM
02/07/13 09:12 PM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
When finishing your new gas tank install make sure the lock ring that seals the fuel sending unit into said tank is tight BEFORE taking it on up to the station to top her off.
Hey... what is that noise like running water?
DAMHIK
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: BB73Challenger] #1382670
02/07/13 09:35 PM
02/07/13 09:35 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
When you get new beadlocks and use a tube make sure the hole in the wheel is the right size and does not cut the valve stem
] "DON'T ASK ME HOW I KNOW"
home of the
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HEMIFRED] #1382671
02/07/13 10:29 PM
02/07/13 10:29 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
If you are driving 2 hrs to the track at 7am and there are no bathrooms for 40 miles.......... do NOT stay up until 2am the night before drinking cheap beers and eating Hot Pockets......
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: 493_DART] #1382672
02/07/13 10:31 PM
02/07/13 10:31 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Before you remove your 727 , make sure you remove ALL 4 of your flexplate bolts......
( " what the F is holding this Fn thing in ???!! " )
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HEMIFRED] #1382673
02/07/13 11:23 PM
02/07/13 11:23 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
one bolt turned in 3 threads does not hold a 22lb steel flywheel on to a crank with a loose register and the engine tilted back.
a 22lb flywheel that falls from 5 1/2 ft. has sufficient force to cut a live air hose cleanly into 2 sections and still have enough energy to take an egg sized bit of concrete out of a concrete floor and still have enough energy to move the ring gear
live air hoses cut into 2 sections seem to have a life of their own
when kicking a flywheel, the flywheel wins
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: bonefish] #1382674
02/08/13 01:53 AM
02/08/13 01:53 AM
Tampa Fl
K
kens avenger Offline
mopar addict
mopar addict
K
Tampa Fl
dont forget to put the PV plugs back in your 1050 dommy then turn on your elect fuel pump and let it run while you answer a phone call and then try to start the car.damhik.
Another fire???? call me sometime AJ..same ###
Remember in here some don't think you should have a Opinion.. sad fact..
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: kens avenger] #1382675
02/08/13 02:24 AM
02/08/13 02:24 AM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Even though you towed it two miles home from the storage compound ALWAYS make sure the trailer ball is latched before you drive your car up the ramps.
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: bill_greenwood] #1382676
02/08/13 09:12 AM
02/08/13 09:12 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
so, im not alone?
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: bonefish] #1382677
02/08/13 11:27 AM
02/08/13 11:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
so, im not alone?
My buddy did the same thing BUT with the tailgate down
on his pick up... the force of the tongue going UP
has PLENTY of force to close said tailgate(and much more)
and it WILL leave a MASSIVE DENT in said tailgate
DAMHIK
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: HEMIFRED] #1382678
02/08/13 12:50 PM
02/08/13 12:50 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Na. we've just all learned from yours and others mistakes after reading these DAMHIK threads over the years.
nobody is doing anything embarrassing anymore!
DO YOU RECOGNIZE THIS ONE
got a new one...
never ever break the first rule of engine building...mock up and measure everything twice before final machine work/balancing. or you might find out that pistons advertised as having a .050" dome and expected to stick up .030-.040 past the deck on an uncut block, actually stick up above the deck .083" and then find out that the piston manufacturer changed the piston 3 years ago, but never changed the online description/specs, etc.
DON'T ASK ME HOW I KNOW!
yup. I had already made the timing chain mistake when I posted that one, but hadn't discovered it yet because that engine wasn't started till a few months later. I was building both those engines at the same time
**Photobucket sucks**
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: dvw] #1382679
02/09/13 11:06 AM
02/09/13 11:06 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Doug
Hmmm??? That reminds me of A guy I know put them finger tight then started across the garage to get a 6 point socket he liked to tighten them then thought I'll go pee first then played on the computer while in the house. went back to the garage assembled the tranny and into the car, into the trailer to the track to tech and back call for first TT and car no moves no more!
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: Dodgem] #1382680
02/09/13 11:51 AM
02/09/13 11:51 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
A loooong time ago, I decided my 58 Plymouth deserved an inside hood release, so I started dismantling the outside part to modify it. Went well, but I lacked the wire. Well, bought the wire later and did some more repairs/modifications to the car. This was in the fall. Then we had a long cold winter, and me as a youngster took the car for a first great testride when spring came. Guess what I forgot..... Luckily the 58 Plymouth has an extended roof so the hood took it all. Almost crashed when it blew open at 55 mph, but was saved by brakes dragging to the right....away from the meeting cars. A friend of mine heard the whole thing, and wondered why he heard a bang first, then squeeking tires. Kinda opposite of expected.....
Me fool? Oh yeah...
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: Oyvind Mopar] #1382681
02/09/13 08:39 PM
02/09/13 08:39 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Buy engine parts from a well known racer and not check everything you can.
At least check thrust easy enough if a dial indicator is around but, didn't.
Start swapping pistons and see wear on 1,3,5,&7 rod bearing but 2,4,6,8 are OK. So start ordering bearings without any more thought.
Then decided to check thrust well .010 can be too much if 1,3,5,&7 rod bearings are worn.
Don't ask me how I know.
But, when you remove the thrust bearing for inspection guess what side is worn.
But, it would be the transmission side.
Luckily I have seen the thrust issue before on some one elses engine who could say.,
They were not so lucky as they ran it for more than one pass and needed a crank.
Leon
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: Leon441] #1382682
02/10/13 02:37 PM
02/10/13 02:37 PM
Weatherford, Texas
RapidusMaximus Online content
RapidusMaximus  Online Content
Weatherford, Texas
The pretty...clean...white towel that you put over the lifter vally to keep random junk out while waiting to install the valley pan...should be removed PRIOR to installing said valley pan...don't ask me how I know...just for the record, it stayed in there until I had to change the valley pan for other reasons and SURPRISE...first thought was WOW, how did that get in there!!!!
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: "DON'T ASK ME HOW I KNOW" 2013 STORIES [Re: RapidusMaximus] #1382683
02/11/13 11:10 AM
02/11/13 11:10 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Don't retalliate to a mod's comment with "stop flapping your pie hole". DAMHIK..........
Page 3 of 4 1 2 3 4
