4160 Holleys missing check ball on the Vac Secs: HEMI #1382491
02/06/13 05:31 PM
02/06/13 05:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I am going thru a set of used carbs that I bought for my 528 HEMI equipped with a Stage V Rat Buster Dual Inline Intake Manifold.
I dissassembled the Vacuum Secondaries Diaphragms and turns out Im missing the check ball:
http://www.moparmusclemagazine.com/howto/155_0506w_holley_4160_short_bowl_conversion/photo_08.html
Do you think it will be a problem? All my Holley books and the Mopar Muscle article say you should not take it out or it will make the engine bog.
Where can I find these if I want to replace them????
Thanks!
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382492
02/06/13 05:47 PM
02/06/13 05:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should be able to find them at a hardware store or industrial supply house local to you , it's just a ball bearing .
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: JohnRR] #1382493
02/06/13 05:53 PM
02/06/13 05:53 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I hope I find the right size one......
I think I know where to go look for em locally.....
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382494
02/06/13 05:55 PM
02/06/13 05:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can you measure the spot it drops in with a drill bit ? Or maybe someone can measure one for you .
I have a 4160 at home in pieces , if I can remember I'll measure the ball for you and post if no one comes thru.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: JohnRR] #1382495
02/06/13 06:00 PM
02/06/13 06:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I guess all it has to do is drop in the hole, snug but without getting trapped....right????
Or i bet its the same as the 6 pack carbs diaphragms???? If so I have some used 6 pack carbs laying aroung I can probably take those check ball off from....
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382496
02/06/13 06:21 PM
02/06/13 06:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
don't put those balls in there, unless you have a death wish.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: lewtot184] #1382497
02/06/13 07:01 PM
02/06/13 07:01 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
please elaborate....
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382498
02/06/13 07:57 PM
02/06/13 07:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the check balls will delay the closing of carbs at WOT, at best, and may completely prevent the throttle from closing at WOT. don't believe me?, then try it. been there done that, and survived. if they were designed to delay opening wouldn't they delay closing?
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: lewtot184] #1382499
02/06/13 08:48 PM
02/06/13 08:48 PM
organ
maximum entropy Offline
organ
i never had that happen when running the balls. yes, they are to "control" the opening of the secondaries, but they have nothing to do with throttle closure. if you're saying they'll trap the vacuum above the diaphragm, no. there is a small channel to bleed that off on trailing throttle. if your throttle stuck, it was for a different reason, i think.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: maximum entropy] #1382500
02/07/13 12:27 PM
02/07/13 12:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The main reason they use a check ball is to have the right size to open them and when you let off the throttle the check ball lifts and makes the opening larger so they close fast enough. If they just had the hole the size for opening the secondaries without the check ball they would not close fast enough. If you leave the check ball out you will have a larger port which should open them real fast and close like they should. As far as I have heard the check ball is there to lift off the gas and make the port larger so they close fast enough. Its gives the right size to open them and then gives the larger size when closing to bleed off the vacum fast enough. Ron
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: 383man] #1382501
02/07/13 12:32 PM
02/07/13 12:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
So??? I should put them back in I guess.....
Domingo
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: maximum entropy] #1382502
02/07/13 12:49 PM
02/07/13 12:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The balls are usually removed in many race applications since with large cams and high compression piston there is minimual vacume to control the diaphram.The spring is then used for primary control(holding the plates closed) the signal from the manifold and cylinders draw them open.The stronger and quicker the signal the sooner the plates open.With a race engine at high idle or launch rpm or transbrake,two-step luanch or other means of leave negates any effect that vacume has.Just like any sring control on a AVS,Thermoquad controls the flapper wich are under tension the pod spring under compression has the same effect.Vacume tends to only effect mild engines that are footbraked at low rpm and when the engine adverages or exceeds 15inchs at lowrpm.
As far as plates sticking open,this will not happen unless the spring is removed or cut short as to not push the diaphram.Usually when the throttle is released the secondary relaxes to the closed position.To test the diaphram and spring open the throttle by hand and open the secondary,release the secondary and it should retract with the spring.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: B G Racing] #1382503
02/07/13 01:02 PM
02/07/13 01:02 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, they return no problem with just the spring action in the vacuum diaphragm.
This car will use a trans brake too. No footbrake (maybe on accassion).
Cam is not wild, but not stock either:
Intake- 248@.050 & .604lift
>Exhaust- 254@.050 & .591lift
>Lobe sep is 114
>lobe #`s: 4875B/4876B sn#-A6105
Compression is 10.5:1
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382504
02/07/13 01:06 PM
02/07/13 01:06 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
besides, the secondarys will be closed by the primaries via the over ride linkage on the throttle lever when you lift off the throttle.....So I dont think the ball has nothing to do with the secondarys closing too slow.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382505
02/07/13 01:17 PM
02/07/13 01:17 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
What Im thinking is that YES without the check ball the secondaries will open faster because the vaccum signal from the venturi will be pulling air from inside the diaphragm thru a larger hole, rather than from the tiny air bleed groove at the seat of the check ball. They will close just as fast with or without the check ball cause when the vacuum sinal weakens it will just blow the ball off the seat.....
Now the only thing I think it might happen is that you might have a BOG from the secondaries opening too fast????? Maybe on a stock engine, but on a high horsepower, BIG CUBES, high intake charge demand engine it wont be a problem????
I mean, I dont think that even without the check ball the vacuum secondaries cant open as fast as a carb with mechanical secondaries.....
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382506
02/07/13 01:22 PM
02/07/13 01:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Also, I think that the bleed port for the vacuum secondaries is above the throttle plates near the venturis, so its unafected by idle vacuum or pulsating vacuum like on race cammed engines......they only work when the vacuum singal is strong when throttles are open and engibe is revving.....
So the balls are there just to restrict excessive singal to the diaphragm to prevent a BOG due to the secondaries opening too fast (on a mild engine), and to open up the bleed passage to aid in faster closing of the secondaries when singal at the venturi drops to atmospheric.....
I guess Im cool leaving those out as long as my HEMI doesnt bog when those things open fast!
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382507
02/07/13 01:24 PM
02/07/13 01:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, one possible consequence of removing the balls is a bog when the secondaries open too quickly. Easy enough to rectify.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382508
02/07/13 01:27 PM
02/07/13 01:27 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I think you just answered all your own questions.You even figured out the linkage bar.It can be adjusted to even help facitilate opening the secondarys.
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: 383man] #1382509
02/07/13 01:29 PM
02/07/13 01:29 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
That is right!
Now the question is: do you think my engine will bog from too fast opening rate???
528 HEMI
10,5:1 compression
solid roller cam
>Lobe sep is 114
CNC ported heads flowing over 430 cfm intake 250 cfm exh
2,25" headers
stage V duial inline intake with dual 4160 750 holleys
Re: 4160 Holleys missing check ball on the Vac Secs: HEMI [Re: domingo] #1382510
02/07/13 01:34 PM
02/07/13 01:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is right!
528 HEMI
10,5:1 compression
solid roller cam
Intake- [Email]248@.050[/Email] & .604lift
>Exhaust- [Email]254@.050[/Email] & .591lift
>Lobe sep is 114
2,25" headers
Only way to find out is the run it , if it bogs change the springs .
