727 Trans Problems #1379560
01/31/13 11:10 PM
01/31/13 11:10 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys,
a friend is having a problem with his 727
it has a cheetah full manual reverse valve body. when in first gear the trans seams to be slipping when he floors
it but when he drives it normal it acts fine. when he shifts at WOT from 1st (slipping) into 2nd the car will fry the tires?
2nd to 3rd is perfect tho. one of the local guys he knows said it has
something to do with a spring adjustment but wasn't very clear as if he really didn't know LOL..
He really hopes its a easy fix he don't want to pull the trans out & fluid don't smell burned.
any help for him would be great thanks
Re: 727 Trans Problems [Re: GTXbound] #1379561
02/01/13 12:43 AM
02/01/13 12:43 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I always did mine in 2nd and never had a problem.
8.30's @3400 lbs
Re: 727 Trans Problems [Re: Mike Swann] #1379562
02/01/13 08:47 AM
02/01/13 08:47 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
hahaha What do you mean?
Re: 727 Trans Problems [Re: GTXbound] #1379563
02/01/13 09:09 AM
02/01/13 09:09 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
With the Cheetah RMVB, the low/rev band is NOT applied in "1". Only elements applied are the forward clutch and the over-running clutch is holding in "1". If it is slipping in "1", I might suspect that the over-running clutch rollers/springs have started to "lay over". The forward clutches are applied in ALL forward gears, so if the clutches were slipping, it would in 2nd and 3rd. The over-running clutch free wheels in 2nd & 3rd, so you would not notice slipping in those gears. More analysis needed to pin point, may include dropping the trans. If the over-running clutch is starting to fail, you are inviting an explosion of the direct clutch drum. Easy place to start - drop the pan and look for metal shavings.
John
Re: 727 Trans Problems [Re: GTXbound] #1379564
02/01/13 12:30 PM
02/01/13 12:30 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Moved
8.30's @3400 lbs
Re: 727 Trans Problems [Re: Mike Swann] #1379565
02/01/13 12:47 PM
02/01/13 12:47 PM
Guitar Jones Offline
DusterW2 is correct. However what he calls the forward clutch is more commonly reffered to as the rear clutch because it's behind the front clutch in the assembly. It has nothing to do with reverse though as that is handled by the rear band and the front clutch. Confused yet?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 727 Trans Problems [Re: Guitar Jones] #1379566
02/03/13 12:09 PM
02/03/13 12:09 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys thanks for all the answers
i told him what everyone said and he agreed to
pull trans out and take it to trans shop to check it out.
what billet drum do you guy use ?
i know he dont have a big budget to spend right now
but i think i can push him in to buying it based on safety.. thanks
Re: 727 Trans Problems [Re: GTXbound] #1379567
02/03/13 12:17 PM
02/03/13 12:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Did he buy the valve body new? Has it ever worked? Did someone take it apart?
Re: 727 Trans Problems [Re: Leigh] #1379568
02/03/13 12:52 PM
02/03/13 12:52 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Yeah he did buy it new bout 10+yrs ago and the trans was built back then.
but he didn't start running the car till now.
He finally got everything together motor wise.
It took him kinda a long time but thats life.
the car had about 1/4 inch of dust on it hahaha.
Re: 727 Trans Problems [Re: GTXbound] #1379569
02/03/13 01:14 PM
02/03/13 01:14 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Ok. I just wondered if someone had the valve body apart. I understand the 1/4" of dust, I'm almost there!
Re: 727 Trans Problems [Re: Leigh] #1379570
02/03/13 06:11 PM
02/03/13 06:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Your buddy needs a sprag and while in there he should buy a new billet front drum. A&A and TCS both sell them.
Re: 727 Trans Problems [Re: Leon441] #1379571
02/03/13 07:39 PM
02/03/13 07:39 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Thanks for all the help guy i let him know..
Re: 727 Trans Problems [Re: GTXbound] #1379572
02/03/13 07:40 PM
02/03/13 07:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If it sat 10 years the valves in the valve body COULD
be all corroded and not working right(as well as the
regulator)... just something to look at
