Page 11 of 12 1 2 9 10 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 71_340s_Only] #1376744
04/16/13 10:55 AM
04/16/13 10:55 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Not to hijack, but I've been doing some research as well. It seems Microsquirt2 v3 (with some minor mods)can run with just the 24x GM wheel and no cam sensor. It is batch-fire fuel and waste-fire spark but several people are running 700hp+ boosted engines with it. Conveniently, when wiring for waste-fire spark the cylinder pairs are the same for an LS1 and small block mopar. It looks very simple to install and you can still use junkyard LS1 coils, throttle body, etc. I plan to install a 24x wheel like Quicksilver did and follow these directions:
http://www.yellowbullet.com/forum/showthread.php?t=543066
This seems like a simple option for those looking to tune their own car. Its about $350-400 for the microsquirt, so cost will probably end up about the same as using the GM computer and paying for the tune.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: j.mcconnell] #1376745
06/24/13 01:32 AM
06/24/13 01:32 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
BTT bringing this one back from the dead as I'm getting ready to finally swap....really tired of tuning with the carb lol
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376746
06/25/13 10:37 AM
06/25/13 10:37 AM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
Wondering if any more progress has been made too. think I've read this whole thread a dozen times.
Its something I'd like to possibly do, I found a shop somewhat close that tunes LS dirt cars. They will put a base tune on your computer for what I think is a reasonable price. Haven't called them to see if they would be willing to something like this.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gpuller] #1376747
06/25/13 01:14 PM
06/25/13 01:14 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I did the EFI with coils about 10 years ago with a AEM ecm and LS coils . It is nice to be able to tune fuel and timeing on a individual cylinder. I run 400 hp nitrous .
But with out EGTs or 8 O2s I am not sure I would bother as it is going to be a tunning nightmare .
I have 8 EGTs and 2 O2s .would like 8 O2s but that is cost prohibitive.
We are running the Factory Ls computers on some stuff and I can tell you it is good stuff . It how ever is not as good as A good aftermarket ECM . I have A lot more usable features in my AEM. the factory Ecm is dedicated where others make them much more flexable.
As you can see I covered my Ls coils as they are ugly as sh!t
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376748
12/01/13 01:45 AM
12/01/13 01:45 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I plan on using a Jeep cam sensor like the one you have mentioned in this thread. The pinout shows a 5V in, GND and 0-5V output. I assume that one would have to regulate the 12V battery voltage down to 5V for this sensor?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: PC-CHARGER] #1376749
12/01/13 05:20 AM
12/01/13 05:20 AM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
The 5 volts will be provided by the pcm...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376750
12/02/13 01:32 PM
12/02/13 01:32 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I'm still working on collecting parts lol but my harness is done and ready to loom. Waiting on my money tree to grow
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: PC-CHARGER] #1376751
12/02/13 07:32 PM
12/02/13 07:32 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Regulated 5V is provided by the FAST ECU at the TPS and MAP sensors (red wires).
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Mopar_Rich] #1376752
01/04/14 02:53 AM
01/04/14 02:53 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I still need a bushing to use the Jeep Dizzy, Any one have anything?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Dos Snails] #1376753
03/09/14 01:10 AM
03/09/14 01:10 AM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Dos Snails] #1802521
04/13/15 05:49 PM
04/13/15 05:49 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
SD Concepts is making them.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gpuller] #1803142
04/14/15 12:09 PM
04/14/15 12:09 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Yes, very nice piece well worth the asking price.
68 Barracuda Formula S 340
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Bad340fish] #1973831
12/21/15 02:47 PM
12/21/15 02:47 PM
NV
smb03 Offline
smb03  Offline
NV
do you have to time or sync the crank reluctor ring and cam sensor, if so is it done off cylinder 1 tdc?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341231
07/21/17 11:09 PM
07/21/17 11:09 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Where do you purchase the SD concepts bushing? I don't see the option on their site. Is there another option?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341233
07/21/17 11:10 PM
07/21/17 11:10 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Hows that for a resurrection?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341294
07/22/17 12:41 AM
07/22/17 12:41 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Did you see the new cam sensor from Andy F?
I have them in stock. Checkout the CNP page on my website.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341322
07/22/17 01:44 AM
07/22/17 01:44 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Ya its all nice stuff..
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341324
07/22/17 01:58 AM
07/22/17 01:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I emailed Jerry, I don't have the address handy though. You might check out the facebook page for them.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341848
07/23/17 09:53 AM
07/23/17 09:53 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i'm here, you can pm me here. I've got kids at camp and i'm in and out of the office. we have the cps bushings on the shelf as well as our crank trigger kits for big blocks and small blocks. IF they would have asked rich wouldn't have had to reinvent the wheel
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #2341849
07/23/17 09:56 AM
07/23/17 09:56 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we have a 24x trigger wheel available for our crank trigger kits as well if anyone needs those.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
