Page 4 of 12 1 2 3 4 5 6 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: dogdays] #1376604
01/29/13 01:44 PM
01/29/13 01:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Check out the Ford cam sensor from a '90s OHC motor. It's simple.
R.
Exactly what I was gonna mention, you need to plug the distributor hole anyway, the Ford design does that pretty cleanly...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376605
01/29/13 01:56 PM
01/29/13 01:56 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
How does the reluctor and or pick up read? Is it magnetic or infrared or what?
If it is magnetic, won't the balancer interfere with it?
I don't know the answer and I am not scrutinizing your work, as it looks great! I am just trying to learn from you. thansk for sharing
Old Geezer Racing
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SCATPACK 1] #1376606
01/29/13 02:23 PM
01/29/13 02:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a general question , do these type of conversions have to be done with a single plane type intake of ?
How would a dual plane work , say like the RPM ?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376607
01/29/13 04:12 PM
01/29/13 04:12 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
Here is my attempt at a hidden reluctor, it is a 24X reluctor off a BB Chevy that fits on the crank snout. The problem is that the BB Chevy crank snouts are a larger diameter than the BB mopar so there is more play than I am comfortable with. If that reluctor is not centered on the crank snout, then the clearance between the reluctor teeth and the Crank Sensor would vary during rotation. Anybody know a easy way to make the hole smaller and maintain a key way? It is made of powdered metal, if that makes a difference....
Then the problem would be how to add a crank sensor to the bottom of the timing cover, it doesn't really land in a good location on the cover during my mockups....also, I would want some level of adjustment with the sensor and the keyway on a BB chevy and a BB mopar is not the same if I remember correctly. So the reluctor would need another keyway cut (but that's no big deal). Also, the balancer snout would have to be cut to keep pulley alignment, but again, thats no big deal.
How about removing the part that connects to the crank snout and attaching the reluctor to an oil slinger ?
Great write up , I'd definitely want to do something like this considering the cost.
I don't see oxy sensors listed on the 700 budget side ?
OOPS! I forgot the oxygen sensors in the other column....ok, what If I told you you could do it for $800...
I'll have to look at the oil slinger....honestly, that BB Chevy reluctor probably fits as tight as an oil slinger does. I could just cut a new keyway.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376608
01/29/13 04:14 PM
01/29/13 04:14 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
IMHO, I would think it would be less than ideal. Placing all the injectors accurately so they shoot at the back of the intake valve is tricky because of the shape of the runners.
A DP wet flow manifold is a compromise to assure good air velocity at low engine speeds so the carb gets good signal and the engine sees decent fuel distribution.
A port injected engine doesn't have this problem to deal with so a single plane doesn't give up anything on the bottom as all it has to do is deliver air. Runner shape makes ideal injector location easier too.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376609
01/29/13 04:15 PM
01/29/13 04:15 PM
Central Valley, CA.
Central Valley, CA.
R.
I'll check it out....
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SCATPACK 1] #1376610
01/29/13 04:18 PM
01/29/13 04:18 PM
Guitar Jones Offline
Very interesting thread, thank you for sharing. I may just consider doing the same on my small block.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Guitar Jones] #1376611
01/29/13 04:25 PM
01/29/13 04:25 PM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
Great post!!
Heres a thought for the bbc reluctor you have to trim the ballancer anyway put a step in it to fit the reluctor.
Thanks again for giving me more ideas to build even more projects around....
The sickness continues...
ACCELERATION SPECIALIST
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SCATPACK 1] #1376612
01/29/13 04:45 PM
01/29/13 04:45 PM
Central Valley, CA.
Central Valley, CA.
The crank signal from an LS1 (24x reluctor wheel) is a typical hall effect square wave output. The reluctor uses 2 different width notches (12* and 3*) that are 15* apart.
Reluctors for both the cam and crank in an LS series engine uses the absence or presence of ferrous material (iron or steel) to modulate a magnetic field that is sensed and sent to the PCM in the form of voltage/current changes.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376613
01/29/13 04:48 PM
01/29/13 04:48 PM
Central Valley, CA.
Central Valley, CA.
I would agree with this.....but I really am not an expert on that subject.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: voigtspeed] #1376614
01/29/13 04:49 PM
01/29/13 04:49 PM
Central Valley, CA.
Central Valley, CA.
Great post!!
Hey...thats a cool idea!!! Let me check that out....
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376615
01/29/13 05:04 PM
01/29/13 05:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How about attaching the reluctor to the lower crank gear ?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376616
01/29/13 05:07 PM
01/29/13 05:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks, I've only ever thought about buying something like the new FAST that looks like a carb , this setup has me intrigued. I'd have to do more homework to see what's involved with running it with E85.
Any links to info for a novice to do their homework ? Injector sizing ?
Sorry for straying
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376617
01/29/13 05:13 PM
01/29/13 05:13 PM
Central Valley, CA.
Central Valley, CA.
Thats possible too...I'll try and test fit that again on my spare block and see what I can come up with.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376618
01/29/13 05:18 PM
01/29/13 05:18 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
E85 would require an injector capable of flowing 30% more fuel. I don't know if a Flexfuel engine uses the same style of injectors or not and if so how much above stock can they support?
Kevin
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376619
01/29/13 05:30 PM
01/29/13 05:30 PM
Central Valley, CA.
Central Valley, CA.
Sorry for straying
Try these calculators as they have E85 functions..and FIC (the first link) sells tons of LSX injctors .My brother just recently built/tuned a newer GTO with just over 1000 Rear Wheel HP on E85 using the stock computer. So it can be done....people used to say the the stock computers were limited in how big of injector they can support....but that has been mostly overcome and these large 2000cc, etc FIC injectors even come with injector map charts to help with the initial tuning.
http://www.fuelinjectorconnection.com/
http://www.dsmtuners.com/sub.php?page=e85calculator
http://injector-rehab.com/shop/e85_injector_size.html
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376620
01/29/13 05:32 PM
01/29/13 05:32 PM
Central Valley, CA.
Central Valley, CA.
Kevin
You don't even need to use a flexfuel PCM...it's all in the injector map that your tuner inputs for the injectors your using (or you input in the HP tuners or EFI Live Software).
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376621
01/29/13 05:51 PM
01/29/13 05:51 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That makes sense. I was just wondering if the Flex injector itself is able to physically flow more fuel than a gas one for a given pulse width or are they the same part# and you just increase the pulse width to get the 30% extra for E85.
Kevin
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376622
01/29/13 06:02 PM
01/29/13 06:02 PM
IL
furious70 Offline
furious70  Offline
IL
FWIW I'm using an rpm perf for my turbo 383 and the distribution is beautiful according to my plugs. I use a sheet metal elbow and 5.0 TB. I have a friend who has also had the best luck with distribution and mpg with a DP on his turbo 340. My take away is use whatever intake you would use based on the goals for the car with a carb and not sweat the efi. Other people may have had a different experience.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376623
01/29/13 06:10 PM
01/29/13 06:10 PM
Central Valley, CA.
Central Valley, CA.
Also, remember when doing injector size calculation that LS motors run fuel pressure at 58 psi.
Flexfuel injectors are actually larger...flow more lbs (like 34lbs vs. 27 lbs +/-)....than the regular fuel injectors to allow for the E-85. Unless you WAY oversize an injector, it won't affect idle, etc. much, if at all if tuned correctly.
