727 TF #1376492
01/26/13 06:48 PM
01/26/13 06:48 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
Hey guys, I'm ready to replace my 727. It's in a 67 Coronet, 511 stroker 440-1 heads Ultimate 9"TC,etc. I just want to purchase a complete replacement, this is really just a street car.I know an aluminum drum is out, no transbrake either. Any opinions on where to purchase and what to buy?
Re: 727 TF [Re: PRZ] #1376493
01/26/13 07:39 PM
01/26/13 07:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: 727 TF [Re: VernMotor] #1376494
01/26/13 08:05 PM
01/26/13 08:05 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
x2
Re: 727 TF [Re: VernMotor] #1376495
01/26/13 08:05 PM
01/26/13 08:05 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: 727 TF [Re: Crizila] #1376496
01/26/13 08:11 PM
01/26/13 08:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with Cope trannys's. If you are going to buy a trans and not build your own then buy from a reliable company that builds good race tranny's and Cope does build good tranny's. Ron
Re: 727 TF [Re: 383man] #1376497
01/26/13 08:38 PM
01/26/13 08:38 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
Thanks guys, I guess your all using them.lol What about A&A,any1 using them. I just looked @ Cope's site the pro race2 for $3150 is lookin like the right choice for me, any1 using that 1?
Re: 727 TF [Re: PRZ] #1376498
01/26/13 09:15 PM
01/26/13 09:15 PM
gregsdart Offline
gregsdart  Offline
It would be a LOT cheaper to go through your present tranny if the core is good. You could have it rebuilt with an aftermarket steel or aluminum drum for less than $1500? If you need a lot of replacement parts, you are still way ahead of 3150.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: 727 TF [Re: PRZ] #1376499
01/26/13 10:22 PM
01/26/13 10:22 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks guys, I guess your all using them.lol What about A&A,any1 using them. I just looked @ Cope's site the pro race2 for $3150 is looking like the right choice for me, any1 using that 1?
I'm not using his tranny,but i use his internal parts(brake,drum,sprag etc.)with good results
Re: 727 TF [Re: PRZ] #1376500
01/27/13 02:19 AM
01/27/13 02:19 AM
On your deal I would look at using a Mopar brand 2.77 low gear set and a steel drum I'm sure Cope can do that for you, I live west of the big muddy so I use Dave Smith at Pro Trans for all of my 727 tranny builds I can do them myself but he has all the little parts needed (thrust washers, snap rings and so on) to set the end play up correctly inside the tranny and a ton more knowledge on torqueflytes than I do so he gets my tranny work
Re: 727 TF [Re: gregsdart] #1376501
01/27/13 06:10 AM
01/27/13 06:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I rebuilt mine and in the end I din't save very much money. Related thread:
https://board.moparts.org/ubbthreads/show...page=0&vc=1
The ProRaceII is a full rollerized trans, with billet drums, gear, servo, new manual reverse VB, even a deep pan, plus a bunch more, and then there are associated assembly parts not even listed like the different thickness drum to pump bushings, selectable thickness output shaft snap ring, setting the clutch packs with selectable clutch retainer rings and/or different thickness kolene steels. If you price all the parts out you don't save a whole lot.
Re: 727 TF [Re: PRZ] #1376502
01/27/13 11:22 AM
01/27/13 11:22 AM
NC
440Jim Offline
440Jim  Offline
NC
If you phone John Cope he will give you a good recommendation on which of his transmissions fits your application best.
But, IMO, that ProRace II is more than you need for a street car. I am thinking the regular ProRace with the steel front drum upgrade would do the trick, $1,595+$535= $2,130. That saves you the expense of the roller bearing modifications.
Re: 727 TF [Re: 440Jim] #1376503
01/27/13 11:28 AM
01/27/13 11:28 AM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
thanks for the input guys, i'll be givin them a call tom.
Re: 727 TF [Re: 451Mopar] #1376504
01/27/13 11:29 AM
01/27/13 11:29 AM
ill
dennismopar73 Offline
ill
There are always up grades that some one could do to the 727 trans,, but the basic standard trans rebuild will work just fine!
Attention to details when rebuilding is the key when it goes back together.
There are several of us who have race cars, run deep into the 9 with just standard rebuilds, with small upgrades bolt in sprags,, and rear roller bearings which is both cheap to do!
As stated , you can spend a lot , and get the same performance out of a stock unit.
Re: 727 TF [Re: PRZ] #1376505
01/27/13 01:09 PM
01/27/13 01:09 PM
Penna
70satelliteguy Offline
Penna
"this is really just a street car."
I really don't think you need the full race transmission.
As stated a simple rebuild with a few selected modifications would do the trick for your application. That is unless you are into overkill and don't mind spending the money!
Mike
Re: 727 TF [Re: PRZ] #1376506
01/27/13 01:22 PM
01/27/13 01:22 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
FWIW.. We just use a standard 727 built with a Turbo Action "Tranz Box" rebuild kit.Works great,no problems.
Nautilus Racing-
Re: 727 TF [Re: racerx] #1376507
01/27/13 02:44 PM
01/27/13 02:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont use Cope tranny's either but thats because I build my own. But many people on here use them and I hear nothing but good about their work. As many have said for a mild street car you dont need a race trans so I would just tell them what you plan to use your car as and let them build what they think you need. I use stock Mopar clutches in my tranny's and my brother does also. Even when he was running high 8's in his Cuda we still used Mopar clutches and never had a failure. We have both been Mopar dealer techs for over 20 years so we have a nice stock of Mopar 727 clutches and steels. Ron
Re: 727 TF [Re: VernMotor] #1376508
01/27/13 02:57 PM
01/27/13 02:57 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Re: 727 TF [Re: 383man] #1376509
01/27/13 03:26 PM
01/27/13 03:26 PM
N.Y. Tioga
P
PRZ Offline OP
PRZ  Offline OP
P
N.Y. Tioga
I do understand where you guys are coming from, but i don't think a 800HP 3500lb B-body is a MILD Street Car. I'm looking for something that could last for some duration.
Re: 727 TF [Re: PRZ] #1376510
01/27/13 03:59 PM
01/27/13 03:59 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
See Sig. I stripped down the 727 in the Challenger last year. After 4 seasons (70ish passes a year) it was hardly worn, the front clutch pack was 9 thou looser than when rebuilt (I kept notes). Still within the limits, it didn't need a rebuild but did it anyway since it was apart.
It's built with stuff from CRT, the usual ware, Kolenes, reds, billet servo's, steel front 5 pinion planetary, bolt in sprag, Griner LBA MVB, oiling mods etc.
Speak to John, he'll keep you right, they're easy enough to build yourself too.
HTH's
OH and a billet steel front drum.
Re: 727 TF [Re: PRZ] #1376511
01/27/13 04:06 PM
01/27/13 04:06 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Get the 727 hand book Cope helped write it.
I used it and all the parts from cope to build a nice street strip trans.
Cope rebuild kit red alto clutches and koleen steels.
billet servos
tf2 or manual valve body
4.2 lever with heavy duty strut
red lined bands
steel planetary
pump modifications done at home per the hand book.
6000 Rpm Governor if using auto shift .
put the the money into the parts and build yourself 727 easy to do.
this is what i did and then there is my friend has a bone stock trans
behind a blown 440 with just a manual valve body for 200 bucks and the trans has held up with street and strip driving so far 10 plus years.
a good trans to start with is key .
1969 Dodge Charger 1969 Dodge Superbee
