Page 14 of 25 1 2 12 13 14 15 16 24 25
Re: Triple Black Bee [Re: basketcase] #1376154
03/18/14 02:35 AM
03/18/14 02:35 AM
Oh
His and Her 69's Offline
Oh
Darin you just need to down size your collection and work on the Bee.
I started doing that myself and also getting rid of parts I don't need anymore. Once you get to driving the Bee your mindset will change and all will be Good again. If I can help let me know.
David
Re: Triple Black Bee [Re: His and Her 69's] #1376155
03/18/14 08:48 AM
03/18/14 08:48 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I found a place to do the head as I spent 6 hours replacing eh wheel bearing in my truck. Maybe once I put some miles on it I won't be so annoyed. You might be right. Well, if you have a set of ported 906/452's, that would help!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Triple Black Bee [Re: OhioMopar] #1376156
03/19/14 02:38 AM
03/19/14 02:38 AM
Oh
Oh
No ported heads that are not being used at the moment.
I have a set of Indy SR heads but that motor is too much of a wussy
for them. Lol
Those heads will do you fine for that motor so no sense spending any money on different ones. Use your money for more important things like buying me gifts because I am a Nice guy. Lol
Good to hear you have a place now to work on it at.
I will take those heads back if you don't want them?
Take Care Darin.
David
Re: Triple Black Bee [Re: His and Her 69's] #1376157
03/19/14 05:54 AM
03/19/14 05:54 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
for them. Lol
Take Care Darin.
David
I was just going to find a set that was done and put on whenI pull these. Kind of for a seamless transaction. If I'm going to pull one, I'm pulling both!
It's not that at all! You didn't say that much was done to them(or my memory sucks) so I was just looking for another set done a little more in case I found a reasonable price on some.
I'm fresh out of gifts! But hopefully I'll give you the satisfaction of seeing your old bullet run in May!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376158
03/20/14 04:53 AM
03/20/14 04:53 AM
Oh
Oh
I HOPE you do make it in May. We are taking Janet's car again for the whole weekend.
Hope to see you and the car there THIS YEAR!!!
David
Re: Triple Black Bee [Re: His and Her 69's] #1376159
03/20/14 07:55 AM
03/20/14 07:55 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
David
I'll be there for sure. Hopefully so will the car...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376160
03/28/14 04:50 AM
03/28/14 04:50 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Not a lot to report on. Well, nothing actually. I got the car moved to the new home. I got my out of state vehicle inspection done in the process. Maybe it will be warm enough to work on it this weekend. It is finally inside, if you can call it that.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376161
03/30/14 02:03 PM
03/30/14 02:03 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Cozy in the new home.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376162
03/31/14 03:13 AM
03/31/14 03:13 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
might not be a 60x60 climate controlled building, but it's out of the weather.
1981 Dodge D150 360 auto
Re: Triple Black Bee [Re: basketcase] #1376163
03/31/14 08:42 AM
03/31/14 08:42 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That it is. I worked on it for a while last night. I found enough bits to put together a tool to shove the plug in. But I ran out of threads before the plug let go. So I'll try to scrounge some more stuff at work today and get it finished up tonight. Then I'll re-rebuild the distributor and get a heavier spring in it. Exhaust this weekend...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376164
03/31/14 12:34 PM
03/31/14 12:34 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
will you be taking the Bee to the Nats?
Re: Triple Black Bee [Re: basketcase] #1376165
03/31/14 03:40 PM
03/31/14 03:40 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That's my plan. The swap meet in Dalton in two weeks, the Jeff Johnson show in May, Carlisle in July and the Nats and Woodward in August. Maybe Norwalk in September if I have any vacation left by then.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376166
04/01/14 01:03 PM
04/01/14 01:03 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
great. I don't think Carlisle is going to happen for me, but I've got my sights set on The Nats.Hope to see you there!
Re: Triple Black Bee [Re: basketcase] #1376167
04/03/14 10:14 PM
04/03/14 10:14 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
You should recognize the car!
Mini update. I tried every pry bar and screwdriver I own, and there was no way to get to the leaking plug. Despite what all the people told me about how I could just pop it out with a screw driver! (Noone who had done it before mentioned screwdrivers or pry bars, but wood working clamps and homemade tools) My guess is this is not a fairly common issue, and you really have no room to work unless you take the hood off...
So I built myself a tool out of a coupler nut, a piece of steel with holes drilled in it, an assortment of 5/16 bolts, and a nut. I was able to poke another hole in the plug. In the end, it is no longer leaking. Thanks Feets and JB Weld. I'll do a more permanent fix when I can take the heads off, but that ain't in the plans right now. It doesn't leak, doesn't move, so I'll run it until it strands me.
So next up is getting the distributor set up and coming up with an exhaust system.
I found my floating taking issue, the plate the pickup coil is attached to had a lot of play in it. I replaced the "tripod" spring out of a distributor that was under 30 years old and everything is relatively peachy.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376168
04/04/14 11:55 PM
04/04/14 11:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you ever need to know the improper way to fix things all you need to do is ask.
- Stu Harmon
Re: Triple Black Bee [Re: feets] #1376169
04/05/14 11:33 AM
04/05/14 11:33 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'll keep you at the top of the list!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376170
04/13/14 08:52 PM
04/13/14 08:52 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
More progress. I picked up a Jegs X-pipe, a pair of Pypes Violator mufflers, and after a trip to Jegs, then a trip to Summit, a set of collector extensions with an s-bend in them. It took me most of the day, but the car now has exhaust on it. I had to run out to use a chop saw to shorten one of the collector extensions, and had to get some reducers because as has been my experience with Jegs "univsrsal" kits, they just weren't quite right. There is no flared end on any of the pipes in the kit. So I either had to butt weld them together (no welder) or use a 2.5" to 2.25" reducer. I don't think it will be a terrible bottleneck. After I had it 98% done, I found Auto Zone had 2.5" to 2.5" slip on connections (that they were out of). But I wasn't taking it back apart. I still need to bend or fab a rear hanger, and find a set of turn downs. But it sounds GREAT!!!! I love the Violator mufflers.
I will most likely take it somewhere once I get a couple more things straightened out and have it all taken apart, squared up, and welded. It isn't the prettiest, it's not even or square, and I can't tell if the mufflers are even when I'm laying on my back under it. But it'll do until I get the new engine built, the engine bay repainted, and the tti system ordered!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376171
04/14/14 12:41 PM
04/14/14 12:41 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that's great.
Re: Triple Black Bee [Re: basketcase] #1376172
04/20/14 09:29 AM
04/20/14 09:29 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I finished up the exhaust yesterday and finally drove it. It needs plugs, which I have, and a little tweaking. But it runs down the road and goes into all 4 gears and reverse. It needs the front end done for sure, and both of my grease caps on the front wheels flew off. But I'll get to all that. I'll hopefully get plugs in it today and play with it some more.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376173
04/20/14 08:22 PM
04/20/14 08:22 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
