Page 2 of 7 1 2 3 4 5 6 7
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373366
01/22/13 08:16 AM
01/22/13 08:16 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
It says takes up to 48 hours to show up in search
O well I guess ill just have to wait
This one? Has a nice whistle!
http://youtu.be/6Ux_0zeEG9I
Re: budget turbo Belvedere still alive and well [Re: MPerry] #1373367
01/22/13 10:15 AM
01/22/13 10:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
are those custom headers? They look like shorty's. I'd like to do a turbo set-up like that one of these days. Does all that clear the factory k-frame. Looks sort of like this SB set-up.
Coming soon!!!!
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373368
01/22/13 11:27 AM
01/22/13 11:27 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
would spend a little more money and get a master power or a borg warner. Those turbos are cheap for a reason
I hear what your saying about those chinese turbos, but check out theturboforums.com. They have a thread about the gt45 that a bunch of guys are using and seems to hold up and make power.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373369
01/22/13 03:05 PM
01/22/13 03:05 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Looking good man!
I'm a fan!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373370
01/22/13 03:25 PM
01/22/13 03:25 PM
DRAG-ULA Offline
DRAG-ULA  Offline
I dig it!!!!! Glad to know the lower end will take that kind of abuse. I'm waiting for my 383 to kick a rod out or break a piston, and I'm only at 12 lbs. Maybe it'll never happen.
1970 Imperial, Low & slow daily driver
1973 Chrysler T&C
1948 Dodge B1 pickup - perpetual project
Re: budget turbo Belvedere still alive and well [Re: DRAG-ULA] #1373371
01/22/13 03:44 PM
01/22/13 03:44 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Yes that is the vid !!!!!
The headers are stainless block huggers from eBay
I think there China made but good quality
I can only find the style header for early Hemi now on eBay
As far as master power turbo, I was gonna go that rout till I found the info on these
For the price ya can't beat em
I do have 2 BW S475 for another project, might get a t4 to t6 adapter and try it
Re: budget turbo Belvedere still alive and well [Re: DRAG-ULA] #1373372
01/22/13 03:51 PM
01/22/13 03:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
How much timing do you have in this thing? Lol...what year motor (how much compression)?
How quick/fast has it been in the 1/8 mile?
Re: budget turbo Belvedere still alive and well [Re: dizuster] #1373373
01/22/13 05:00 PM
01/22/13 05:00 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
It's the original 383 from the car
1968 engine. So prolly 9 to 1 I think
Timing is locked out at 28
As for 1/8 mile times ill have to look at the time slips
They are all in the car
And the car is in storage LOL
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373374
01/22/13 07:57 PM
01/22/13 07:57 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Good i love e85...the abuse thus fuel will take...Guess I can probably run more then 8psi and 20 degrees of timing in mine then huh?
Re: budget turbo Belvedere still alive and well [Re: Mr.Yuck] #1373375
01/22/13 08:35 PM
01/22/13 08:35 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I would love to see a pic of the other side of that engine, looks like an "easy" fit in an abody.
68 Barracuda Formula S 340
Re: budget turbo Belvedere still alive and well [Re: Bad340fish] #1373376
01/22/13 09:17 PM
01/22/13 09:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sorry found it online. I'm guessing they are shorty headers looks like straight pipe down and under the k-frame over to pass side.
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373377
01/22/13 11:03 PM
01/22/13 11:03 PM
Washington State, USA
W
Winchester 73 Offline
W
Turbo is a Ebay GT45 y2004k, Ebay 53mm BOV and 60mm waste gate.
Its like a 69mm 105AR exhaust, I have 4-5 years on it now with no problems what so ever....
And we are not nice to it at all!!!
Engine is BONE stock 1968 383 never been apart except for.
280/480 comp juice cam, used one I had laying around
double roller chain
chrome timing cover lol
High volume oil pump
And a Torker 383 intake with new valley pan cause the old one was rusted out.
Carb i did myself, it runs on E85
3500 10" stall, colum shift.... I just leave it in drive!!!
3.91 gear witch I will be swapping for 3.23 soon
29x10 Slicks
High 10s @ around 120 so far but fuel system cant keep up so no full power passes yet.
should run low 10s to high 9s @ 130s once fuel seystem keeps up
BTW!!! car is FUN to drive !!!! layer on the wood and let the Turbo do the talkin LOL !!!!!
thank you for building this!you must have done this in a secret location away from the moparts gestapo.at the minemum for boost you need pistons from some sort of metal that came from a meteor,aftermarket block,the newest of heads that JUST got developed and then sent to some wichdoctor for porting ect,ect and if all this fails they would tell you to turbo a stock LS1
Re: budget turbo Belvedere still alive and well [Re: gtsdude] #1373378
01/22/13 11:33 PM
01/22/13 11:33 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I agree 100%. If others are having luck i guess its worth a try. I got lucky and picked up a new s480 from a buddy for peanuts. glad to see that there will be other turbo mopars out to play with.
Re: budget turbo Belvedere still alive and well [Re: prochargedhemi] #1373379
01/23/13 01:38 AM
01/23/13 01:38 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Love the comment Winchester !!!!!!
You hit the nail on the head with that one !!!!!
As for the pipe connecting the headers to turbo.
It's compression bent 2 1/2 with a home made Y that I tried to make flow as good as I could
It pokes up threw the hole inbetween the K member to the turbo
Just a tad less ground clearance by about a 1"
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373380
01/23/13 01:46 AM
01/23/13 01:46 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
And yes !!!!!
dizuster don't be afraid to turn the wick up !!!! LOL
I never really like driving the car untill 15psi
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373381
01/23/13 02:07 AM
01/23/13 02:07 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
And yes !!!!!
Im gonna blame you cause now the gears are turning in my brain for a turbo deal on my cast piston 440...Boost just looks so fun. Your car truly is badass.
Re: budget turbo Belvedere still alive and well [Re: 69B3GT] #1373382
01/23/13 02:45 AM
01/23/13 02:45 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Thanks 69 !!!!!
After the turbo stuff started to come out and I would watch them run got me thinkin about boost !!!!!
I had to have one !!!!!
It's the funnest car I have ever owned, cheepest too LOL
Well that goes this quick anyways !!!!
You don't have to own a fox body with a 5.0 or a Chevy product to go fast cheep.
Re: budget turbo Belvedere still alive and well [Re: Winchester 73] #1373383
01/23/13 02:50 AM
01/23/13 02:50 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Exactly! The reason turbo Mopars arent more predominant is simply because people dont build them.
Mopar to the bone!!!
Re: budget turbo Belvedere still alive and well [Re: 72Swinger] #1373384
01/23/13 03:03 AM
01/23/13 03:03 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Well hopefully this will change things
And if anyone needs info on the build I will try my best to help them out !!!!
Re: budget turbo Belvedere still alive and well [Re: RockChip] #1373385
01/23/13 03:36 AM
01/23/13 03:36 AM
W
W
i have a 73 dart sport with a fresh rebuilt cast piston 383 with the very same cam 8 3/4 with 3.23 stock 727.lots of carbs to play with -e85 is sold about twenty minutes from my home.im thinking about doing this with reversed stock manifolds.
how much to setup a carb for me?
