Early A body with Alterkation and TTI headers #1372658
01/20/13 11:57 AM
01/20/13 11:57 AM
ont,canada
mopartuner Offline OP
ont,canada
Has anyone on here done this combo?I am talking about a small block auto with tti's step headers and the alter K.Problems?
410 pump gas solis flat tappet cam 10.95 so far
Re: Early A body with Alterkation and TTI headers [Re: mopartuner] #1372659
01/20/13 02:29 PM
01/20/13 02:29 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
It can be done, i dont have one myself but i have picx, i'll try to find them for you. Btw i know at least one in Fabo.
Re: Early A body with Alterkation and TTI headers [Re: mopartuner] #1372660
01/20/13 02:46 PM
01/20/13 02:46 PM
Delray beach, Florida
P
Performance Only Offline
P
How early of an A body are we talking about? I put a set on a 66 dart with a 360 we built for it. The TTi's were a nightmare to install and keep from touching anything. In the future i'd rather build my own than deal with their product.
machine shop owner and engine builder
Re: Early A body with Alterkation and TTI headers [Re: Performance Only] #1372661
01/20/13 02:58 PM
01/20/13 02:58 PM
ont,canada
ont,canada
I have a 65 cuda and wondered if going to an alter k might fix some of the intallation and clearance issues.
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372662
01/20/13 03:00 PM
01/20/13 03:00 PM
ont,canada
ont,canada
Thanks,pics would be good.
Re: Early A body with Alterkation and TTI headers [Re: mopartuner] #1372663
01/20/13 03:58 PM
01/20/13 03:58 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Any off the shelf header on an early A body (63-66) is going to be tough. Basically you have to understand your framerails are 2" closer together than later A bodies. I have never looked at a set of TTI headers on one of these but can only imagine how tight the fit will have to be.
I would recommend running a BOBSPROFAB tubular front k-member with rack and pinion and coilover shocks. This will move all the problems out of the way. Then you have a lot more room. But, the best headers are going to be a custom built header. This is not inexpensive and I don't want to BS you in to believing it is. But, after you do this you would really have a nice front end and headers that would truely turn your somewhat basketcase Barracuda into a really nice user freindly car. I feel I can say this because I know these cars well. My car was a total headache to work on until I made these upgrades up front. Now I would not trade it for any other A-body.
PM me if you have any detailed questions
Leon
Re: Early A body with Alterkation and TTI headers [Re: Performance Only] #1372664
01/20/13 04:00 PM
01/20/13 04:00 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
What header wouldn't be a nightmare on a early A, other than fenderwell?
Re: Early A body with Alterkation and TTI headers [Re: Leon441] #1372665
01/20/13 04:43 PM
01/20/13 04:43 PM
Mcallen, TX
Mcallen, TX
Leon
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372666
01/20/13 04:44 PM
01/20/13 04:44 PM
Mcallen, TX
Mcallen, TX
2
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372667
01/20/13 04:45 PM
01/20/13 04:45 PM
Mcallen, TX
Mcallen, TX
3
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372668
01/20/13 04:46 PM
01/20/13 04:46 PM
Mcallen, TX
Mcallen, TX
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372669
01/20/13 04:46 PM
01/20/13 04:46 PM
Mcallen, TX
Mcallen, TX
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372670
01/20/13 04:47 PM
01/20/13 04:47 PM
Mcallen, TX
Mcallen, TX
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372671
01/20/13 04:48 PM
01/20/13 04:48 PM
Mcallen, TX
Mcallen, TX
Last..
Re: Early A body with Alterkation and TTI headers [Re: SB449VALIANT] #1372672
01/20/13 08:33 PM
01/20/13 08:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I like the AlterKtion because it eliminates the need for the stock upper shock mount.
Mine is a '65 with W-9 heads.
I started with a kit for late A body headers from Stahl and don't have pics of the finished product , but they turned out pretty O.K.
The primaries are a couple inches longer than optimum and one tube on each side still goes outside the rails ( 7 & 8 ), but I got a good stretch of tube before the first bend.
The steering shaft needs to come out for installing / removing them , but I am happy with the results.
Not cheap either , but a lot cheaper than having them made....with flanges from SPD and the kit , I had around 650.00 into them.
Got them coated locally and bartered on part of the price so I am into them for under 850 bucks......well under 1/2 price of having them built.
Re: Early A body with Alterkation and TTI headers [Re: tubtar] #1372673
01/20/13 08:34 PM
01/20/13 08:34 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
another angle
Re: Early A body with Alterkation and TTI headers [Re: tubtar] #1372674
01/20/13 08:36 PM
01/20/13 08:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
partial from pass side.........when I was done they looked nothing like the picture I was using for a reference.
Re: Early A body with Alterkation and TTI headers [Re: tubtar] #1372675
01/21/13 06:20 PM
01/21/13 06:20 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Soooooo..
The undercar TTI's won't fit a car with a Alterkation suspension but, they would a stock set up ?
Re: Early A body with Alterkation and TTI headers [Re: bigdad] #1372676
01/21/13 07:13 PM
01/21/13 07:13 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Soooooo..
I bet they would , and are probably a nice choice for stock ports or maybe even W-2's.
1 3/4 to 1 7/8 " step would be marginal for my deal and hacking apart a 800.00 set of headers to use the W-9 flange and still having un-equal primary length factored into my decision too.
Re: Early A body with Alterkation and TTI headers [Re: tubtar] #1372677
01/21/13 07:25 PM
01/21/13 07:25 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
post more pics of your project
I had never seen it before this thread
Please
