A couple of things here... the heads.. you have .660
lift so the heads need to have a peak flow in the
.500 lift range.. thats pretty easy with a W-2.. but
it doesnt say what the flow is... a set of W-2 can have
a flow of 300 cfm pretty easy.. you need to show all
the specs on the cam so we get a idea of the duration
anf see what it will turn in the rpm range... you
will be happier with a H beam rod... I have torn
a I-beam in half before and when I changed over to
the H-beams I havent had any problems... flat top
pistons have a much better flame front.. it doesnt
have to burn around corners or humps.... have you
sat down to figure out your goals with the car...
thats a MUST... then figure out the budget for the
car then the budget for the engine..... its cheaper
and easier to make the car lighter than it is to make
more HP, plus its easier on parts
