Re: My New Bullet; a 454 Small block
[Re: Cab_Burge]
#1369559
01/14/13 11:42 PM
01/14/13 11:42 PM
Triple Threat
Renton Washington
The plenum is fairly sizeable as it sits, but I was planning on experimenting with spacers anyway. The car is still only legal to 10.0, and its heavy.
[Re: DavidDean]
#1369563
01/15/13 01:22 AM
01/15/13 01:22 AM
Triple Threat
Renton Washington
I might be dumb enough to drive it to the track just to do it. We'll see, I can tell you that its gonna be driven on the street still.
Cam is the one it came with, kind of old school but for now it works. The heads were treated to new valves, springs and just a good check up and cleaning. If budget wasn't a concern it would have an Indy or W9 on top of it, probably will in the future. For now these heads shall get the job done.
[Re: SB449VALIANT]
#1369565
01/15/13 02:13 AM
01/15/13 02:13 AM
Triple Threat
Renton Washington
More picx, of those B1's will be nice!
I don't have any good pictures of the short turn. Would need to pull the valves out for those.
[Re: Al_Alguire]
#1369573
01/15/13 09:16 AM
01/15/13 09:16 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Shoulda bouoght a big block
Lighten up Al, He's now a member of the B1-aires Boys Club. Pint Size edition..
Chris..
[Re: Chris'sBarracuda]
#1369574
01/15/13 09:54 AM
01/15/13 09:54 AM
Posts: 13,237 aZLiViN
J_BODY
aZLiViN
Chris..
...you can take the boy out of the Stage VI's......but you can't take the Stage VI's out of the boy!
So what was the deal with those Brodix heads? I know they were spendy, but I'm sure the castings are good. Was the potential there?
[Re: greendart408]
#1369576
01/15/13 11:27 AM
01/15/13 11:27 AM
Triple Threat
Renton Washington
J, correct. Very expensive, very good casting from a quality perspective. Never caught on due to cost, need for aftermarket equipment and poor port layout. I haven't seen any other small block MC engines out there. Ryan got pretty good numbers from a set, you can check flow numbers and more on his site.
Ryan, 2.15/1.60 and like .050 long from what Brodix supplied. I'd have to check my notes. Combustion chamber is 65.2cc, and intake port was never measured. Brodix claims 240+ as cast so they're obviously bigger than that, but suffer from the 59 degree push rod limitations.
