Dash Frame Paint: Semi gloss or flat black? 69 B-body #1366201
01/08/13 12:53 AM
01/08/13 12:53 AM
Arizona
69rrgrabber Offline OP
Arizona
Greetings!
I'm about to paint the dash frame for the 69 Charger this weekend but am not sure on the shade of black. It looked flat black but in some hidden areas seemed like satin black. Any insight?
I have a 15% gloss satin black that I was going to use on the tail panel in place of Organsol, does that sound about right?
Many thanks,
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: 69rrgrabber] #1366202
01/08/13 02:32 AM
01/08/13 02:32 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
From a spray can, Rustoleum textured black is very close. It has a very fine texture like original.
From a gun I've heard of using application techniques to get that fine texture finish. Maybe someone with experiance at that will chime in.
I've seen stuff people have shot from a gun look not right. Whereas its pretty hard to screw up the Rustoleum textured. The Rustoleum texture is above average for spray can durable, but real paint from a gun should be tougher.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: autoxcuda] #1366203
01/08/13 10:27 AM
01/08/13 10:27 AM
SE Pa.
LimeliteAero Offline
SE Pa.
If youre not going to use the correct suede finish paint be very careful with the amout of gloss you use. The sun glare is awful with any amount of gloss paint used on top of the dash frame. DHMHIK!
Do yourself a favor and call Instrument Specialties and get the correct paint.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: LimeliteAero] #1366204
01/08/13 01:26 PM
01/08/13 01:26 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I made that mistake. Had to take the dash back out and respray it with a satin clear.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: LimeliteAero] #1366205
01/08/13 07:05 PM
01/08/13 07:05 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I had to have a color match done for my Demons dash so I could use acrylic enamel. No recipe other than laquer at $80/pint.
Mixer added "flattener" to get to the "suede" gloss level and it came out great.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: nomore65BelvJim] #1366206
01/08/13 09:08 PM
01/08/13 09:08 PM
Arizona
Arizona
Great advice! I didn't think about glare, what a mess having to take the dash back out! I'll do a test run on some cardboard and check in the sun before spraying the dash.
CAC
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: 69rrgrabber] #1366207
01/08/13 11:25 PM
01/08/13 11:25 PM
SE Pa.
SE Pa.
You probably wont get the same glare effect from the cardboard, The glare comes from the sun hitting the dash and reflecting up into the windshield and back into your face.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: LimeliteAero] #1366208
01/09/13 12:03 AM
01/09/13 12:03 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Get the correct suede... this is something you only want to do once... IMO...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: LimeliteAero] #1366209
01/09/13 12:06 AM
01/09/13 12:06 AM
I agree. The cardboard will absorb the paint instead of letting it dry like it should. I would test out on a spare piece of metal.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: 69rrgrabber] #1366210
01/09/13 12:09 AM
01/09/13 12:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I had mine Powdercoated, I've sprayed plenty of the Suede, got two quarts of it at my shop.. The powdercoat is a very good match...
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: 1_WILD_RT] #1366211
01/09/13 11:50 AM
01/09/13 11:50 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Be careful because flattening agent is usually white and can give a gray tint to the black. Spray bomb stuff is not really tough enough for a dash, in my opinion. 2 part out of a gun would be much more resistant to accidents. DAMHIK
Master, again and still
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: DaveRS23] #1366212
01/10/13 10:39 PM
01/10/13 10:39 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
On a 69 Roadrunner I did last year I got the original formula in laquer for the dash. It came out great. It was kinda pricey though.
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: 1_WILD_RT] #1366213
01/11/13 03:21 AM
01/11/13 03:21 AM
Oakley CA
69charger440_6pa Offline
Oakley CA
great idea and looks very nice.
Do you recall exactly what the color was called that you used?
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Dash Frame Paint: Semi gloss or flat black? 69 B-body [Re: Mopargnome] #1366214
01/11/13 10:55 AM
01/11/13 10:55 AM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
About $90 a pint if I recall.... but looks perfect! It sprays really nice as well... used on steering coulmn also.
