Which Front Anti-Sway bar kit? #1365006
01/06/13 01:04 AM
01/06/13 01:04 AM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Planning on a major front end rebuild on my 1969 Plymouth B-body.
Doing a disc conversion at the same time.
Car does not have a bar now and just want to make it feel a little more secure at higher speeds when I get it there. Mainly a cruiser.
Who sells the most economical front bar for these B-Bodys? Any issue with the discs?
Plaz
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365007
01/06/13 01:05 AM
01/06/13 01:05 AM
Central TX
roe Offline
roe  Offline
Central TX
I got mine from a factory car for a sweet deal, maybe you can find a setup like that. Made a huge difference when cornering.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Which Front Anti-Sway bar kit? [Re: roe] #1365008
01/06/13 01:10 AM
01/06/13 01:10 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Check Firm Feel, they have kits for what your doing. I went with SSBC all the way round on the brakes and stock suspension up front. They also make a very nice rear swaybar setup, I'll be putting that back in after the car returns.
Re: Which Front Anti-Sway bar kit? [Re: roe] #1365009
01/06/13 01:10 AM
01/06/13 01:10 AM
plazomat Offline OP
plazomat  Offline OP
Did you mean a used bar? Like a Roadrunner of the same vintage?
I guess I can look around for that - didn't give it much thought.
PLAZ
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365010
01/06/13 01:55 AM
01/06/13 01:55 AM
Central TX
roe Offline
roe  Offline
Central TX
Yep, a used setup was great for me. Cheap, and I knew it would bolt in without needing mods. And was a very nice improvement in handling
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365011
01/06/13 04:13 AM
01/06/13 04:13 AM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365012
01/06/13 09:11 AM
01/06/13 09:11 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I bought a K frame from a 69 GTX with a sway bar attatched. The mounts have to be split to remove it. I still have it and would sell cheap. (PM me) I used Firm Feel, best bar I have ever installed
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365013
01/06/13 01:20 PM
01/06/13 01:20 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Economical? May not be a factory bar unless you find someone who really wants to ditch it. I've seen lots of those for sale for more than they are worth because so many feel they are original, therefore valuable. Plus they are not real big, 7/8 or 15/16 max.
The best value would be a solid bar in 1 1/8 diameter. With careful shopping, you should be able to pick up a used one for under a $100. Even if you have to pick one up new, you can get them for around $150.
Re: Which Front Anti-Sway bar kit? [Re: TC@HP2] #1365014
01/06/13 02:31 PM
01/06/13 02:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Which Front Anti-Sway bar kit? [Re: 1_WILD_RT] #1365015
01/31/13 11:27 PM
01/31/13 11:27 PM
plazomat Offline OP
plazomat  Offline OP
Pretty much decided on Addco front and rear bars for this car, hard to beat less than $250 for both bars shipped to my FLA address.
Apparently the guys there say they have improved there hardware kits...I guess we will see.
Since I am doing a disk converstion at the same time, will I need to mount calipers to rear?
I already have 73 Ebody pin calipers ready to bolt up, can I rear mount those or do I need to replace?
Plaz
Re: Which Front Anti-Sway bar kit? [Re: plazomat] #1365016
02/01/13 12:44 AM
02/01/13 12:44 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I'd wait and see where the sway bar links land on the lower control arm before mounting the brakes. The brake hose routing will be much easier if you front mount them like they are supposed to be. Look at the bottom of your k frame, and see if it has notches in the bottom so the sway bar will pass thru the k frame like a 70 Roadrunner or any E body. If it does, use a sway bar like that and front mount you calipers with no problems. You may get lucky, as some later 69 k frames had 70 bottoms on them from the factory. Good luck.
Re: Which Front Anti-Sway bar kit? [Re: JDMopar] #1365017
02/01/13 12:56 AM
02/01/13 12:56 AM
plazomat Offline OP
plazomat  Offline OP
I think all bars listed for 1969 B go under the K member, who makes one that goes through it? or would that be a '70 piece?
Plaz
