Manual to Power Brakes #1363464
01/03/13 12:20 AM
01/03/13 12:20 AM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
My 71' Roadrunner originally came with all drum manual brakes. I already have A-body spindles and can do the disc swap easily.
I work at O'Reillys and can actually get a power brake booster and master cylinder together for my car. My question is are there any other parts I would need to do the swap? IE like is the brake linkages the same lengths between both setups?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Manual to Power Brakes [Re: CurYellowBird] #1363465
01/03/13 08:32 AM
01/03/13 08:32 AM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
I did the swap on my 72 RR and the only surprise was the bracket that is mounted behind the dash as it has two studs that interfere with the mounting of the power brake booster to firewall. Dont forget about proportioning valve and most of the brake lines.
