My 71' Roadrunner originally came with all drum manual brakes. I already have A-body spindles and can do the disc swap easily.
I work at O'Reillys and can actually get a power brake booster and master cylinder together for my car. My question is are there any other parts I would need to do the swap? IE like is the brake linkages the same lengths between both setups?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
