If you had to run a cast iron intake 440, what to use?
#1363402
01/02/13 11:29 PM
01/02/13 11:29 PM
Posts: 33 Terre Haute, Indiana
bgilbert
Is there a factory cast iron intake manifold for a 440 that is more desirable than others? Let's say if you were running in a truck pulling class that essentially allows unlimited cubic inch, but limits you to cast iron manifolds. All I have right now are truck manifolds to work with (port). Just wondering if there is a more desirable OEM single 4BBL cast iron intake to be looking for. Thank you.
85 D350 crew with 90 Cummins 6BT Getrag 3.07
93 D350 single cab Getrag 3.54
74 W300 360 4 speed 4.88 70 front/rear
Re: If you had to run a cast iron intake 440, what to use?
[Re: Handygun]
#1363407
01/03/13 12:00 AM
01/03/13 12:00 AM
bgilbert
the 70-71 6bbl would make the most power but I assume your talking single 4's. What I dont know is why the baddest man in downtown TerreHaute with a rotary pump is talkin bout gas engines?
I've turned a corner! It's a whole new world for me with gas engines. I'm very confident with a 1st gen Cummins and rotary pumps, but clueless when it comes to gas engines .
So I need to start looking for a 72 T-Q intake? Is that a Thermo Quad? I plan to run a Holley carb if that matters .
[Re: bgilbert]
#1363408
01/03/13 12:11 AM
01/03/13 12:11 AM
Posts: 5,160 Texas
dannysbee
Texas
I think the biggest advantage of the thermoquad intake is the larger plenum. I think other than that they all would be pretty close.
Getting old just means you were smarter than some and luckier than others.
[Re: RUNCHARGER]
#1363410
01/03/13 12:25 AM
01/03/13 12:25 AM
bgilbert
Yep: I assume the adapter is legal to run a squarebore Holley?
Sheldon
Yes. They are weird rules. From what I understand, it's essentially unlimited cubic inch, OEM appearing, engine must have come in a 1 ton or smaller pickup, 35" dot tires, and cast iron heads, and manifolds.
[Re: RUNCHARGER]
#1363411
01/03/13 12:26 AM
01/03/13 12:26 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
When Bill aquires this intake, should he machine out the center part and make it a "single plane" manifold, or just port and smooth out the internals.
Yes, he is just allowed a 4 barrel intake, or else we would be six packing it.
Anything else you want me to disclose about this build via the internet? Or do you want to keep it top secret, Bill?
Michael(the other first gen guy in the room)
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: RUNCHARGER]
#1363415
01/03/13 04:04 AM
01/03/13 04:04 AM
DaytonaTurbo
Manitoba, Canada
Think plenum volume though.
Sheldon
Yes but I cringe at the idea of necking those big holley primaries down to the itty bitty thermoquad primary size.
[Re: scatpacktom]
#1363421
01/03/13 11:58 AM
01/03/13 11:58 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A few years back an aluminum intake painted blue to match the rest of the engine worked fine for me.Believe me unless there is a Mopar tech or another Mopar racer in your class no one will ever notice.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
