Page 1 of 3 1 2 3
If you had to run a cast iron intake 440, what to use? #1363402
01/02/13 11:29 PM
01/02/13 11:29 PM
Terre Haute, Indiana
bgilbert Offline OP
bgilbert  Offline OP
Is there a factory cast iron intake manifold for a 440 that is more desirable than others? Let's say if you were running in a truck pulling class that essentially allows unlimited cubic inch, but limits you to cast iron manifolds. All I have right now are truck manifolds to work with (port). Just wondering if there is a more desirable OEM single 4BBL cast iron intake to be looking for. Thank you.
85 D350 crew with 90 Cummins 6BT Getrag 3.07 93 D350 single cab Getrag 3.54 74 W300 360 4 speed 4.88 70 front/rear
Re: If you had to run a cast iron intake 440, what to use? [Re: bgilbert] #1363403
01/02/13 11:43 PM
01/02/13 11:43 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think the 72 TQ manifold would flow the best.
Sheldon
Re: If you had to run a cast iron intake 440, what to use? [Re: RUNCHARGER] #1363404
01/02/13 11:49 PM
01/02/13 11:49 PM
gregsdart Offline
gregsdart  Offline
Sheldon
I hope the TQ intakes are good, I just got one for a ratrod build.
Re: If you had to run a cast iron intake 440, what to use? [Re: gregsdart] #1363405
01/02/13 11:52 PM
01/02/13 11:52 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have run 11.96 with a T-Q intake and an 800 D-P spreadbore Holley
Gus
64 Plymouth Savoy
Dana 60
Re: If you had to run a cast iron intake 440, what to use? [Re: RUNCHARGER] #1363406
01/02/13 11:52 PM
01/02/13 11:52 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
the 70-71 6bbl would make the most power but I assume your talking single 4's. What I dont know is why the baddest man in downtown TerreHaute with a rotary pump is talkin bout gas engines?
Re: If you had to run a cast iron intake 440, what to use? [Re: Handygun] #1363407
01/03/13 12:00 AM
01/03/13 12:00 AM
bgilbert Offline OP
bgilbert  Offline OP
I've turned a corner! It's a whole new world for me with gas engines. I'm very confident with a 1st gen Cummins and rotary pumps, but clueless when it comes to gas engines .
So I need to start looking for a 72 T-Q intake? Is that a Thermo Quad? I plan to run a Holley carb if that matters .
Re: If you had to run a cast iron intake 440, what to use? [Re: bgilbert] #1363408
01/03/13 12:11 AM
01/03/13 12:11 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I think the biggest advantage of the thermoquad intake is the larger plenum. I think other than that they all would be pretty close.
Getting old just means you were smarter than some and luckier than others.
Re: If you had to run a cast iron intake 440, what to use? [Re: dannysbee] #1363409
01/03/13 12:21 AM
01/03/13 12:21 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Yep: I assume the adapter is legal to run a squarebore Holley?
Sheldon
Re: If you had to run a cast iron intake 440, what to use? [Re: RUNCHARGER] #1363410
01/03/13 12:25 AM
01/03/13 12:25 AM
bgilbert Offline OP
bgilbert  Offline OP
Sheldon
Yes. They are weird rules. From what I understand, it's essentially unlimited cubic inch, OEM appearing, engine must have come in a 1 ton or smaller pickup, 35" dot tires, and cast iron heads, and manifolds.
Re: If you had to run a cast iron intake 440, what to use? [Re: RUNCHARGER] #1363411
01/03/13 12:26 AM
01/03/13 12:26 AM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
When Bill aquires this intake, should he machine out the center part and make it a "single plane" manifold, or just port and smooth out the internals.
Yes, he is just allowed a 4 barrel intake, or else we would be six packing it.
Anything else you want me to disclose about this build via the internet? Or do you want to keep it top secret, Bill?
Michael(the other first gen guy in the room)
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: If you had to run a cast iron intake 440, what to use? [Re: MMiller] #1363412
01/03/13 12:31 AM
01/03/13 12:31 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're not going to be running a thermoquad, quadrajet or a spreadbore holley, then I think you're probably no better off than with one of the factory square bore intakes. I don't think those adapters are any good for making power.
Re: If you had to run a cast iron intake 440, what to use? [Re: DaytonaTurbo] #1363413
01/03/13 01:09 AM
01/03/13 01:09 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Think plenum volume though.
Sheldon
Re: If you had to run a cast iron intake 440, what to use? [Re: bgilbert] #1363414
01/03/13 01:38 AM
01/03/13 01:38 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I doubt that there is much difference in any of them. Back in the eighties i ran a spreadbore intake with a 3/4 inch adapter and a 750 vac carb. I removed quite a bit of iron out of the plenum, left the divider at about half it original height. I ran it for a while until i swapped it for a square bore intake. A friend wanted to run a thermoquad on his car so we traded intakes. I took a fair amount of material out of the squarebore intake but left the divider at full height. And had a 2 inch spacer on top. This was on a mild 440, high 13 sec 71 RR. Car ran virtually the same ET and MPH with either intake. Not very scientific i know. May not be a very valid comparison,considering the difference in spacer heights, etc.
Re: If you had to run a cast iron intake 440, what to use? [Re: RUNCHARGER] #1363415
01/03/13 04:04 AM
01/03/13 04:04 AM
Manitoba, Canada
Manitoba, Canada
Sheldon
Yes but I cringe at the idea of necking those big holley primaries down to the itty bitty thermoquad primary size.
Re: If you had to run a cast iron intake 440, what to use? [Re: DaytonaTurbo] #1363416
01/03/13 07:54 AM
01/03/13 07:54 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Didn't Indy make a cast iron intake at one time? Dave
Re: If you had to run a cast iron intake 440, what to use? [Re: bgilbert] #1363417
01/03/13 09:03 AM
01/03/13 09:03 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you can modify the plenum, use spacers, and any carb, all of the hp intakes would be equal.
Re: If you had to run a cast iron intake 440, what to use? [Re: bgilbert] #1363418
01/03/13 09:48 AM
01/03/13 09:48 AM
florence,sc
mtolley Offline
mtolley  Offline
florence,sc
Sheldon
i would be asking questions about this. i take this part as meaning cast iron exhaust manifolds. most rule books will say intake if thats whats meant
Re: If you had to run a cast iron intake 440, what to use? [Re: mtolley] #1363419
01/03/13 10:05 AM
01/03/13 10:05 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The 440 didn't get the TQ until 1973. All the 4bbl big block intakes suck. They have poor transitions and sharp edges. In FAST a few have made some big smoke with them but only after a MAJOR reworking of the iron. The rest have chucked them in favor of a six pack. I would think the TQ manifold would be the best junk to start with. Be easy on the cubes it will only make the manifold a bigger restriction.
Re: If you had to run a cast iron intake 440, what to use? [Re: scatpacktom] #1363420
01/03/13 10:08 AM
01/03/13 10:08 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Maybe use a six pack intake without one of the outboards and a 500 cfm center carb?
Re: If you had to run a cast iron intake 440, what to use? [Re: scatpacktom] #1363421
01/03/13 11:58 AM
01/03/13 11:58 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
A few years back an aluminum intake painted blue to match the rest of the engine worked fine for me.Believe me unless there is a Mopar tech or another Mopar racer in your class no one will ever notice.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Page 1 of 3 1 2 3
