Re: 1965 B-Body Front Suspension Drawing
[Re: PHJ426]
#1363355
01/03/13 12:33 AM
01/03/13 12:33 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
how much of that info might have been supplied with a frame alignment machine for the purpose of unibody alignment?
That probably shows something but not all the measurements your looking for.
Not much info. Those charts don't define the suspension pick up points.
I assume the O.P. wants to plot the suspension geometries on paper or proabably a computer program. . . . Break out your rulers, calipers, plumb bobs, height indicators, etc, etc..! Actually you should check the circle track parts industry. They may sell some tools to do this type of measuring. I helped a guy do it to chassis years ago, but don't remember the brands or names of the equiptment.
It's much harder to do to a stock bare chassis compared to a race car bare chassis.
[Re: 410mopar]
#1363356
01/03/13 02:07 AM
01/03/13 02:07 AM
autoxcuda
So Cal
[Re: 410mopar]
#1363357
01/03/13 01:23 PM
01/03/13 01:23 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Stuff a 69 k frame under the car if you're concerned about handling. It will move the engine back and down but the suspension geometry stays the same. As a bonus you will get the improved idler arm mount with top and bottom brackets. The 65 uses a cantilevered bottom bracket without any support on top. It just kinda flaps around under stress.
[Re: feets]
#1363358
01/05/13 12:33 PM
01/05/13 12:33 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
The Firm Feel ball bearing idler kit mitigates this to a considerable extent.
Rick
