Are these spindles any good? #1362939
01/01/13 09:39 PM
01/01/13 09:39 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
I bought these years ago, they are E-body pieces and I want to install them on my 69 B-Body for my disc brake conversion.
I am a little concerned with the rust on bearing surfaces.
Looks like surface only should I be worried or just clean them up and go? What is the best way to clean them?
Or should I just call em a loss and get new ones?
Plaz
Re: Are these spindles any good? [Re: plazomat] #1362940
01/01/13 09:49 PM
01/01/13 09:49 PM
plazomat Offline OP
plazomat  Offline OP
OK now with a link to the picture
https://www.dropbox.com/s/hd8fzfkdt3q92q8/Spindles.jpg
Plaz
Re: Are these spindles any good? [Re: plazomat] #1362941
01/01/13 09:54 PM
01/01/13 09:54 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Pic didn't show so I'm not sure, see if it cleans up and see how well the bearings fit. Went thru this a few years ago, as long as there is no pitting you should be fine.
-Daty
Re: Are these spindles any good? [Re: plazomat] #1362942
01/01/13 09:55 PM
01/01/13 09:55 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
try some fine grit emery paper and varsol. I think it will clean up ok.
Re: Are these spindles any good? [Re: brads70] #1362943
01/02/13 12:36 AM
01/02/13 12:36 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Those are fine, the bearings ride on races anyway.
Re: Are these spindles any good? [Re: 469runner] #1362944
01/02/13 01:11 AM
01/02/13 01:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the only critical point is the area where the inner wheel seal rides....
I am truckless..
Re: Are these spindles any good? [Re: 340SHORTY] #1362945
01/02/13 10:28 AM
01/02/13 10:28 AM
plazomat Offline OP
plazomat  Offline OP
Thanks guys.
I will clean them up with Evapo Rust and see if they are pitted.
What are the specs for where the bearings/races ride on?
PLAZ
