Re: Anyone Familar With The 371 - Late Model Race Engine
[Re: Sb Valiant]
#1362823
01/01/13 07:40 PM
01/01/13 07:40 PM
Posts: 3,396 Pa
Hot 340
Pa
Just wondering if anyone ever ran this combination or heard of anyone running it. I thought I would post about it because It almost sounds to good to be true but sounds very simple and easy and I am tempted to try it sometime!
Alot of people have ran .060 over 360's.. thats all it really is.
[Re: tvt59]
#1362826
01/01/13 10:27 PM
01/01/13 10:27 PM
Posts: 5,894 Florida
Locomotion
Tom Hoover from Chrysler made that combo for his notchback Cuda and it was featured in the Feb. 1976 issue of Popular Hot Rodding. The undersides of the low compression 340 pistons had to be clearanced for the 360 counterweights as well. I have the issue buried somewhere here at home. It was very inspirational in my early years. But that was before the 360's had a variety of pistons to choose from. Popular Hot Rodding Feb. 1976Like the 355 Nascar/circle track engines from the '70's, it's a cool combo. But there are a lot of other, less expensive combos to make HP today.
[Re: Locomotion]
#1362827
01/01/13 11:37 PM
01/01/13 11:37 PM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
Built many low buck .060 over 360's = 371 hard to beat for the money invested. split one cylinder on one after years of abuse at 7,000 plus rpm many times would not hesitate to build one again stock rods, crank, kb pistons, sonic check the block if you can older blocks seem the best. all depends on your budget many people set their sights so high the project never gets done and the parts end up for sale never used. they run good for the money and 360 blocks are common....
ACCELERATION SPECIALIST
[Re: Cab_Burge]
#1362830
01/03/13 10:01 PM
01/03/13 10:01 PM
Posts: 108 so ca
mikesiron
so ca
Yep that what I do. You need the crank turned anyway so we turn it to 340 main size. It seems to have cooler oil temps also because of the smaller main size.
[Re: tvt59]
#1362832
01/04/13 09:02 PM
01/04/13 09:02 PM
Posts: 1,532 off the grid
340B5
off the grid
I've run 10.95 with my 374 inch SB. (4.08x3.58) Home ported J's and a .520 lift cam. That was on the 5th pass on a fresh engine and on the rev limiter @1000' Proper gearing should lead to better ET's.
Yeah, it's got a smallblock.
