Dash illumination lights 70 340 duster #1362393
12/31/12 06:03 PM
12/31/12 06:03 PM
ohio
Monstercookies Offline OP
ohio
Hello All!
I'm new to this forum but, not new to them in general.
I am restoring a 1970 340 duster. I have went through all the wiring in the car completely. But, one big problem I have ran into is that I can not for the life of me get the cluster illumination lights to come on with the head lights or parking lights. everything from the dome light, heater, radio, turn signinals, e-brake light, high beam light everything works. I have checked the bulbs and made sure they are making the connections or the board and are not blown. just wondering if there's a ground i am missing or something to get these bulbs to work. anything helps.
Thanks.
Shayne
Re: Dash illumination lights 70 340 duster [Re: Monstercookies] #1362394
12/31/12 06:19 PM
12/31/12 06:19 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
You do have the lower mounting screws in the dash bezel don't you? They are what grounds the dash to the dash frame. Also check your dimmer switch terminals for voltage. One terminal is for your dash lights.
Re: Dash illumination lights 70 340 duster [Re: Monstercookies] #1362395
12/31/12 06:19 PM
12/31/12 06:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The dash grounds where it seats by the screws holding it in so be sure they are tight and not insulated with paint. The dash dimmer part of the headlight switch could be bad.
Re: Dash illumination lights 70 340 duster [Re: stumpy] #1362396
12/31/12 06:42 PM
12/31/12 06:42 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
with Stumpy. I just had the same problem on my 71 Duster, tuned out to be the headlight switch. They are about $10 from autozone, napa, etc.
Re: Dash illumination lights 70 340 duster [Re: NV69B7RR] #1362397
12/31/12 07:26 PM
12/31/12 07:26 PM
ohio
ohio
sweet thats great news im gonna try that and hope it works ill keep you guys posted.
Re: Dash illumination lights 70 340 duster [Re: Monstercookies] #1362398
12/31/12 08:49 PM
12/31/12 08:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I hope you made sure the "inst" fuse is good, and has power when headlight switch is on.
Re: Dash illumination lights 70 340 duster [Re: buildanother] #1362399
01/01/13 05:04 PM
01/01/13 05:04 PM
ohio
ohio
okay guys I forgot to mention before I had already checked the fuses.
I went and got a new switch for the lights and it worked. thanks for the help guys really mad this headache a lot easier and that finished all my wiring so now its just got to go for paint! thanks again
