Cutting Off 1/4's 66 Charger #1361598
12/30/12 03:41 PM
12/30/12 03:41 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Im looking for suggestions on how to and where to cut off 1/4's on a 1st gen Charger. My plan is to use a saws-all. Any other thoughts or ideas.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361599
12/30/12 03:45 PM
12/30/12 03:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Drill the spot welds on the 1/4 skins
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361600
12/30/12 03:47 PM
12/30/12 03:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Save as much as you can. Patching in an area that you already had sorta sucks.
I'd drill out the welds at the top and chisel the panels apart at the pinch weld. Same goes for the rocker area and door jamb.
Re: Cutting Off 1/4's 66 Charger [Re: Kern Dog] #1361601
12/30/12 05:21 PM
12/30/12 05:21 PM
Ashville, Manitoba, Canada
superbeeman69 Offline
super street
super street
Is that the one your fixing or restoring? If that's a parts car, cut a few inches from the trunk gutter, through the trunk floor inside of the rail. Near the door, go into the rocker past the factory seam and match to the saw mark through the floor. Up top, take above the factory roof to 1/4 seam. Find it on yours first (seam is leaded up, it will be darker than steel when you sand it down) so you know where to cut. When you go to put it on your car, you will need to drill out all the spot welds as stated, take off all the left over trimmings and off she comes. If your having trouble separating the 1/4 from wheelhouse, add some heat from a butane torch from the inside wheewell. It lets that factory seam sealer go gooey and let the panel go without distorting or messing up the outer panel.
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361602
12/30/12 05:57 PM
12/30/12 05:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why are you cutting that off? looks decent to me. If you do cut it, do a nice clean job where the molding goes, then you can hide any wleds w/ the trim
Coming soon!!!!
Re: Cutting Off 1/4's 66 Charger [Re: Mr.Yuck] #1361603
12/30/12 09:37 PM
12/30/12 09:37 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks for the ideas, this car was going to be cut up for scrap but this guy called me and asked if I wanted the 1/4s Passenger side was the best hardly any rust popping through. the drivers side was the worst. I got both and a tinted rear glass and some misc trim including the j trim on the quarters. I can remove all the spot welds and clean up all the edges now that there at the house
1972 Corvette
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361604
12/30/12 09:40 PM
12/30/12 09:40 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Another shot
1972 Corvette
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361605
12/30/12 10:10 PM
12/30/12 10:10 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I can use side glass, a trunk lid/trim, and any window parts that might be available.
Re: Cutting Off 1/4's 66 Charger [Re: Jeremiah] #1361606
12/30/12 10:17 PM
12/30/12 10:17 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Most of that stuff was already gone. Some one had cut the structure inside of the 1/4's to get the rear window hardware and glass out.
1972 Corvette
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361607
12/30/12 10:38 PM
12/30/12 10:38 PM
Orlando, FL
ChargerKnight66 Offline
Orlando, FL
Can you get the VIN and post it on the Charger registry?
Regards,
Re: Cutting Off 1/4's 66 Charger [Re: 19cuda73] #1361608
12/31/12 01:27 AM
12/31/12 01:27 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Ouch! Merry Christmas and Happy New Year Dennis!
Re: Cutting Off 1/4's 66 Charger [Re: Jeremiah] #1361609
12/31/12 03:16 AM
12/31/12 03:16 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Happy New Year to you and all of our Moparts Friends.
1972 Corvette
Re: Cutting Off 1/4's 66 Charger [Re: Jeremiah] #1361610
12/31/12 08:29 AM
12/31/12 08:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Jeremiha too bad you are so far away.My kid has just about all you need.The deck lid is sitting by my 65 and he has all the glass and lots of the assembleys.Rocky
Chrysler Firepower
Re: Cutting Off 1/4's 66 Charger [Re: therocks] #1361611
12/31/12 02:57 PM
12/31/12 02:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Road trip?
