Re: Cutting Off 1/4's 66 Charger
[Re: Kern Dog]
#1361601
12/30/12 05:21 PM
12/30/12 05:21 PM
Posts: 454 Ashville, Manitoba, Canada
superbeeman69
super street
super street
Is that the one your fixing or restoring? If that's a parts car, cut a few inches from the trunk gutter, through the trunk floor inside of the rail. Near the door, go into the rocker past the factory seam and match to the saw mark through the floor. Up top, take above the factory roof to 1/4 seam. Find it on yours first (seam is leaded up, it will be darker than steel when you sand it down) so you know where to cut. When you go to put it on your car, you will need to drill out all the spot welds as stated, take off all the left over trimmings and off she comes. If your having trouble separating the 1/4 from wheelhouse, add some heat from a butane torch from the inside wheewell. It lets that factory seam sealer go gooey and let the panel go without distorting or messing up the outer panel.
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
[Re: Jeremiah]
#1361606
12/30/12 10:17 PM
12/30/12 10:17 PM
Posts: 1,300 Washington
19cuda73
Washington
Most of that stuff was already gone. Some one had cut the structure inside of the 1/4's to get the rear window hardware and glass out.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: 19cuda73]
#1361607
12/30/12 10:38 PM
12/30/12 10:38 PM
Posts: 25 Orlando, FL
ChargerKnight66
Orlando, FL
Can you get the VIN and post it on the Charger registry? Regards,
[Re: 19cuda73]
#1361608
12/31/12 01:27 AM
12/31/12 01:27 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Ouch! Merry Christmas and Happy New Year Dennis!
[Re: Jeremiah]
#1361610
12/31/12 08:29 AM
12/31/12 08:29 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Jeremiha too bad you are so far away.My kid has just about all you need.The deck lid is sitting by my 65 and he has all the glass and lots of the assembleys.Rocky
Chrysler Firepower
