11 X 2.5" Rear Brake Picture request #1361100
12/29/12 08:19 PM
12/29/12 08:19 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
Anybody have a nice clear picture of their 11 X 2.5" rear brakes right after they rebuilt them and right before they put the drum back on? Yes, I know there is a line drawing in the tech archive. I would just like a clear color picture.
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361101
12/29/12 09:47 PM
12/29/12 09:47 PM
BDW Offline
BDW  Offline
Re: 11 X 2.5" Rear Brake Picture request [Re: BDW] #1361102
12/29/12 10:37 PM
12/29/12 10:37 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Thank you!
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361103
12/30/12 12:03 AM
12/30/12 12:03 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Drat, the kit I got is missing the big spring across the bottom. I think I've still got the originals.
And the cable that goes from the top down to the starwheel is the wrong length by at least an inch.
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361104
12/30/12 08:45 AM
12/30/12 08:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The spring comes in the hardware kit not in the adjuster kit.Also the ones with no self adjusters are different than that pic.My 69 rear thats in my 65 has no self adjusters.Rocky
Chrysler Firepower
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361105
12/30/12 03:59 PM
12/30/12 03:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pics above show the '69-later setup with the spring-loaded adjuster cable and the bottom spring spans the two shoes. A mousetrap spring returns the adjuster lever.
The '68 and earlier cable isn't spring-loaded and the bottom spring spans from the front shoe to the adjuster lever.
Re: 11 X 2.5" Rear Brake Picture request [Re: John_Kunkel] #1361106
12/30/12 08:32 PM
12/30/12 08:32 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Thanks for all the info. I ended up ordering two new cables and a spring kit from RockAuto. I'd originally ordered kits for 10" drums.
I'm putting the 11 X 2.5" rear brakes from a '70 Superbee (went disc on it) on my '68 pickup. The truck drums are 11 X 2", so there's about 25% more are on the shoes and the 11 X 2.5" drums are half the price of the 11 X 2" drums.
I really haven't messed with drums much. What all do you lube when you put them together? Just the starwheel?
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361107
12/30/12 10:04 PM
12/30/12 10:04 PM
BDW Offline
BDW  Offline
As a side note, I'm thinking about putting the 11x2 brakes in the 2.5" drums to help with the front / back bias.
I already have 7/8" WCs. I have 11.75's up front with the larger calipers and it's still marginal on lock-up.
Don't want to add an adjustable valve, so the 25% less pad contact should do the trick.
Your situation would probably be worse with the light rear of a truck?
Re: 11 X 2.5" Rear Brake Picture request [Re: BDW] #1361108
12/30/12 11:05 PM
12/30/12 11:05 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I'll watch for that when I start testing it all out. These trucks came with front drums too. I have a Scarebird setup that uses an 11.5" Crown Vic rotor and a GM truck caliper.
Edit: I have a lot of options for pad compounds with the GM caliper.
Re: 11 X 2.5" Rear Brake Picture request [Re: Chilort] #1361109
01/05/13 10:53 PM
01/05/13 10:53 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Thanks again for the photos. They were wildly helpful today.
