Pic of 1969 Hemi distributor please #1360367
12/28/12 10:28 PM
12/28/12 10:28 PM
San Miguel NM
fowler1400 Offline OP
San Miguel NM
Anyone have a pic of a 69 Hemi original distributor please ? I am looking at a dual point with vac advance, no tag, not sure where the cap clips should be in relation to the vac advance ? Also how exactly should it be pointed when in the engine, with the vac advance pointing up to the driver side ? Thanks for your help
Re: Pic of 1969 Hemi distributor please [Re: fowler1400] #1360368
12/28/12 10:58 PM
12/28/12 10:58 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
1969' hemi prestolite dual point
Re: Pic of 1969 Hemi distributor please [Re: fowler1400] #1360369
12/28/12 11:05 PM
12/28/12 11:05 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Installed... []
Re: Pic of 1969 Hemi distributor please [Re: fowler1400] #1360370
12/29/12 02:26 AM
12/29/12 02:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Without a tag it could be anything , first off look at the base that goes into the engine , it should have an o-ring groove , if it doesn't its a 67 or earlier distributor.
How it is lined up in the engine all depends on where you put the wire for cylinder #1 , the distributor itself doesn't know or care as line as the firing order is right and #1 is set at/near the top of the #1 cylinder compression stroke.
Re: Pic of 1969 Hemi distributor please [Re: fowler1400] #1360371
12/29/12 12:07 PM
12/29/12 12:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
One on right is original 69 Hemi 4spd.
