Reman'd Master Cylinder #1358447
12/24/12 02:11 PM
12/24/12 02:11 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I went to the autopart store yesterday and the different in price from new vs. a reman'd master cylinder for a 74 A-body was $131 for the new vs. $25 for the reman'd. Both brands were Fenco. Is there that much of a difference? Have you guys ever used these reman'd units with any success??
Re: Reman'd Master Cylinder [Re: mopowers] #1358448
12/24/12 02:19 PM
12/24/12 02:19 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I don't know that brand but yes I have had good luck with reman's (Cardone).
Re: Reman'd Master Cylinder [Re: MPerry] #1358449
12/24/12 03:41 PM
12/24/12 03:41 PM
Central TX
roe Offline
roe  Offline
Central TX
I have had great results with Cardone remans as well. Have not had one fail yet. Last one was a Cardone booster/master cyl set that I put on my sig car a couple years back. Still going strong.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Reman'd Master Cylinder [Re: mopowers] #1358450
12/24/12 05:53 PM
12/24/12 05:53 PM
I've also had good luck with remans. No way I'd pay 131 for one
Re: Reman'd Master Cylinder [Re: mopowers] #1358451
12/24/12 06:31 PM
12/24/12 06:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, the very most expensive NEW M/C at Rock Auto is only $91. You might want to shop around.
Don't be the exception.
Re: Reman'd Master Cylinder [Re: Supercuda] #1358452
12/24/12 11:26 PM
12/24/12 11:26 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
I never had any luck with a remanned master cylinder. It took 3 for me to get one that still only works halfway decent (Got it at oreillys). I think its a cardone. Sounds like other people have had good results though, so I may just be the odd one out here. I will not buy another remanned unit.
Re: Reman'd Master Cylinder [Re: BEINGmeISaCRIME] #1358453
12/25/12 12:07 AM
12/25/12 12:07 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I've used remans for a lot of years with no problems.
Re: Reman'd Master Cylinder [Re: BEINGmeISaCRIME] #1358454
12/25/12 12:08 AM
12/25/12 12:08 AM
pass christian, ms
69fish Offline
69fish  Offline
pass christian, ms
Went to replace mine a few weeks ago with a Cardone reman, could not get to bench bleed. Got a new one thru Napa for only a few dollars more - I think mine was around $50, but mine was for 67 Dart.
Re: Reman'd Master Cylinder [Re: 69fish] #1358455
12/25/12 12:22 AM
12/25/12 12:22 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
if you do pick up a reman...check the brake line threads before you take it home. i got one all the way in once...just to find enough threads missing wo where it wouldnt tighten up.
Re: Reman'd Master Cylinder [Re: rave_12000] #1358456
12/25/12 01:25 AM
12/25/12 01:25 AM
IN
ahy Offline
ahy  Offline
IN
If you do decide to go new, check around. There is a lot of difference in cost of new at the different parts chains. For some reason, AZ is usually the lowest. I'm running 3 of their MC's with no problems so far ('01 Jeep, '98 Neon, '78 Ford PU).
Re: Reman'd Master Cylinder [Re: ahy] #1358457
12/25/12 02:22 AM
12/25/12 02:22 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I have used a few over the years, most of the time they are fine,..if not, they have more!
the new ones dont always have the original appearance, if that matters to you..
Re: Reman'd Master Cylinder [Re: sthemi] #1358458
12/25/12 05:53 AM
12/25/12 05:53 AM
SE PA
Yellow Fever Offline
SE PA
NEW one at Rockauto is $11.23
1974 DODGE DART 5.9L 360cid V8 : Brake/Wheel Hub : Master Cylinder Wiki Price Core Total
EIS Part # E77018
New Master Cylinder w/FT DISC/RR DRUM,15/16" - w/PWR BRAKES; Sport 360 Engine VIN L [Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty] (Only 13 Remaining)
$11.23 $0.00 $11.23
Re: Reman'd Master Cylinder [Re: 69fish] #1358459
12/25/12 10:10 AM
12/25/12 10:10 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used them at work a lot.We run them on our cars also.In 30 years as a tech I had maybe 2 bad remans.Mostly we used ones from Advanced.My 65s has been on at least 15 years and the kids at least 11 years.No problems.Rocky
Chrysler Firepower
Re: Reman'd Master Cylinder [Re: therocks] #1358460
12/25/12 10:50 AM
12/25/12 10:50 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I'm using a $23 reman from Autozone and it works perfect
Re: Reman'd Master Cylinder [Re: Yellow Fever] #1358461
12/25/12 11:52 AM
12/25/12 11:52 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I always check Rock Auto when I need parts. Sometimes they are a bargain, sometimes not so much. Of course you have to watch the shipping. They don't actually have any parts. They have drop ship agreements with Raybestos, Wagoner, etc., etc.. Of course they have LOTS of parts besides brake stuff. I bought Sherman rocker panels for my '89 Chevy pickup including shipping for half of the price I could find them locally.
Re: Reman'd Master Cylinder [Re: mopowers] #1358462
12/25/12 12:48 PM
12/25/12 12:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually prefer the Fenco new or remanned units over Cardone, or Tru Stop, or Duralast, I've never gotten a bad unit from Fenco in the last few decades, only issues I've ever had with Fenco is availability, because they are a small capacity mfg
Just make sure you have the right application for your intended brake set up, and benchbleed the master properly before installation
mike
Re: Reman'd Master Cylinder [Re: DAYCLONA] #1358463
12/25/12 01:19 PM
12/25/12 01:19 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
most if not all of the cheapie brands all come from the same rebuilders/source/place.
they are just repackaged with different names
on the box.
so one brand is no any better then the other.
fenco, i don't think is a part of that.
most failures come from parts made in india or china..
Re: Reman'd Master Cylinder [Re: Yellow Fever] #1358464
12/25/12 01:27 PM
12/25/12 01:27 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks for the heads up guys! Whats the difference between the power disc/drum vs. the manual disc/drum?? Which one has the 15/16" piston? I'm assuming the manual one?
EIS Part # E77018
$11.23 $0.00 $11.23
Only problem with ordering something like that from Rock auto, is how do they deal with warranties?? I'd rather buy a master from somewhere local in case I have to replace it. Thanks for the heads up though! Who is EIS anyway?
