Thermo-Guard Battery Box #1356118
12/20/12 01:44 AM
12/20/12 01:44 AM
USA
JoesMopar Offline OP
USA
Does this look like the correct battery cover for a '77 A38 Monaco (B) with a 440?
http://www.ebay.com/itm/NOS-Mopar-1976-8...ies&vxp=mtr
Re: Thermo-Guard Battery Box [Re: JoesMopar] #1356119
12/20/12 10:35 AM
12/20/12 10:35 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Yes. They were universal. One size fits all.
Two caveats:
1. They require their own special hold down bracket.
2. The battery has to duplicate the design of the OEM battery in size, terminals, caps, etc to fit properly, not that most aftermarket batteries won't fit. Just not properly.
Re: Thermo-Guard Battery Box [Re: Commando1] #1356120
12/21/12 12:24 AM
12/21/12 12:24 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
For your reference, here's the original from my '77 Cordoba.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Thermo-Guard Battery Box [Re: JoesMopar] #1356121
12/23/12 02:33 AM
12/23/12 02:33 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
The ones on my M body police cars are very similar to that one, but they have a bit of a "snorkel" at the front of the box to guide air flow from the front of the car around the battery. The "snorkel" like thingy pushes up against the rad support. Sorry, at work now and don't have a pic on this computer, but lmk if you'd like one.
Facts are stubborn things.
Re: Thermo-Guard Battery Box [Re: larrymopar360] #1356122
12/23/12 10:51 AM
12/23/12 10:51 AM
Commando1 Offline
Commando1  Offline
I wouldn't mind seeing it just for my own reference.
Thanks.
Re: Thermo-Guard Battery Box [Re: Commando1] #1356123
12/23/12 11:47 AM
12/23/12 11:47 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
Here is a picture of mine in the 5th Avenue.
Eric
Re: Thermo-Guard Battery Box [Re: Erics5th] #1356124
12/23/12 12:16 PM
12/23/12 12:16 PM
USA
USA
Thanks guys. Do any of you have a picture of the hold down for the older style box and an idea of an aftermarket battery that does fit it without cutting/modifying?
Re: Thermo-Guard Battery Box [Re: Erics5th] #1356125
12/23/12 12:36 PM
12/23/12 12:36 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Eric's picture is the police one that came with my cars. Thanks Eric. I have huge battery from Walmart in all mine and the thermoguard fits over them. You can see all the extra room in Eric's pic. I don't think you will have any trouble fitting a battery. If it fits in the battery tray, the guard will fit over it. The hold downs that I used on mine is also from Walmart. The only one they had, hanging next to the batteries. It is plenty long.
Re: Thermo-Guard Battery Box [Re: larrymopar360] #1356126
12/23/12 06:54 PM
12/23/12 06:54 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Here's my original hold down.
The end on the right in the photo above faces forward in the car, and bolts through a hole in the core support. The hook on the other end hooks through a hole in the tray. The "arch" at the top protrudes slightly through a slot in the top of the guard.
DynoDave
Member # 12304
Re: Thermo-Guard Battery Box [Re: DynoDave] #1356127
12/23/12 09:03 PM
12/23/12 09:03 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
The 1978 shop manual shows the hold-down for a B body (whatever that is in 1978) has the windshield washer reservoir built into it!
Re: Thermo-Guard Battery Box [Re: 1970A13] #1356128
12/23/12 09:19 PM
12/23/12 09:19 PM
USA
USA
Thanks for the pics guys.
My car has the windshield washer res. on the passenger side fender towards the front.
Re: Thermo-Guard Battery Box [Re: 1970A13] #1356129
12/24/12 11:50 AM
12/24/12 11:50 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Correct. Starting in 1978, for the B bodies anyway, the washer bottle was integrated into the Thermogard. These can be used on the earlier cars, but you have to move the pump wiring harness from the right fender to the left. I have one of those that I'll be running on my '77.
DynoDave
Member # 12304
