I Need Opinions Please!! #1355596
12/19/12 05:32 PM
12/19/12 05:32 PM
western PA
Sb Valiant Offline OP
western PA
I know alot of people say go to a dyno but since I don't have time nor money just have to go off of what works for everyone else. I've seen some people post about the 590 mopar cam. My friend had this one cam that was like in the 570's that was a mopar cam and used to run his 383 for years at 7900 rpm and ran in the mid 10's. I was just wondering if these cams are really suitable for 7500-7900 rpm area under the right combo? Also was wondering maybe instead of going like a big 630 plus lift and just take a smaller cam like the 590 or smaller and adding the 1.6's roller rockers. I guess this combo work's out real nice from what I've seen, heard and read!I am also wanting to squeez more compression out. Is it worth buying special head gaskets to get another half a point of compression? or maybe just to some of us it is..
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355597
12/19/12 07:03 PM
12/19/12 07:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
When it comes to motor building you need to know the goal intended(wanting to achieve) before you start buying parts, I've been lucky on some projects and paid the price on other projects by not using the parts that are compatable with the intended goal. Save your money do it right to start with Set a realistic goal that you can achieve on YOUR budget and go have some fun Learn and move on, save for the next project and move up the food change safely with better parts To many RPM will kill a lot of parts as well as cars and sometimes the driver and spectatotors
Re: I Need Opinions Please!! [Re: Cab_Burge] #1355598
12/19/12 07:13 PM
12/19/12 07:13 PM
western PA
western PA
my goal is 10.90's and yes I am just in reach with my budget
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355599
12/19/12 07:17 PM
12/19/12 07:17 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We run a 590 mopar cam with 1.6 harland rockers in our 440. It never revs more that 7300 thru the traps. With the heads we have it seems like thats about where its running out of steam. Our car weighed 3250 with me in it and it ran 10.80 with a really really mild 440.
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355600
12/19/12 09:36 PM
12/19/12 09:36 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
That's a start. now post a list off all your parts and I'm sure many on here can get you there.............
Re: I Need Opinions Please!! [Re: 10.90 Racer] #1355601
12/20/12 12:06 AM
12/20/12 12:06 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We had that cam in our 440 with 64 max wedge heads on it, with a messed up converter it went 10.70s, stock stroke and standard bore, old TRW pistion... Oh and it is heavy at 3580lbs with me in it
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355602
12/20/12 05:07 PM
12/20/12 05:07 PM
Your using a SB Mopar ,right? If so what parts, heads, block, stroke and compression and intake annd carb. size, are you starting with? That will help determine how much cam you need to get there
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355603
12/20/12 07:02 PM
12/20/12 07:02 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
You need to get your engine apart to some degree to check a couple of things. First off, your piston to head clearance and secondly, how much valve to piston clearance you have. Whilst you're there you could put a degree wheel on your camshaft and get an idea of what you have. It's no good buying parts and discovering that they are not going to fit, or requires machining to get them to fit.
Whilst you're at it, if you haven't done so already, do a leak down and a compression test to check your engines health.
I personally don't see any point changing your camshaft until you have some idea of what it is. Going out and buying a 30+ y/o design Camshaft like a 0.590" Mopar Solid, or a camshaft with a more current design lobe could be throwing money away when the one that you have could get the job done.
I sound like a broken record, but putting the engine onto a Dyno is going to save you time, headaches, and in most cases $$$. After a test session you will know where your engine makes power and torque and just how much it actually makes. I have had friends and acquaintances in the past spend 12-18 months of racing and tuning and changing parts and get no where. They put the engine on a Dyno and determine they're pipes were too big, or they were 1000 rpm off on their converter or whatever.
In summary:
Check the engines Health (Leak down & Compression Test)
Determine what you're working with
Lastly, look at the car. Is your ignition system up to task, are you getting enough voltage to the ignition etc.
Converter? ( I personally think it's too big, and too low a stall speed)
Pipes? What size are you running?
I made some assumptions and ran a simulation in Pipemax
Peak power @ 6600 - 1 3/4" x 32"-34" primary, 3" x 17.6" Collector
Peak power @ 7200 - 1 3/4" x 29"-31.5" primary, 3" - 3.5" x 16" Collector
Alan Jones
Re: I Need Opinions Please!! [Re: LA360] #1355604
12/21/12 01:49 PM
12/21/12 01:49 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I did not want to post on this again,, as your not letting us help you by posting what parts your starting with..... but you are obviously a new racer and time and time again we lose new people to the hobby because the learning curve/curse hit's there wallet WAY harder then they like or needs to be..........
Re- reading this post.. one I agree you don't need (nor want) a big cam like a .590 to run 10.90's... 245 @ .050 255 @ .050 will get you into the mid 10's on most combo's. Mine is .518 lift...
High RPM to run 10.90's...... not unless your running a 273 or 318......
6500 area would probably a real good starting point with a 360 or 340
Dyno... Ya you can learn stuff........ But for what you are doing ... I don't see the necessity.......
Re: I Need Opinions Please!! [Re: 10.90 Racer] #1355605
12/21/12 07:15 PM
12/21/12 07:15 PM
western PA
western PA
I am sorry 10.90 racer and all the others. I've been extremely busy but I am now on break for the holidays! My deal with this engine is you can only go off what the people told us what was in it. They really didn't take a real long time either explanning what's really in it. As far as I know It's just a standard bore 340 that has been cleaned up alittle. Stock stroke crank but it is an old school 8 bolt crank which required and different flex plate. I believe it might be an old moldex. I guess it has steel rods. Suposely has 13:1 TRW pistons. It also suposley has a 606 lift flat tappet mechanical cam that's suposely post to be a mopar cam. It has w2 heads that are the econo version with suposely 2.08 intake valves and the standard 1.60 exhuast. It has a very crappy set of headers on it that were almost built over night lol. They are only like 1 5/8. It currently has a M-1 single plane intake manfiold with a 2 inch open aluminum spacer and a 750 cfm proform carburetor. Like I said all this stuff that's inside that we can't see is what's suposely in it. But we will know for sure here come sometime in Janurary when we go through everything!!!! Thanks for all the comments guys.
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355606
12/21/12 07:41 PM
12/21/12 07:41 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
You already know MY opinion!!!!! What you have now is MORE than enough to get you into the 10's. If you do what ive told you already,RACE,TUNE,RACE,TUNE,RACE,TUNE,RACE,TUNE and RACE,TUNE!!!!!! Yes in that order!!!!
Re: I Need Opinions Please!! [Re: MIKES_DUSTER] #1355607
12/21/12 07:51 PM
12/21/12 07:51 PM
western PA
western PA
Yea you are probaly right mike. But motor still needs to be checked over. Something could be worn out and the parts have the potential just not able. There is a very long list of possibilities!!
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355608
12/22/12 01:06 AM
12/22/12 01:06 AM
Every body on here started out knowing nothing, if you have the ability to take the motor apart and inspect it to see if it is good or bad do that first After doing the visual checks on the spark plugs, upper valve train,, leakdown test and so on then pull it down further If you don't have th tools or expertise, hire someone capable to teach you and instruct you on how to do the tear down and inspection, racing is not cheap and wrecking a car because of bad parts isn't cheap either I've seen some auotshop instructors that weren't race car mechanics or engine guru so keep that in mind Hands on training can be great, it can also be very expensive while your learning
Re: I Need Opinions Please!! [Re: Cab_Burge] #1355609
12/22/12 01:26 AM
12/22/12 01:26 AM
Cab...From my understanding,the motor was put in last year and only raced a few times...Thats why I told him BEFORE he goes buying all this stuff and swapping things on/off,just race what you have and TUNE IT. Just tuning my old motor,I went from 13.3 to 12.07....My dad went from 11.4 to 10.70.
You wont know what the car will run if you keep changing things out before its tuned....Just playing with the suspension,you could gain a 1/2 a second. The car is capable of running 10's right now with what it has in it,it just needs tuning.
Re: I Need Opinions Please!! [Re: MIKES_DUSTER] #1355610
12/22/12 08:27 AM
12/22/12 08:27 AM
western PA
western PA
Mike Like I said before you are right but we got this motor from ciricle track boys!!! Who knows how they ran it or what they did to it? Before that the motor was drag raced then rebuilt then it sat around for something like 10 years. What concerns me would be did anyone ever roll the motor over in the winter by hand once a week? Or did they ever take out the bolts for the rocker assembly and let the springs relax? I know since we have had it we not once did any of that stuff but I didn't know.. I am going to try and listen to you and my one neighbor buddy and maybe the car will run in the 10's!!!! But IMO I think it would be some what of a good idea to atleast check things over see if anything could become or be an issue. The bearings could be real bad and we would never know it untill we check!!! We really need to find out what cam and lift is in the motor and see where all the geomerty is at. Also really need to pay real close attention to the valve springs because they could be in real bad shape as I stated before about letting the valve springs relax either by turning motor over once a week by hand or just by taking the bolts out.
Re: I Need Opinions Please!! [Re: MIKES_DUSTER] #1355611
12/22/12 08:38 AM
12/22/12 08:38 AM
western PA
western PA
Some of this stuff can be done by some simple tests like a leak down tester or a compression tester. But it also won't tell me what the bearings are going to look like or how good of shape the valve springs are in. So that stuff is just going to have to be checked!!!
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355612
12/22/12 09:40 AM
12/22/12 09:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I will never buy and run a used engine without tearing it down and checking it out. Been there, done that and have the broken parts to prove it.
Re: I Need Opinions Please!! [Re: Sb Valiant] #1355613
12/22/12 07:36 PM
12/22/12 07:36 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Good move.......... inspect it......
if is not broke don't fix it. just have fun..........
IIRC these pistons are real heavy. I would not try and RPM the bejeezuz out of it.....
Re: I Need Opinions Please!! [Re: 10.90 Racer] #1355614
12/23/12 01:04 PM
12/23/12 01:04 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
Do yourself a favor: pull the bullet, find out EXACTLY what's in it.
Replace the worn out, update the obsolete.
Check back in. Half the necessary info results in a half answer.
We've already made the mistakes, take advantage of them.
If You Can't Be Good, At Least Be Colorful
Re: I Need Opinions Please!! [Re: Dago Red] #1355615
12/23/12 05:19 PM
12/23/12 05:19 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
I would do a leak down test and if all apears good I would drop it in the car and run it as is . That motor should have no problem pushing you into the tens
