Page 36 of 180 1 2 34 35 36 37 38 179 180
Re: Real world weight loss program and it` cost.......... [Re: @#$%&*!] #1353886
05/05/13 09:36 AM
05/05/13 09:36 AM
fullmetaljacket Offline
Yeah, but that was all that was available and Dr Diff mentioned that all I would need is a crush collar from a 489 carrier and it fits perfectly over the dome to seat the cap. It should be alright.
My trans member is waiting for some welding to close it up and be ready for installation. I'll send pics soon. In the meanwhile, stay light guys.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353887
05/09/13 12:44 AM
05/09/13 12:44 AM
The Muff's are coming along nicely. Wait till you'll see 'em.
Works of art to be hidden with rustic patina.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353888
05/09/13 08:46 AM
05/09/13 08:46 AM
Here's the main aluminum Muffler body taking shape in the spirit of the Dynomax Ultra-flo's. Unobtanium is building them since I have no time at this time.
They will also be straight thru design for max flo under throttle. Should weigh in the range of 6-7 Lbs each when finished.
Compare that to 13 Lbs each for the steel Ultras. I'll put them both on the scales when finished and get the exact numbers.
I'll probably coat the insides of the tubes before installation for max corrosion protection from the corrosive gasses like what Mr.P-body had mentioned before.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353889
05/09/13 11:18 AM
05/09/13 11:18 AM
State of confusion
Thumperdart Offline OP
State of confusion
Looks good and a nice weight savings................
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353890
05/10/13 07:31 AM
05/10/13 07:31 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Here's an idea.
Does the car have to be quiet? If not, just run a straight pipe right through the muffler casing... saves weight, saves trying (and probably failing) to figure out how to baffle a muffler for maximum flow, saves complexity, and nothing to corrode (any more than the rest ov the system anyways). Some people really do love that straight pipe sound too.
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353891
05/10/13 08:21 AM
05/10/13 08:21 AM
This muffler design is a straight pipe thru. It's based on Dynomax's ultra Flo welded mufflers.
They out flow almost all street mufflers while being the quietest so far. I just want it to be light in weight.
Yes, I do need to be quiet for many reasons but need some what of a loud enough note mainly to wake up all the Hipsters staring down at their I-phones while walking against the light on the crosswalks as well as my own sanity.LOL.
I've never used the horns on my car because of its presence known two blocks away coming. Semi-loud pipes saves lives like no other these days.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353892
05/10/13 12:14 PM
05/10/13 12:14 PM
State of confusion
State of confusion
I hear ya about the "being heard" stuff and if you think that`s fun drive into an underground parking lot and give a listen to the many different alarms and lights that go beserc............ I`m hittin up my exhaust guy later on to see about an alum 3 1/2 system w/the ultra flows myself...........peace!
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353893
05/11/13 11:25 AM
05/11/13 11:25 AM
I'll try and let you know of all the flaws and trials along the way to try and built a successful aluminum system. Still waiting on my mufflers and will be plugging it all up real soon. The sound should be interesting.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353894
05/14/13 08:09 AM
05/14/13 08:09 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I'm not sure you understood me. I meant NO muffler at all. Just the pipe itself, with a muffler casing welded around it to look like its a real muffler. No internals, no baffling, nothing to design (or screw up, HP exhaust IS a science!) at all. Hell... because the casing itself is only for show, you could make it an extremely light gauge and save even more weight, so long as you dont accidently hit it with something.
Again, the only downside will be the sound... it will sound like a straight pipe, and it will be loud...
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353895
05/14/13 09:22 AM
05/14/13 09:22 AM
I knew what you meant, but I can not get away with too much noise. The baffling will be very light in this application anyhow. A little back pressure won't hurt neither. Plus, I'd rather have some of the low hung weight in the back as well since its a factory chassis and suspension.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353896
05/15/13 07:21 AM
05/15/13 07:21 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Hmmm... Gotcha. I'd do this myself if i could stand the sound ov straight pipes.
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353897
05/15/13 09:32 PM
05/15/13 09:32 PM
Just heard from the Muffler guy and they will be ready by next week and I'll post some flicks then. Maybe all tide up to the rest of the exhaust system.
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #1353898
05/22/13 12:10 AM
05/22/13 12:10 AM
Who's using Copper plated aluminum strand #1 or #2 Ultra light weight battery cables from their trunk mounted batteries to the starter?
I understand that Quarter-Max has a #2 gauge battery cable that works great and is half the weight of standard welding cable. Accel also has one of their own on the market.
Just scouting.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353899
05/22/13 07:26 AM
05/22/13 07:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I can say the OEMs are experimenting with it right now, It is very light.
Doug
Re: Real world weight loss program and it` cost.......... [Re: dvw] #1353900
05/22/13 11:24 AM
05/22/13 11:24 AM
Would love to see what they come up with. I might have to beat 'em to the punch line and see how they hold up.
On another note, just curious that no one including me has tried the SFI Reactor aluminum convertor flex plates. Rotating weight removed right at the center of the heat. Wonder if the lighter weight negatively effects the stored energy of heavier plates on launch. So far, my SFI steel plate has served me swell. Maybe pick my battles. I'll look into this.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353901
05/27/13 06:21 PM
05/27/13 06:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I just wanted to post cutting down centerlink to clear pan like I had to do on my car...
i'm sure you can get pretty crazy with it...
Mopar Performance
Re: Real world weight loss program and it` cost.......... [Re: moparniac] #1353902
05/27/13 07:13 PM
05/27/13 07:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
I like to see and hear more about this. mine rubs on the pan !
Re: Real world weight loss program and it` cost.......... [Re: VernMotor] #1353903
05/27/13 07:21 PM
05/27/13 07:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
from the castle nuts down that slide area look at the bar... wacked off in milling machine then I spent time on a belt sander rounding and smoothing out some. pretty much everywhere the pan had rubbed paint off the bar and by the depth of "pan rub areas" I that area.
Mopar Performance
Re: Real world weight loss program and it` cost.......... [Re: moparniac] #1353904
05/28/13 07:06 PM
05/28/13 07:06 PM
Some time this week I'll weigh the new Accel #1 gauge Lightning battery cable that comes in bails of 20'ft to compare with traditional copper wire battery cable. Being that it is made of aluminum strands with a electro-copper coating, it should weigh about just under half of copper or about 5-6 pounds as SB412Duster indicated. Stay tuned.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353905
05/30/13 02:49 AM
05/30/13 02:49 AM
Man, was I on point with the weight of the new mufflers that Chris at Unobtanium built me. They come in at 7 lbs each.
Here are some flicks of the straight-thru gems ready to be mated with my aluminum tube exhaust that was posted earlier on this thread.
So as I had mentioned before, my already lightened 321 stainless exhaust with X-pipe and Factory Dyno-max Ultra flo's weighed in at a trim 38 Lbs. Now with this new system and fingers crossed, it comes in at a stealthy,featherly 21-3/4 Lbs.
That's as much as I can lighten it other than open Headers. No!, I would not use collector bullets or collector Muffs since I wanna drive this thing.
