Page 27 of 180 1 2 25 26 27 28 29 179 180
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #1353706
03/07/13 06:07 PM
03/07/13 06:07 PM
State of confusion
Thumperdart Offline OP
State of confusion
You guys r makin me tired............ How do you guys feel about alum. bolts on seats as in roll bar bolts and mounting to floor bolts. I`ve got a guy that goes to L.A. on thursdays and can get whatever I need in alum.................
Whats the sheer strength on them and are you feeling lucky enough to try them on the seats and bolt in seat mounts, not me good quality grade eights is what I would use on them you know me, I don't like unneeded pain or injurys
That`s kinda what I expected to hear..............
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #1353707
03/07/13 08:51 PM
03/07/13 08:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Seats?? No freakin' way. Grade 8's minimum. Titanium maybe??
Re: Real world weight loss program and it` cost.......... [Re: cudadoug] #1353708
03/07/13 09:20 PM
03/07/13 09:20 PM
State of confusion
State of confusion
Damn, guess I`m crazier than most and figured it wouldn`t be a problem. On a side note; The ATI dampner weights 11 lbs. and the Fluidampr weighed 12 lbs. I was hopeing for a 4-5 lb. difference to free up some usable revs.............oh well, we`ll take more out somewhere else.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353709
03/07/13 10:52 PM
03/07/13 10:52 PM
fullmetaljacket Offline
No way Jose, Any aluminum bolt is not a good idea for the seats and or brackets as stated.
I went with high grade Titanium on mine. Saved only a pound or so if I remember correctly and that was between both front A-100 seats and the bolts attaching the seats to the brackets. Lot more costly then aluminum, but also a lot more safer in a Amen situation. In any case, make sure to use good grade Titanium or 7075 aluminum wide washers under the seat to chassis mount to spread the clamping.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353710
03/07/13 10:56 PM
03/07/13 10:56 PM
Dampers? That's a good small rotating mass right there on the front of the engine. Might not see so much of a difference and then again if you do, you may never know exactly to what specific thing because of all the various things you have pulled off so far this Winter. In either cas. I'd like to see that pup be below the 3K weight bar and see a good 9.47 or so out of it.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353711
03/07/13 11:52 PM
03/07/13 11:52 PM
State of confusion
State of confusion
I`ll get some grade 8`s tomorrow w/good area washers since that`s the quickest/easiest way and if I go 9.47, I`ll be up for days............ Two more zeus fastners to tie the hood down and mount the seats and were cruisin.......
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353712
03/08/13 12:03 AM
03/08/13 12:03 AM
You might have to make a few runs to achieve the number and maybe you'll be lucky on the first pass. Maybe a little shake down semi-pass or all out the back door?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353713
03/08/13 12:09 AM
03/08/13 12:09 AM
State of confusion
State of confusion
I`ll play w/it on the street and when I get to the track I`m going all out first pass and if it hooks, hang on baby if not, I`ll lift and try and quickly figure it out.......... Off to lady friends house.........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353714
03/11/13 10:55 PM
03/11/13 10:55 PM
State of confusion
State of confusion
Ok, so anyone wanna take a stab at my new weight? I`m using the stock(22 lbs.)windshield and radial ft. tires which both will be replaced soon..............was around 3200 lbs before I lost it and went crazy on this thing.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353715
03/11/13 10:58 PM
03/11/13 10:58 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
ill try 2940lbs .......... ...sorry lee, you should of had first shot at the question ...pat
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353716
03/11/13 11:06 PM
03/11/13 11:06 PM
Okay, I'm away from my desk at the moment, half way down the equator. I suspect 3010 LBs.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353717
03/11/13 11:17 PM
03/11/13 11:17 PM
State of confusion
State of confusion
I kinda agree w/Lee on this. I just don`t see me gettin 200+ lbs. out of it but, you never know.................
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353718
03/11/13 11:21 PM
03/11/13 11:21 PM
Did I win the prize?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353719
03/11/13 11:23 PM
03/11/13 11:23 PM
State of confusion
State of confusion
Havn`t weighed it yet still waitin on scales which I should have here tonight............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353720
03/11/13 11:25 PM
03/11/13 11:25 PM
new york usa
P
P
new york usa
One can only hope ...lee is the professor.....iam drving a 3280 lb"b" body.....so iam taken the ride for the out come ...i ve followed this post since day one...cant wait for the results....I hear they are taking book on the number in vegas.....lol....hope u r happy i know how much you put into this...all the best
Re: Real world weight loss program and it` cost.......... [Re: pattyboy 572] #1353721
03/11/13 11:32 PM
03/11/13 11:32 PM
State of confusion
State of confusion
I do, he is and this has turned into a great informative post and I know I can get another 20+ lbs. off the ft. w/lexan and bias ply tires which is coming but I`m real curious and can`t wait. That`s awfully light 4 a b body.................
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353722
03/12/13 12:04 AM
03/12/13 12:04 AM
new york usa
P
P
new york usa
AM radio still working ,no heater box...glass hood,bumper aluminum block,heads auto .small back seat for dog,widows still all cranking....and cap front end with coil over....n...rack...10.5 tire..12.5 to 1...325cnc 1s..with a 2.19...best to date 9,86..139.7..needd to do convertor..dyno eng last year got bad data...so it off to tnt to get number's to dail in the vert...60 foots terrable 1.41-1.38.....pat
Re: Real world weight loss program and it` cost.......... [Re: pattyboy 572] #1353723
03/12/13 12:08 AM
03/12/13 12:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
3039lbs
Re: Real world weight loss program and it` cost.......... [Re: dvw] #1353724
03/12/13 12:35 AM
03/12/13 12:35 AM
State of confusion
State of confusion
Nice running car................hopefully I`m under 3000 lbs..............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353725
03/12/13 08:35 AM
03/12/13 08:35 AM
tboomer Online work
tboomer  Online Work
2980#...Good luck,Thumpman!!
