Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#1353709
03/07/13 10:52 PM
03/07/13 10:52 PM
fullmetaljacket
No way Jose, Any aluminum bolt is not a good idea for the seats and or brackets as stated. I went with high grade Titanium on mine. Saved only a pound or so if I remember correctly and that was between both front A-100 seats and the bolts attaching the seats to the brackets. Lot more costly then aluminum, but also a lot more safer in a Amen situation. In any case, make sure to use good grade Titanium or 7075 aluminum wide washers under the seat to chassis mount to spread the clamping.
[Re: Thumperdart]
#1353710
03/07/13 10:56 PM
03/07/13 10:56 PM
fullmetaljacket
Dampers? That's a good small rotating mass right there on the front of the engine. Might not see so much of a difference and then again if you do, you may never know exactly to what specific thing because of all the various things you have pulled off so far this Winter. In either cas. I'd like to see that pup be below the 3K weight bar and see a good 9.47 or so out of it.
[Re: Thumperdart]
#1353715
03/11/13 10:58 PM
03/11/13 10:58 PM
Posts: 452 new york usa
pattyboy 572
new york usa
ill try 2940lbs .......... ...sorry lee, you should of had first shot at the question ...pat
[Re: Thumperdart]
#1353716
03/11/13 11:06 PM
03/11/13 11:06 PM
fullmetaljacket
Okay, I'm away from my desk at the moment, half way down the equator. I suspect 3010 LBs.
[Re: Thumperdart]
#1353718
03/11/13 11:21 PM
03/11/13 11:21 PM
fullmetaljacket
[Re: fullmetaljacket]
#1353719
03/11/13 11:23 PM
03/11/13 11:23 PM
Thumperdart
State of confusion
Havn`t weighed it yet still waitin on scales which I should have here tonight............
[Re: Thumperdart]
#1353720
03/11/13 11:25 PM
03/11/13 11:25 PM
pattyboy 572
new york usa
One can only hope ...lee is the professor.....iam drving a 3280 lb"b" body.....so iam taken the ride for the out come ...i ve followed this post since day one...cant wait for the results....I hear they are taking book on the number in vegas.....lol....hope u r happy i know how much you put into this...all the best
[Re: Thumperdart]
#1353722
03/12/13 12:04 AM
03/12/13 12:04 AM
pattyboy 572
new york usa
AM radio still working ,no heater box...glass hood,bumper aluminum block,heads auto .small back seat for dog,widows still all cranking....and cap front end with coil over....n...rack...10.5 tire..12.5 to 1...325cnc 1s..with a 2.19...best to date 9,86..139.7..needd to do convertor..dyno eng last year got bad data...so it off to tnt to get number's to dail in the vert...60 foots terrable 1.41-1.38.....pat
[Re: pattyboy 572]
#1353723
03/12/13 12:08 AM
03/12/13 12:08 AM
Posts: 9,866 MI, usa
dvw
MI, usa
