TIMING QUESTION
#1351796
12/15/12 07:40 PM
12/15/12 07:40 PM
Posts: 4,745 On the parachute mount
n20mstr
How high have you been?
THe higher i go the faster it goes, where should i stop?
....BAD A$$ STREET CAR.....
Re: TIMING QUESTION
[Re: n20mstr]
#1351806
12/17/12 12:26 AM
12/17/12 12:26 AM
Posts: 213 poughquag, NY
440GTX
poughquag, NY
I think stash master is just posting up random numbers Wayne.
He may be...he may not be... If so, what's the point of this thread?
the point is to see if i can find those missing straps
Need to try 70 degrees of timing LOL you are the man tony !!!!!!!!
Re: TIMING QUESTION
[Re: Thumperdart]
#1351810
12/17/12 01:50 PM
12/17/12 01:50 PM
Posts: 5,160 Texas
dannysbee
Texas
Start off at 50-60 total. Then as you replace parts retard it little by little till you hit the sweet spot. A good rule of thumb if you are replacing big parts retard it more, if small parts less. Good luck with it!!! If you have any problems there is a guy up in your neck of the woods that uses this methods. I am sure he would be glad to help you out. Lol
Getting old just means you were smarter than some and luckier than others.
Re: TIMING QUESTION
[Re: Cab_Burge]
#1351812
12/17/12 06:44 PM
12/17/12 06:44 PM
Posts: 21,060 in a cattle trailer down by th...
Guitar Jones
Mohammad Ghandi can tell you.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
