Felpro Head Gaskets for Big Block
#1351350
12/14/12 06:10 PM
12/14/12 06:10 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I have been running Felpro 1009's since I built this 496. Just tore the heads off to replace valve springs and check things over. The firing ring is real close to the chamber on the Eddy Performer heads, but have been sealing good. Question is...I have a set of 8519 PT1 Felpro's in my gasket kit. They seem to have a slightly larger bore than the 1009's, and are about .044" thick uncompressed. The 1009's have compressed down to about .037". Will these be OK to sub for the 1009's and still keep my quench the same? ![](/ubbthreads/images/graemlins/shruggy.gif) At 75.00 a piece for 1009's, I realy don't want to fork out a bunch of money if the 8519's will work.
Re: Felpro Head Gaskets for Big Block
[Re: superwrench]
#1351356
12/14/12 11:28 PM
12/14/12 11:28 PM
Posts: 75 North Carolina
Mopar dragster
North Carolina
Just my opinion, but I would invest in a set of Cometics. Worth every penny they cost to me.
Please see my brother Darrell Kiger at Wyo Racing and Rods for all of your drag car fabrication and restoration needs. From Pro Mod to concours restorations, he is the man. (336)463-4309.
[Re: AndyF]
#1351358
12/14/12 11:49 PM
12/14/12 11:49 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I recommend Cometic head gaskets. The 8519 gaskets will damage the head and then you'll have to pay to surface the heads. Even the 1009 gaskets usually damage the cylinder heads enough to require a skim cut.
Yep been there done this. ![](/ubbthreads/images/graemlins/iagree.gif)
[Re: 451Mopar]
#1351362
12/15/12 03:40 AM
12/15/12 03:40 AM
superwrench
Yeh..I defintely have the fire ring impressions on my heads. I've had them off a couple of times and just installed new 1009's and never had a leak (that I know of) ![](/ubbthreads/images/graemlins/shruggy.gif) ...maybe just lucky. I guess one would have to order direct from Cometic?? Or are there any dealers for them (Pac Northwest area)?
[Re: superwrench]
#1351363
12/15/12 07:21 AM
12/15/12 07:21 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My 440 with Stealths I run the FP marine gaskets.Been on 4 years street/strip.I run 12.5 domes.The 1009s were close to the chamber.The Marines compress to about .039.Think they were like 40 bucks each.Rocky
Chrysler Firepower
[Re: therocks]
#1351364
12/15/12 11:56 AM
12/15/12 11:56 AM
Posts: 1,301 Penna
70satelliteguy
Penna
"My 440 with Stealths I run the FP marine gaskets.Been on 4 years street/strip.I run 12.5 domes.The 1009s were close to the chamber.The Marines compress to about .039.Think they were like 40 bucks each.Rocky" I am about to put together a 440 with the Stealth heads with 9:1 compression with a set of 1009's. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Am I going to run into trouble down the road? It is just a street cruiser! Thanks Mike ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Thumperdart]
#1351366
12/15/12 02:16 PM
12/15/12 02:16 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"Same here but I don`t like the waisted space around the bore but it`s worked for years..." So thumper are you running the 1009"s that have not been a problem for years? Mike p.s. You sure are spending a lot of time on here for a Saturday. You should be working on the car or getting your "Honey DO" list done! ![](/ubbthreads/images/graemlins/laugh2.gif)
