NHRA-IHRA Super Stock Rule question #1351313
12/14/12 02:58 PM
12/14/12 02:58 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I know for a long time that if your car came with leaf springs you had to run them in Super Stock. I have heard that coil over and ladder bars are now legal to run without leaf springs?
Any body know about this?
Switched to the dark side...
Re: NHRA-IHRA Super Stock Rule question [Re: JSR1485] #1351314
12/14/12 03:17 PM
12/14/12 03:17 PM
I don't know about IHRA rules but NHRA did rescind that rule sometime in the past. Call both tech. dept or better yet E mail both and get a WRITTEN reply so you have a written record of there decisions
Re: NHRA-IHRA Super Stock Rule question [Re: JSR1485] #1351315
12/14/12 04:37 PM
12/14/12 04:37 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
You are correct........ The modified tubs must be of the same material and gauge as the original tubs.........
Many SS cars are running on leaf springs these days ,with the latest technology in tires and shocks..........
Re: NHRA-IHRA Super Stock Rule question [Re: JSR1485] #1351316
12/14/12 05:33 PM
12/14/12 05:33 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Most upper class cars have 4 links/coil overs. Some lower class cars still have ladder/leafs.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: NHRA-IHRA Super Stock Rule question [Re: sixpackbee] #1351317
12/14/12 05:44 PM
12/14/12 05:44 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
There are a few Mopar Stock & Superstock racers who run Cal
Tracks leaf springs & shocks and run either NHRA class on
9X30 drag slicks three come to mind Jim Duraham, Don Little
and Steve Wann,(Div 7) have run Stock and SuperStock with the
same car, just different motor combo's.
Phil Saran Parker, Colorado
Re: NHRA-IHRA Super Stock Rule question [Re: Phil Saran] #1351318
12/14/12 07:33 PM
12/14/12 07:33 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
NHRA 2013 rule book - I underlined the pertinent parts.
SUSPENSION, Rear Stock rear suspension may be changed as follows: Lateral movement inboard permitted when rear frame and/or suspension is moved in for tire clearance. Mounting points may be moved in on axle housing and frame as required. In addition to stock suspension, a pivot below rear axle housing is permitted. Axle housing may rotate in spring mount; side movement of housing limited to 1/4-inch. Spring mounts may slide on leaf-spring equipped cars no more than 1/2-inch forward or rearward. See illustration in General Regulations 3:4 for acceptable pivot mount for rear suspension. Leaves may be added or removed. Rear leaves may be aftermarket fiberglass type. Rear leaf springs need not be same length as original. Coil springs may be replaced with similar configuration units; rear trailing arms may be replaced or removed when using four-link or ladder-bar suspension. Removal of original springs permitted. Coilover shocks permitted in rear suspension. Shocks may be relocated; minimum down travel on shock is 1 inch. Rear trailing arms may be replaced with OEM-type aftermarket units, round tubing permitted, 1-inch-minimum diameter. Bushing must be in trailing arms that allow suspension movement but keep parts from being noticeably loose. See General Regulations 3:4.
Re: NHRA-IHRA Super Stock Rule question [Re: Phil Saran] #1351319
12/14/12 09:15 PM
12/14/12 09:15 PM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Coil overs and 4 link on my KA car..plan to run new F and G SS car on mono's/Caltrac's so I can run between Stock and SS.
Re: NHRA-IHRA Super Stock Rule question [Re: Phil Saran] #1351320
12/14/12 11:20 PM
12/14/12 11:20 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
9X30 drag slicks
My 73 Dart Sport runs G & H/S and SS/K & L. .80-1.0 under the stock indexes and .3-.4 under in SS.
1959 Bugeye Sprite
1971 MG Midget
Re: NHRA-IHRA Super Stock Rule question [Re: ProStDodge] #1351321
12/14/12 11:27 PM
12/14/12 11:27 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
That was what I read and I guess it is correct, That is very cool.
Thanks for the INFO
I have a 70 Duster that I was trying to sell. It was a old bracket car
and has ladder bars with coil overs. It still has stock dash, glass and the windows still roll up and down. I can take the fiberglass fenders off and put steel on with a flat steel hood. I was thinking maybe about building SS/JA or KA car
Re: NHRA-IHRA Super Stock Rule question [Re: JSR1485] #1351322
12/14/12 11:43 PM
12/14/12 11:43 PM
408Dust Offline
408Dust  Offline
70 Duster is a natural J car and a tough combo to make fast, K you would have to add a lot of weight.Look at some of the later 360 combo's or GT class.
Re: NHRA-IHRA Super Stock Rule question [Re: Cab_Burge] #1351323
12/15/12 12:32 AM
12/15/12 12:32 AM
Locomotion Offline
Locomotion  Offline
IHRA typically follows NHRA rules. Most of the differences between the two are around IHRA-only classes and some HP factors.
Re: NHRA-IHRA Super Stock Rule question [Re: Locomotion] #1351324
12/15/12 03:15 AM
12/15/12 03:15 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Super Stock still requires the stock floor in front of the rear seat area to the firewall and between the frame rails all the way to the tailight panel. Beyond that, many of the state of the art, high end cars look like an OEM/Pro Stock hybrid.
Re: NHRA-IHRA Super Stock Rule question [Re: 408Dust] #1351325
12/15/12 07:08 AM
12/15/12 07:08 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
The 340 is a good combo to make fast......... With the GT you are giving up .10 right off the bat that you can't pick up with that body style...........
Re: NHRA-IHRA Super Stock Rule question [Re: 10.90 Racer] #1351326
12/15/12 09:31 AM
12/15/12 09:31 AM
408Dust Offline
408Dust  Offline
Mark Howes is the fastest high compression 340 and there are only two guys running the big valve high compression combos.
Re: NHRA-IHRA Super Stock Rule question [Re: 408Dust] #1351327
12/15/12 02:10 PM
12/15/12 02:10 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
JSR, I`m not 100% sure but I think thats my friends old S/S Duster that he ran many years ago in S/S I, J, or K automatic with a 340. My engine builders as was (and still is ) his alsos name is on the side of the car. I asked him and showed him the pic from your ad and he`s not sure. His car was originally done by a guy named Hayes in Paterson. He sold the car many years ago to a guy that put the big block in it, who might have had it redone by Quay. But if its the same car it ran S/S originally. Bill Rolik had a similar car built by the same guy.
Re: NHRA-IHRA Super Stock Rule question [Re: 408Dust] #1351328
12/15/12 03:48 PM
12/15/12 03:48 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Have you looked at the HP on that engine lately??? 290hp less than a low comp small valve 360 in GT..........
But if you want to put together a lower budget SS engine the 360 is the way to go.........
Re: NHRA-IHRA Super Stock Rule question [Re: 10.90 Racer] #1351329
12/15/12 04:14 PM
12/15/12 04:14 PM
408Dust Offline
408Dust  Offline
I know it well, 340 high compression big valve is rated at 279 this year it was 283.
I run 71 340 high compression with magnum heads rated at 288.
Re: NHRA-IHRA Super Stock Rule question [Re: 408Dust] #1351330
12/15/12 04:41 PM
12/15/12 04:41 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I knew it had hp taken away this year..... again...... Would love to go that route for my 69...... i'm putting together a mag head 360 combo for GT........
how far under are you?? Why don't you like it??
Re: NHRA-IHRA Super Stock Rule question [Re: 10.90 Racer] #1351331
12/15/12 05:22 PM
12/15/12 05:22 PM
408Dust Offline
408Dust  Offline
PM sent.
Re: NHRA-IHRA Super Stock Rule question [Re: 11secdart] #1351332
12/15/12 05:54 PM
12/15/12 05:54 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
Bill you might be correct, I have too look again but the one fender had the Name the Motor shop or something like that and there was also a sticker in the trunk about a shop in Paterson NJ.
I know the car has been a drag car a long time, a plaque on the dash from 1977 world series race from Raceway Park
