Page 4 of 8 1 2 3 4 5 6 7 8
Re: B1's - Why not more popular for Big strokers?? [Re: mopartoby] #1350221
12/13/12 04:12 AM
12/13/12 04:12 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have mainly tried them in pump gas engines around 500 cu in, and in those cases they haven't worked very well. They have huge ports compared to teh flow, which means low velocity. The ones I built did not make enormous power and were a bit shy on tq too. Even if they flow better than some others, I propably wouldn't use them except in all out engines. Different story with more cubes, I guess. And will find out, there is a set that made 780 hp on a 500 going on a 604 short block. We'll see....
Plynouth VIP '67 TT IC EFI
Re: B1's - Why not more popular for Big strokers?? [Re: go green] #1350222
12/13/12 10:54 AM
12/13/12 10:54 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
20 plus year old heads . If you have to ask then you are stuck in a time warp feeding the dated zombie Mopar hoard. I find it way more offencive that we don't have any more heads to chose from in the past 10 years . The B1 heads should be parked right next to the MC hammer pants.
Now that's a quote I will not forget soon! and sooo True!
I want a MC Hammer fire suit to wear at the track,would be very comfortable instead of the skinny jean suit I have now.
Time warp dated Zombie Mopar Hoard--Great name for on the side of a trailer. thanks for the idea's
Re: B1's - Why not more popular for Big strokers?? [Re: mopartoby] #1350223
12/13/12 11:07 AM
12/13/12 11:07 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
You're almost right, they are a bit old school but they work very well!! And your predators work even better. But no way i'll fork out that kinda loot for that little gain over the b1's.
Now wait a second...
when you use the term "little gains" can you qualify that for me.
Im saying that max effort B1 Heads are great pieces, but the cost difference between them and Predators are not that much different and a predator can make substantially more power....
Re: B1's - Why not more popular for Big strokers?? [Re: joshking440] #1350224
12/13/12 11:34 AM
12/13/12 11:34 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
he left out *when using a 509 purple shaft cam*
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: B1's - Why not more popular for Big strokers?? [Re: bigtimeauto] #1350225
12/13/12 12:14 PM
12/13/12 12:14 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Hello guys, I'm a graduating Mechanical Engineer(2days away) and this thread makes me wonder if I will make any money whatsoever in finishing a BBM canted valve cylinder head project I'm working on lol. Luckily, I'm passionate and driven to succeed so as long as things proof out, I will have them machined by the end of next year hopefully. Its a slow process when your doing it essentially by yourself.
My question is what are people typically doing with these big stroker motors? That could be half of the problem right there.
If most of these builds are being used in bracket racing, there's no need to go all out unless your trying to run Top Sportsman Naturally Aspirated. I know in my region, there are barely any Mopars running faster than 9.20's so the big strokers aren't really needed for that. Also, when I think of the faster cars, they either have Sonny's for power, a BBC, use a power adder, top of the line SB's, or use hemi99 power. In general, most mopar guys just run the brackets and are between 6.00-6.50 in the 1/8th mile. Now that I think about, there is one car at our local track that has a B1 motor and runs 5.20's. Other than that, I don't see many around my way or at local events elsewhere.
Adriel Paradise
Substation Design Engineer III
Re: B1's - Why not more popular for Big strokers?? [Re: Al_Alguire] #1350226
12/13/12 12:27 PM
12/13/12 12:27 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I have never figured out why they are not more popular period. I think there are way to many myths out there about them. However I am sure the biggest issue with most people is pistons. No one stocks a shelf piston for a B1, so you have an additional cost there. Or could be guys are happy with Indy and their stuff. As I have said a hundred times if you cannot make at least 800 hp with a set of B1 originals you are doing something seriously wrong.
if I was to step up to "a real head" over my EZ-1's which I will do eventually I would have to buy all new rocker arms and pistons. Then have the assembly rebalanced and new rings. I don't know it just seems like a lot. If I was building from the ground up then it would be easier but as an upgrade it's to much.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: B1's - Why not more popular for Big strokers?? [Re: Jacob Pitt] #1350227
12/13/12 12:55 PM
12/13/12 12:55 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I think it is a double whammy. The custom pistons along with the custom headers put the b1's out of most people's comfort zone. Someone tool up a 2.25 header that will work on an A B or E body and I bet you would see many more. Probably some of the best money koffel's could spend would be to get a shelf header and pistons. The b1 has had it's day as the cutting edge race head but as a big inch street and strip or fast bracket alternative it could be a whole new horizon. I believe it would be just a matter of making the needed parts readily available.
Getting old just means you were smarter than some and luckier than others.
Re: B1's - Why not more popular for Big strokers?? [Re: go green] #1350228
12/13/12 01:14 PM
12/13/12 01:14 PM
That statement really nails it
I do a few SBC's every year for customers and EVERY time we build one we research the head choices--there are so many new ones each year! The options are astonishing.
Wasn't the B1 an abanoned Chrysler deal? Wasn't the -1 Indy made from the leftover ( though updated) casting box from Zeeker? Indy Small Block aluminum head same deal from another maker that went bust?
The Edelbrock was the only original from the ground up new head. Source just a copy of that.
Oh well...we can make enough power with those to split stock blocks, guess that is enough.
Oooh! Pistons have gone through the roof in last few months--even the shelf stock plain Janes--SRP, Protrues,even the Icon--all supposed to be cheaper than the flagship brands--wowy zowy!!!Pistons are CRAZY priced now! Near $400 for CAST KB's is just a JOKE as well!!!!!!
Re: B1's - Why not more popular for Big strokers?? [Re: dannysbee] #1350229
12/13/12 01:27 PM
12/13/12 01:27 PM
gregsdart Online content
gregsdart  Online Content
Well put. And an offering of a slightly smaller port version capable of being ported to the needs of different engine sizes would go a long way to making them sale-able. 3 cnc versions, small, medium and huge. Think about it- a B1-PSO head with smaller ports but the meat in the heads to go as big as the basic head will allow. This would wind up being similar to a Brewer head, which worked like gangbusters for an inline head, but the market wasn't strong enough to make a go of it. Brewer heads were a match (or better) for B1Mc heads, yet made power 500 rpm below what the Mcs did. An old adage is "a wedge head is only as good as the length of its' intake valve" The Brewers are a great example. seems to me the basic B1 casting could be upgraded similarly. On top of that, make the valve train and mounting points in such a way as to accommodate different spring installed heights and rocker ratios. OK, the Christmas wish list is complete!
Re: B1's - Why not more popular for Big strokers?? [Re: gregsdart] #1350230
12/13/12 02:16 PM
12/13/12 02:16 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Koffel's are you listening? Someone should send them a link to this thread. Lol
Re: B1's - Why not more popular for Big strokers?? [Re: gregsdart] #1350231
12/13/12 02:35 PM
12/13/12 02:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I am sure I will get beat over the head with this one but here goes.
I am still very much on the fence about the Predator deal. They show great potential for sure as the best available head other than the 99 stuff. However everyone I know personally that has one has had some reliability issues with them. Three of those came from big name Mopar shops. I have a set on the shelf and we have not built anything with them yet. Not so much due to others reliability issues, although that is certainly a concern but more I dont have a car to put one in yet. I also understand there are a number of them out there running really hard. For me my current B1MC runs fine and is plenty for the car I have. we certainly have some left on the table with my current car as far as all out racing is concerned. If I ever get a light car we will look much harder at the Predator deal.
As for th B1 points. Do yo uguys really think a shelf piston and headers will help?? I agree with the marketing plan that has not been the strongest and dont see that changing. These heads have been around OVER 20 years and they still are not very plentiful. So what does one think a set of B1 shelf headers will run ya?? My guess is TTI prices or better due to lack of sales. So why bother for a set of headers that will at best be a compromise. For a few hundred more you can get a much better performing piece that actually fits whatever chassis it is in. Not something you have to dent, move, curse or disassemble most of the car to install.
As for the need for bigger strokers. I will provide a little bit different perspective. Being a .90/super class raer there is a definite need for them here. As much as you all HATE throttle stop racing in this world MPH is king pretty much. Thus the need for these types of RELIABLE decent power strokers. Reliability and repeatability are the keys here. I have a 1050+hp BB Mopar that we rarely have to do anything to. I have not even set the lash this year, just checked it. Chenge the oil occasionally and throw in a set of plugs each year along with a set of valvesprings for good measure. One of my BIG hesitations with the Predator deal is this concern. While slower MPH can and do win here if you look hard you will see the big MPH cars seem to have an advantage, whether perceived or real it is there.
Just my
Re: B1's - Why not more popular for Big strokers?? [Re: Al_Alguire] #1350232
12/13/12 03:06 PM
12/13/12 03:06 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I guess my point here if there was alternative B1 (bore centerline valve reliefs) Piston readily available, other head MFG's could develop a head with the superior B1/W8 type Valve arrangement that wouldn't cost much more than the present offererings. If they assumed anybody buying that head was building a stroker, (How many people build stock 3.75" stoke 440 motors out their Keleno, MP or World blocks after all ?), it seems like this wouldn't be hard to do.
As for the B1 header, yes it is an added expense, but maybe Koffel could run a test set of EZ-B1's (sorry indy ) that have a conventionally sized (but still very good) exhaust port.
People say, well it's not gonna happen....and maybe not...but now Edelbrock is coming out with a Victor small block head that has a 2.15" intake valve....so that's not gonna just bolt on to most existing shortblocks without a piston swap (or some serious flycutting mods and maybe upsetting the bobweight/balance)either
What if Koffell, Indy, Eddie or whoever gave Us a BBM head which combined max wedge ports (standard intakes will fit ) BUT also gave us a W / B1 style valve arrangement that opened on the bore center and a more favorable for flow Valve angle?
WIZE
In Car:
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350233
12/13/12 03:11 PM
12/13/12 03:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Woudl not just be the port size. The heads are wider and taller so the headers would be moved a great deal and need to be B1 specific. Having said that I have seen fenderwell headers used on an A body
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350234
12/13/12 03:23 PM
12/13/12 03:23 PM
NC
440Jim Offline
440Jim  Offline
NC
OK Wize,
When I build my next motor, it will have a KB aluminum block and B1 heads (original or MC?). I might stay small CID to use my existing Callies 4.250" crank, so 4.500" bore would be 540-541 CID.
But I need a better car to put that thing in! So it isn't going to happen in the next couple years. Maybe 2017... unless somebody buys mine sooner.
I keep changing my mind, either going back to 10.00 ET or bigger motor and lighter car... LOL
Re: B1's - Why not more popular for Big strokers?? [Re: Al_Alguire] #1350235
12/13/12 03:36 PM
12/13/12 03:36 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I have a set of 2.25 headers that are for a b1 in a early b body that have one tube out the fender well similar to set of pro parts headers. These were custom built and on a RB b1.
Re: B1's - Why not more popular for Big strokers?? [Re: 440Jim] #1350236
12/13/12 03:44 PM
12/13/12 03:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Jim I vote for lighter and bigger..Same boat I am in. Porker of a car with a tiny motor.
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350237
12/13/12 04:02 PM
12/13/12 04:02 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I will wade into this one with the risk of stirring the pot a little more.The direction you take really depends on where you want to go and how much money you would like to spend. The rough list below is in order of increasing cost. Of course there will be outliers or combos that make more or less than these rough figures. This is purely a general guide from my perspective.
550-650 Edelbrocks
650-750 SR's or B1BS
700-800 440-1
800-900 572-13
850-950 B1 original
850-1000 B1-MC
950-1150 Predator
The points I am making here is that there is potentially alot of overlap between the engines built with the different heads. But there are some good choices available depending on what power level you are targeting. However if you are interested in a competitive top sportsman combination there really is no viable alternative at this time if you want to qualify in the top half of the field and run consistent. The 99 makes some good hp and while suitable for comp not so useful for a T/S deal with a peaky powerband.
Naturally aspirated if you want big power time to give up brand loyalty and move on to many good higher output alternatives.
Flame away !
76 Duster work in progress
Re: B1's - Why not more popular for Big strokers?? [Re: dannysbee] #1350238
12/13/12 04:10 PM
12/13/12 04:10 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You had a couple of options for B1 heads. B1BS and B1 originals. I wonder how well a BS head works when done all out? They are not expensive. The originals were made for racing, not street car and small et numbers. That's why we were offerd 2 back in the day.
I pulled my engine out of my race car , installed the B1 and got to use the same Headers. They even fit better. (tube chassis) Serious racer will go the extra length to have the headers made, or make them their selves. Koffel's has the 2 3/8 flanges already. You can get by with smaller. By the way, Koffel's keeps pistons in stock.
I really have never bought a shelf piston for racing. They were always needing deeper pockets for a better cam choice. Everything has it's limits. You ever run a 440 source kit? They advertised notches up to around 700 lift. Zero deck and you fly cut. Most are around 12 in the hole.
MR P has a set of kick azz pistons forsale for the MC B1's at a fantastic price if someone is going that route. And can be used on an original
Re: B1's - Why not more popular for Big strokers?? [Re: Al_Alguire] #1350239
12/13/12 04:18 PM
12/13/12 04:18 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Speculation is a Mopar guys worst enemy
Re: B1's - Why not more popular for Big strokers?? [Re: Mopar-Al] #1350240
12/13/12 04:19 PM
12/13/12 04:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For me its simple......price. I guess I am poor next to some of the guys on here. I sometimes wonder how so many people have the money they do to spend on the hot rod ? I wish I had more but alot of people like me have to live within our means. Thats why I went with EZ heads as I wanted to stay with stock rockers and stock exh port location. I know I am giving up hp but its a budget I can afford and I feel the EZ's are better then the Eddy RPM's and any iron head. Course my 63 is basically a street car that I love to race when I can afford too and I new mid to high 10's on pump was all I could afford. Ron
