Repairing Bench Seat #1349788
12/11/12 09:27 PM
12/11/12 09:27 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
Im sure I have not been the only one with sagging springs on the drivers side of the bench seat. I pulled the seat out thinking that the springs are broke. Well none of them are broke but all those tiny wires that run thru the burlap are just hanging there. I assume they are part of the cause for the sagging. Has anyone ever repaired a seat on there own or am I better off finding a upholstery shop
Re: Repairing Bench Seat [Re: weazel] #1349789
12/12/12 03:44 PM
12/12/12 03:44 PM
Utah
E
Eagleone1983 Offline
E
Utah
You can cut some foam rubber in the shape of a cone to tightly fit in the springs and that will stiffen the seat up a bit.
Re: Repairing Bench Seat [Re: Eagleone1983] #1349790
12/14/12 04:49 AM
12/14/12 04:49 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I've read you can weld the wires back together.
The success of which I'm sure depends on your skill level and the actual welder used.
A torch or stick probably won't get you there but a MIG or TIG might.
I can't afford this. mark
Re: Repairing Bench Seat [Re: weazel] #1349791
01/03/13 11:38 PM
01/03/13 11:38 PM
Top 'O' Texas
hotrod340 Offline
hotrod340  Offline
Top 'O' Texas
I took a piece clothesline wire and interweaved it over and under each spring in the middle and tied the ends on the springs on both ends. Then I hog ringed the wire to each spring. I think it worked pretty good and there's good support.
