restoration of AC Lines #1349490
12/11/12 12:48 PM
12/11/12 12:48 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Casn I get some advise on materials and technique for restoring these lines. TX
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: restoration of AC Lines [Re: 68 Sat] #1349491
12/12/12 12:53 AM
12/12/12 12:53 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If the rubber is not dry rotted and cracked glass bead the entire hose and have the ends plated, the plating wont stick to the rubber. Have them pressure tested also.
Re: restoration of AC Lines [Re: 71birdJ68] #1349492
12/15/12 12:44 PM
12/15/12 12:44 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I went the cheapie route over having them replated. I used a chrome galvanize spray paint from Eastwood. made by Aervoe.
Pretty close in appearance to the reflective clear zinc I think these were originally plated with. The paint takes forever to completely dry though and is not very durable (scratches easily)
1MYTGTX
Re: restoration of AC Lines [Re: 1MYTGTX] #1349493
12/15/12 12:48 PM
12/15/12 12:48 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
nudder...
1MYTGTX
Re: restoration of AC Lines [Re: 1MYTGTX] #1349494
12/15/12 02:01 PM
12/15/12 02:01 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
They look really good tx
Re: restoration of AC Lines [Re: 68 Sat] #1349495
12/16/12 10:04 PM
12/16/12 10:04 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Looks good in the pic, You will just have to touch up when needed.
MLR426
Re: restoration of AC Lines [Re: MLR426] #1349496
12/16/12 11:22 PM
12/16/12 11:22 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Respectfully let me say, they look much better in pics than in real life. When you personally visually look at this when spray bombed, they look spray bombed. Its just not the same.
Re: restoration of AC Lines [Re: 68 Sat] #1349497
12/17/12 12:33 AM
12/17/12 12:33 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's what I do and it will take a little time; first I cleaned then with some laquer thinner the taped and sealed every opening and then glass bead blasted the metal items. Then tool 000 steelwool and some good metal polish and made them as clean and smooth as possible. Then I took metal polish (Semichrome paste) and a buffing wheel and polished them to a chrome like finish. From here it's your choice, use RPM, a good parifin clear wax or clear engine (hi-temp) enamel and coated them to maintain the finish. Some of the parts that I wanted with a satin finish I of course didn't use the buffing wheel.
