Re: Roller Rockers VS Flat Tappet
[Re: Sb Valiant]
#1348361
12/09/12 02:03 PM
12/09/12 02:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
As a rule of thumb.. go with roller rockers when you exceed .550 lift... I'm sure if you measure the actual ratio of the stock VS the HS rockers you will see that the stock rockers dont even have a true 1.5 ratio so IF your engine wants more lift it will be a gain... the big factor also when running roller rockers is you have a easier sweep across the valve tip which will cause wear on both the tip and the rocker using the stock stuff
[Re: Sb Valiant]
#1348362
12/09/12 05:21 PM
12/09/12 05:21 PM
Posts: 4,209 New York
polyspheric
New York
because they were desinged in the 1970's
Rocker arm design pretty much stalled around WW2. Everything you see today was already known but not cost-effective as a marketable product.
The relationship that determines side thrust (excess wear and lost motion) isn't only lift, it's lift as a function of the long-side rocker length. The ratio doesn't matter. Percentages below 30% (rocker lever is 1.40", lift is .420") don't need any help, percentages above 40% (lever is 1.40", lift is .560") do. If the ratio were 200%, the rocker would point straight up and down. This is why for most engines big block rockers need roller tips at higher lifts than small blocks.
Boffin Emeritus
[Re: Sb Valiant]
#1348365
12/09/12 08:24 PM
12/09/12 08:24 PM
polyspheric
New York
When you say "finger type rocker" you lose your audience.
Since your rocker is about 1.515" long (according to Jesel), 60% means you have: 1. .909" lift 2. very, very bad geometry
Boffin Emeritus
[Re: Sb Valiant]
#1348367
12/10/12 03:16 PM
12/10/12 03:16 PM
polyspheric
New York
You can call them late for dinner if you want, but there's no such thing as "flat tappet rockers".
Boffin Emeritus
[Re: Sb Valiant]
#1348368
12/10/12 04:06 PM
12/10/12 04:06 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Are you referring to the adjustable stock type ductile iron rocker arms as the finger type?
[Re: Sb Valiant]
#1348373
12/10/12 08:15 PM
12/10/12 08:15 PM
Posts: 1,505 TN
SCATPACK 1
TN
Ductile Iron Adjustable Rockers. Typically they check out around 1.40 ratio (or less in some cases) instead of 1.50. I bet you would see a noticable performance inscrease with roller rockers.
Old Geezer Racing
[Re: SCATPACK 1]
#1348374
12/10/12 09:42 PM
12/10/12 09:42 PM
Posts: 3,395 Pa
Hot 340
Pa
Are you sure about that? Those arent 273 rockers on there..
[Re: Cab_Burge]
#1348376
12/10/12 11:29 PM
12/10/12 11:29 PM
Posts: 3,395 Pa
Hot 340
Pa
Buy some aftermarket Ductile Iron rockers from Crane, Isky, Erson and whoever else sells them and check them at the retainers and let us know what you find I have Why do you think RAS was so busy when they where doing business on a regular bases Not only are the Mopar ductile iron rockers bad the Ford FE and the early Oldsmobile 303 to 394 C.I. and the early hemi where all bad
Ill check these ones out as I get it all set up. Old bushed w2's. You might be right..
[Re: astjp2]
#1348379
12/11/12 01:54 PM
12/11/12 01:54 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
MP made two different w2 ductile rocker arms ...
a bushed and unbushed rocker...
sold off my unbushed rockers a couple years ago...still got a set or two of the bushed ones..
actually MP listed the unbush ones as econo and bushed one as rockers for the race w2
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
