Roller Rockers VS Flat Tappet #1348360
12/09/12 01:16 PM
12/09/12 01:16 PM
western PA
Sb Valiant Offline OP
western PA
Is going to roller rockers worth the money for w2 heads? I have a set of flat tappet rockers on the motor now with over a 600 lift flat tappet cam and was told that the finger style rockers aren't meant for that kind of lift, rpm, ect because they were desinged in the 1970's. I was wondering if those rockers are hurting performance by a good amount or don't waste the time and money for rollers? I am looking into a cheaper set for the w2 heads called crane gold roller rockers. I guess they need machined because they don't come right but are meant for the w2 heads. I guess it beats spending an extra over 600 dollars for the next cheapest set of harland sharps..
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348361
12/09/12 02:03 PM
12/09/12 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As a rule of thumb.. go with roller rockers when you
exceed .550 lift... I'm sure if you measure the actual
ratio of the stock VS the HS rockers you will see
that the stock rockers dont even have a true 1.5 ratio
so IF your engine wants more lift it will be a gain...
the big factor also when running roller rockers is
you have a easier sweep across the valve tip which
will cause wear on both the tip and the rocker using
the stock stuff
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348362
12/09/12 05:21 PM
12/09/12 05:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Rocker arm design pretty much stalled around WW2. Everything you see today was already known but not cost-effective as a marketable product.
The relationship that determines side thrust (excess wear and lost motion) isn't only lift, it's lift as a function of the long-side rocker length. The ratio doesn't matter.
Percentages below 30% (rocker lever is 1.40", lift is .420") don't need any help, percentages above 40% (lever is 1.40", lift is .560") do. If the ratio were 200%, the rocker would point straight up and down.
This is why for most engines big block rockers need roller tips at higher lifts than small blocks.
Boffin Emeritus
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348363
12/09/12 07:38 PM
12/09/12 07:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I don't know how good they are but Jack Moore has some MP rollers for W-2's for sale in the race section classifieds
Gus
64 Plymouth Savoy
Dana 60
Re: Roller Rockers VS Flat Tappet [Re: polyspheric] #1348364
12/09/12 07:46 PM
12/09/12 07:46 PM
western PA
western PA
They are deffiently more then 40 percent. Maybe if close to 60. We Were adjusting valves a while back and my buddy happen to mention that the rockers were sitting up on end pretty good and must be a pretty big cam if not to much for the finger type rockers.
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348365
12/09/12 08:24 PM
12/09/12 08:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
When you say "finger type rocker" you lose your audience.
Since your rocker is about 1.515" long (according to Jesel), 60% means you have:
1. .909" lift
2. very, very bad geometry
Boffin Emeritus
Re: Roller Rockers VS Flat Tappet [Re: polyspheric] #1348366
12/10/12 09:19 AM
12/10/12 09:19 AM
western PA
western PA
sorry that's just a nick name for them. They are just flat tappet rockers and cam is post to be around 606 lift but we are going to check it for true lift and see what it is. Also geometry still can't be to good regardless.
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348367
12/10/12 03:16 PM
12/10/12 03:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You can call them late for dinner if you want, but there's no such thing as "flat tappet rockers".
Boffin Emeritus
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348368
12/10/12 04:06 PM
12/10/12 04:06 PM
Are you referring to the adjustable stock type ductile iron rocker arms as the finger type?
Re: Roller Rockers VS Flat Tappet [Re: Cab_Burge] #1348369
12/10/12 06:07 PM
12/10/12 06:07 PM
western PA
western PA
Maybe that's what they are... I will try and get acouple pics up for you guys!
Re: Roller Rockers VS Flat Tappet [Re: polyspheric] #1348370
12/10/12 07:02 PM
12/10/12 07:02 PM
western PA
western PA
Here are some pictures!
Re: Roller Rockers VS Flat Tappet [Re: polyspheric] #1348371
12/10/12 07:04 PM
12/10/12 07:04 PM
western PA
western PA
Here is another shot of the w2 econo rockers we have. What ever they are called.
Re: Roller Rockers VS Flat Tappet [Re: Cab_Burge] #1348372
12/10/12 07:24 PM
12/10/12 07:24 PM
western PA
western PA
Does anyone know what these rockers specifically are???
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348373
12/10/12 08:15 PM
12/10/12 08:15 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Ductile Iron Adjustable Rockers. Typically they check out around 1.40 ratio (or less in some cases) instead of 1.50. I bet you would see a noticable performance inscrease with roller rockers.
Old Geezer Racing
Re: Roller Rockers VS Flat Tappet [Re: SCATPACK 1] #1348374
12/10/12 09:42 PM
12/10/12 09:42 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Are you sure about that? Those arent 273 rockers on there..
Re: Roller Rockers VS Flat Tappet [Re: Hot 340] #1348375
12/10/12 11:11 PM
12/10/12 11:11 PM
Buy some aftermarket Ductile Iron rockers from Crane, Isky, Erson and whoever else sells them and check them at the retainers and let us know what you find I have Why do you think RAS was so busy when they where doing business on a regular bases Not only are the Mopar ductile iron rockers bad the Ford FE and the early Oldsmobile 303 to 394 C.I. and the early hemi where all bad
Re: Roller Rockers VS Flat Tappet [Re: Cab_Burge] #1348376
12/10/12 11:29 PM
12/10/12 11:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ill check these ones out as I get it all set up. Old bushed w2's. You might be right..
Re: Roller Rockers VS Flat Tappet [Re: SCATPACK 1] #1348377
12/11/12 12:32 AM
12/11/12 12:32 AM
western PA
western PA
Thank u for the info ScatPack1 that really cleared things up for me!!!!
Re: Roller Rockers VS Flat Tappet [Re: Sb Valiant] #1348378
12/11/12 12:41 AM
12/11/12 12:41 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My factory 426 hemi rockers were in the range of 1.32-1.36, RAS did a geometery correction and got me to 1.42 average. Went with stage V, they were about 1.5-1.52
Re: Roller Rockers VS Flat Tappet [Re: astjp2] #1348379
12/11/12 01:54 PM
12/11/12 01:54 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
MP made two different w2 ductile rocker arms ...
a bushed and unbushed rocker...
sold off my unbushed rockers a couple years ago...still got a set or two of the bushed ones..
actually MP listed the unbush ones as econo and bushed one as rockers for the race w2
Tony
70 AARCuda Vitamin C
