Suspension, what's next? need help #1347685
12/08/12 01:44 AM
12/08/12 01:44 AM
Janesville, WI
SpareParts Offline OP
Janesville, WI
http://www.youtube.com/watch?v=SNR4ELAoM6o
So Based on the little bit you can see of the leave what do I need to focus on now?
basic rundown is, SS springs 2800lb solid eye bushings, /6 T bars,MP rear shocks, Calvert fronts, stock A arms and front susp. SS springs are clamped on every leaf (testing showed improvement) This car hooks but the 60' seems slow to me. You'll notice I gave up the win light (and a lil dough) but what's the first thing that comes to mind that you see needs a change?
Thanks guys
Re: Suspension, what's next? need help [Re: SpareParts] #1347686
12/08/12 02:07 AM
12/08/12 02:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The front lifts but the rear doesnt do anything...
first would be rear shocks... get some adjustable ones
and the rear tire pressure looks high
Re: Suspension, what's next? need help [Re: MR_P_BODY] #1347687
12/08/12 03:25 AM
12/08/12 03:25 AM
Janesville, WI
Janesville, WI
I would definitely agree on tire pressure, freezing cold night and I was worried about the car moving around up top so for stability I kept pressure in it to avoid pedaling. What's your take on the rancho/calvert adjustable rear shocks? Thanks much
Re: Suspension, what's next? need help [Re: SpareParts] #1347688
12/08/12 03:45 AM
12/08/12 03:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The Rancho 9 way would be the MINIMUM... alot of
guys use them with the Caltrac but they are IFFY
with SS springs... but from your vid I would say
to try them... you lacked any lift in the rear that
you should get from SS springs... what gear are you
running
Re: Suspension, what's next? need help [Re: MR_P_BODY] #1347689
12/08/12 03:57 AM
12/08/12 03:57 AM
Janesville, WI
Janesville, WI
4.30 gear, 28" tire. These shocks are probably two years old now going on three. Not sure how long they should last.
Re: Suspension, what's next? need help [Re: SpareParts] #1347690
12/08/12 09:29 AM
12/08/12 09:29 AM
ill
dennismopar73 Offline
ill
More info needed!! tq vert stall / flash, leave rpm tire pressure you are running now, and carb?
Re: Suspension, what's next? need help [Re: MR_P_BODY] #1347691
12/08/12 10:50 AM
12/08/12 10:50 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
keep saving your lunch money and buy some nice rear shocks (double adj if poss) suspension tuning is vital. i'm with ya on that mr. P
Re: Suspension, what's next? need help [Re: Deepockets] #1347692
12/08/12 11:48 AM
12/08/12 11:48 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Are the springs in the stock location?
Re: Suspension, what's next? need help [Re: Dartwizer] #1347693
12/08/12 12:26 PM
12/08/12 12:26 PM
Janesville, WI
Janesville, WI
Converter is a 4800 leave at 3k foot brake, had 18psi in tires, 750 proform DP, springs are moved inboard. I have a set of ranchos on the shelf, ran out of season to try them though
Re: Suspension, what's next? need help [Re: SpareParts] #1347694
12/08/12 12:32 PM
12/08/12 12:32 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
as mentioned you need to get body separation that's what slams the tires against the ground
Re: Suspension, what's next? need help [Re: SpareParts] #1347695
12/08/12 12:37 PM
12/08/12 12:37 PM
gregsdart Offline
gregsdart  Offline
If you go to the roundy round section of an AFCO catalog there is a lot of info on rear shackles and the effect of different setups. Well worth reading. If you have no rear lift, I suspect you have too stiff of a set of SS springs, poor shackle setup, bind, or some or all of the above. Too stiff on the shocks could be a culprit, although with SS springs that is very hard to achieve due to their very high leverage. The only other thing I could think of is spin at the hit(I didn't watch the vid, so,,,,)
I put a set of 002 and 003 springs on a 3300 lb Dart I am building and used stock shackles. It is stiff as all get out back there now. Not what I wanted. I should have bought the ones for a 2800 lb car instead. It is much better to have a low spring rate and control it with shocks and clamps than too stiff a spring, which can't be fixed without replacing them.
Re: Suspension, what's next? need help [Re: gregsdart] #1347696
12/08/12 12:51 PM
12/08/12 12:51 PM
Janesville, WI
Janesville, WI
I think in the spring I'll try and remove some of the clamps on the rear segment of the springs. I actually tried 002/003 springs this year but it would knock the tires right off on the prepped street. The 2800lb springs will pick the fronts on a decent concrete street after a proper burnout.
Re: Suspension, what's next? need help [Re: SpareParts] #1347697
12/08/12 01:21 PM
12/08/12 01:21 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I'd let you try my used rancho 9 way's if my car wasn't in storage right now. I agree with some of the others though, most SS spring cars I have seen have LOTS of separation. I've never ran the SS springs, but I can't see a good set of adjustables NOT being a good investment- sure they might cost ya, but they are soo worth it. A set of strange D/A's is $250 each for the rear, but well worth the money...especially if your trying to get it to hook hard on the streets The tuneability is worth it imo
Re: Suspension, what's next? need help [Re: SpareParts] #1347698
12/08/12 01:34 PM
12/08/12 01:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My ss springs were always best with rear segments unclamped. Long drag shocks and or shock extensions. just a clamp 6" behind axle let them fan out on launch.
with the cal tracs SS springs and 9 way adjustable was best with rear of springs unclamped and shocks at 7 for foot braking.
Re: Suspension, what's next? need help [Re: mshred] #1347699
12/08/12 01:34 PM
12/08/12 01:34 PM
Janesville, WI
Janesville, WI
Can't try much this year, tracks closed. There's always my other "track" but it's just plain old too cold here. I'm mainly looking for tips for next year so I have all winter to read up and hide money lol
Re: Suspension, what's next? need help [Re: SpareParts] #1347700
12/08/12 02:38 PM
12/08/12 02:38 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Rear segments should not be clamped and I agree with the earlier comment too be wary of too stiff a spring. That car needs body separation to plant the tires. Also, to get the suspension working you may try leaving at a lower RPM so the converter "flashes" off the line. You need that action of the rear axle housing trying to rotate which makes the front segment push the body up and as Newton said, every action has an equal and opposite reaction. I believe that will drop your sixty as long as you are hooking.
Re: Suspension, what's next? need help [Re: SpareParts] #1347701
12/08/12 03:19 PM
12/08/12 03:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Look real closely at the rear shackle angles as already suggested. If yours are in the stock location you need to move the upper pivot point forwars to the front of the car so you have a 30 degree or more angle on the rar shackles when sitting still with the weight on the rear tires The rear shackles need to be able to move forward under acceleration to help lift the back of the car up so it pushes the rear tires into the ground If there almost straight up and own when sitting still they will swing forward past the staright up and down and start pulling the rear spring eye down
Re: Suspension, what's next? need help [Re: SpareParts] #1347702
12/08/12 03:54 PM
12/08/12 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
TIP; I`d seriously consider getting out of the ice ages and throw some c-tracs and rancho 9-ways on that thing then start posting about new best`s instead of HELP. Been there...........no fun chasing your tail............ peace!
Re: Suspension, what's next? need help [Re: Thumperdart] #1347703
12/08/12 05:00 PM
12/08/12 05:00 PM
Janesville, WI
Janesville, WI
Shackle angle is fine, made sure I paid attention to that. Cal tracs will not be seen on this car for as long as I can avoid it. They make things easier but I'd rather do the homework and keep it spring only. Less is more approach is kinda what the car goes by.
Re: Suspension, what's next? need help [Re: SpareParts] #1347704
12/08/12 05:03 PM
12/08/12 05:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If that`s your thing, have at it...........
