Re: went edel victor aluminum head finaly!Flow tested.
[Re: Clanton]
#1347091
12/13/12 12:32 AM
12/13/12 12:32 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I would like a picture of a cnc exh port if anyone has 1 PLEASE! Thank you! I have a cutaway pic in stock form.
[Re: Clanton]
#1347092
12/13/12 12:44 AM
12/13/12 12:44 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure if this we help you but this guy does some beautiful work. http://www.speierracingheads.com/BBMv3.3.htm
[Re: Jeremiah]
#1347094
12/13/12 01:34 PM
12/13/12 01:34 PM
Clanton
northern,Ohio,USA
Let me know if you want more pics.
Thank you!Do you have a pic from chamber side without the valve? What is the opening size on the exh exit? Thanks for the great pics,help!
[Re: Clanton]
#1347096
12/15/12 02:40 AM
12/15/12 02:40 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I had a chance to work on my engines today but forgot my camera. I'll get back to it Monday after work and get some pics for you.
[Re: hemi-itis]
#1347099
12/16/12 01:12 PM
12/16/12 01:12 PM
Clanton
northern,Ohio,USA
Your gunna need your COMP licence too
at least I dont need a dr note with the IHRAuntel 150mph I think.
[Re: hemi-itis]
#1347101
12/16/12 05:15 PM
12/16/12 05:15 PM
Clanton
northern,Ohio,USA
I guess I have been bored so I have been using the wallace calcs.Port speed will be 256 FPS[corrected] and the max velocity for that port csa/3.14 is 542fps at 6800 rpm.The gained cfm over my as working engine will be 70cfm with a hp rating anywhere from 1.4/2.0 hp per cfm N/A.The tune may change as far as fuel,timing but we will see.
[Re: Clanton]
#1347107
01/12/13 07:48 PM
01/12/13 07:48 PM
Clanton
northern,Ohio,USA
the final results are in. 1)77.76 2)149.49 3)209. 4)266.11 5)321.75 6)351.00 7)357.75 8)362.25
exh 1)63.50 2)108.50 3)153.45 4)194.06 5)219.10 6)225.36 7)228.49 8)225.36
all with factory size int,exh opening. Thank you Scott Koffel for the great work!
