King Street BIR? #1346708
12/06/12 02:34 AM
12/06/12 02:34 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
I'm just starting the rebuild of my 70 GTX and was thinking of running King Street at Brainerd International Raceway in Minnesota. My question is how fast are the guys running in KS at BIR I've looked on there web site and haven't found anything on there about it. I'm just curious on what it would take to be competitive in KS.One more question is are there two seperate classes like NA, PA or is it run what you brung?
Thanks for any and all info
Kevin
Re: King Street BIR? [Re: 604 Hemi GTX] #1346709
12/06/12 10:56 AM
12/06/12 10:56 AM
Coon Rapids, Minn.
MW Racecraft Offline
Coon Rapids, Minn.
You will have to run low 9's.
Re: King Street BIR? [Re: MW Racecraft] #1346710
12/06/12 01:44 PM
12/06/12 01:44 PM
ONTARIO,CANADA
ONTARIO,CANADA
So I was pretty close thinking mid to high 8's then. One more question how much HP is needed in a 3600lb car to run mid to high 8"s?
Kevin
Re: King Street BIR? [Re: 604 Hemi GTX] #1346711
12/06/12 02:10 PM
12/06/12 02:10 PM
Hibbing Mn
tazmaniac Offline
tazmaniac  Offline
Hibbing Mn
900hp? for high 8's
Re: King Street BIR? [Re: tazmaniac] #1346712
12/06/12 02:20 PM
12/06/12 02:20 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You would need 1060 to go a 8.75 at that weight.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: King Street BIR? [Re: 1967dartgt] #1346713
12/06/12 02:38 PM
12/06/12 02:38 PM
ONTARIO,CANADA
ONTARIO,CANADA
So now I know that I'll need 1100HP to be competitive.
Thanks for the info
Kevin
Re: King Street BIR? [Re: MW Racecraft] #1346714
12/06/12 04:05 PM
12/06/12 04:05 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
King Street cars are running in the high 7s this year.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: King Street BIR? [Re: lowflyingdart] #1346715
12/06/12 05:55 PM
12/06/12 05:55 PM
ONTARIO,CANADA
ONTARIO,CANADA
I see....Well that's alot faster than i was hoping, I guess i may have to look into a procharger and efi then.
Thanks for the info
Kevin
Re: King Street BIR? [Re: 604 Hemi GTX] #1346716
12/06/12 06:09 PM
12/06/12 06:09 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Thanks for the info
Kevin
You might want to look into a lot lighter car, and a Procharger
Yes I live in Michigan, so there is still 1 light on
Re: King Street BIR? [Re: 440dart] #1346717
12/06/12 07:48 PM
12/06/12 07:48 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
I run a procharged dart in real street unlimited, needs mufflers, ins, dot tires, and working lights. I ran a 9.30 and was one of the slower cars. mid eights are common and I thought one guy qualified with a 7.95 in that class. I could be wrong, but I know mid to low eights are common in that class.
Re: King Street BIR? [Re: 80arrow] #1346718
12/06/12 08:18 PM
12/06/12 08:18 PM
ONTARIO,CANADA
ONTARIO,CANADA
So I guess if I want to run King Street then I'll have to step up the program just a wee bit.Plus I can't see me buying another car so I'll have to work with what I have and build more power.
Kevin
Re: King Street BIR? [Re: 604 Hemi GTX] #1346719
12/06/12 09:26 PM
12/06/12 09:26 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Just buy my small tire car, instant contender with spares
Re: King Street BIR? [Re: Al_Alguire] #1346720
12/07/12 01:39 AM
12/07/12 01:39 AM
ONTARIO,CANADA
ONTARIO,CANADA
Believe me Al I've looked at it and drooled all over my computer. But I made the decision to work with what I have already and it's in the works as we speak. But if I didn't have a car I'd be all over it.
Kevin
Re: King Street BIR? [Re: 604 Hemi GTX] #1346721
12/07/12 02:45 AM
12/07/12 02:45 AM
Las Vegas
Las Vegas
Foiled again
Seriously best of luck with the new bullet. I am sure it will be where you want it to be.
Re: King Street BIR? [Re: Al_Alguire] #1346722
12/07/12 05:53 PM
12/07/12 05:53 PM
ONTARIO,CANADA
ONTARIO,CANADA
Foiled again
Thanks Al,
I'm kind of at a crossroads with the engine build, not sure if I should do the power adder or NA. But with the car I know how it's going to be done.
Kevin
