Triangulated four link question #1345801
12/04/12 11:53 AM
12/04/12 11:53 AM
Dandridge TN
Dabee Online content OP
Dabee  Online Content OP
Dandridge TN
I have a triangulated four link question for you guys. I’m installing a triangulated four link on a 55 Dodge PU street rod. I know on a parallel drag race style four link the bottom bar needs to be parallel with the ground and the top bar is angled down to set the instant center. This is done to get the car to hook. On a triangulated setup for the street can the bottom bar be installed angled up and the top bar parallel to the bottom bar and will this negatively affect the handling?
Re: Triangulated four link question [Re: Dabee] #1345802
12/04/12 01:52 PM
12/04/12 01:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
handling and triangulated four link.
Interesting juxtaposition.
Don't be the exception.
Re: Triangulated four link question [Re: Supercuda] #1345803
12/04/12 02:00 PM
12/04/12 02:00 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sure works well for cars like mine.
Holden Torana's dominated racing in Australia, and uses a triangulated 4 link factory...
Re: Triangulated four link question [Re: OzHemi] #1345804
12/04/12 03:49 PM
12/04/12 03:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Millions of GM cars were built with a triangulated four link suspension.
- Stu Harmon
Re: Triangulated four link question [Re: feets] #1345805
12/04/12 07:34 PM
12/04/12 07:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The go buy one. Just cause millions of wiggly butt GM's have it doesn't mean it's a good thing.
In order to get a triangulated fourlink to handle you have to use a lateral locating device, making in somerthing other than a four link.
So OZ, your Torana running a panhard or watts? Bet it is.
Re: Triangulated four link question [Re: Supercuda] #1345806
12/04/12 07:48 PM
12/04/12 07:48 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
That is a bet you would not win then...
And plenty of them being raced without them too.
Re: Triangulated four link question [Re: Supercuda] #1345807
12/04/12 07:55 PM
12/04/12 07:55 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And...running a panhard with a triangulated 4 link induces binding anyways from what I believe. Since the panhard moves in an arc differently from the one moving by the differential itself.
A 3 link with watts link would probably be a better way to go from what I have read now and then..
Re: Triangulated four link question [Re: OzHemi] #1345808
12/04/12 08:05 PM
12/04/12 08:05 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Trianglated means the uppers, or maybe lowers if those are the ones that are at an angle, keep the rearend centered, no need for a panhard bar or Watts linkage.
Straight bars would probably need a panhard bar or Watts link, depends on how good the installation is, and how hard/soft rubber/metal the bushings are.
Along with the shock mount and spring mount, etc.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Triangulated four link question [Re: amxautox] #1345809
12/04/12 08:14 PM
12/04/12 08:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's the theory, in reality I have yet to drive a production triangulated four link that wasn't wiggly in the rear.
The only reason the triangulated four link was developed was to provide a cheap, soft ride. Adapting it to any performance aspect requires a lot of stock parts replacements and redesign. Something not necessarily needed with the Chrysler based leaf setup.
Re: Triangulated four link question [Re: Supercuda] #1345810
12/04/12 08:29 PM
12/04/12 08:29 PM
amxautox Offline
amxautox  Offline
They wiggle because they have soft rubber bushings for comfort off the showroom floor/dealer lot. Not to mention the weak U shaped bars that really can't support much side load. THATS why the bars need to be replaced with solid/hollow bars, and use heim/saphirical ends for the best results/adjustability/handling.
Tom
author unknown
Re: Triangulated four link question [Re: amxautox] #1345811
12/04/12 10:08 PM
12/04/12 10:08 PM
Ohio
blown71duster Offline
Ohio
Art morrison recommends the lower bar level or slightly down.
http://www.artmorrison.com/instructions/tri4-bar1-Model.pdf
They use this setup in their max-g chassis. I also heard good feedback on the RMS and its a triangulated 4 bar.
http://www.artmorrison.com/2006cat/31.pdf
Re: Triangulated four link question [Re: blown71duster] #1345812
12/04/12 11:15 PM
12/04/12 11:15 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
RMS Street Linx here.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Triangulated four link question [Re: blown71duster] #1345813
12/05/12 02:10 AM
12/05/12 02:10 AM
Dandridge TN
Dandridge TN
Blowen 71 duster, Thanks for the links. They answered my question. I currently have the top bars tacked in about 2 degrees up. I’ll move the brackets down to get 1 degree down before I weld them in place. I was thinking they should be parallel. The bottom bars are level.
For supercuda, lots of street rods use triangulated four links with great success. This is not a production GM set up so you are comparing apples to oranges here. The aftermarket set ups have stiff bushings in the links. Ozhemi is correct a triangulated four link doesn’t use a pan hard bar or diagonal link to keep the axle centered like on a parallel four link. This is a street cruiser not a drag set up.
Re: Triangulated four link question [Re: Dabee] #1345814
12/05/12 05:15 AM
12/05/12 05:15 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Here is a good read on the fabrication/installation of a triangulated 4 link setup on a 67 Dart. Same basic design as the Reilly Street-Lynx setup, just beefier DIY.
http://www.forabodiesonly.com/mopar/showthread.php?t=101437&highlight=triangulated
Re: Triangulated four link question [Re: amxautox] #1345815
12/05/12 08:30 PM
12/05/12 08:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I know all that and have gone through most of it with the 96 Stang I had. Still had a wiggly butt compared to my Cuda or Dart. I have yet to be impressed with any production triangulated 4 link, an Oz that Torana of yours looks to be a corporate GM setup so I imagine I wouldn't be impressed there either.
Once you get into heim joints and spherical bearings to make it work you have less a street car but more of a race car. If that's what you want fine, but it's not my bag of goodies.
If I were going to put all this effort into a rear suspension I would skip over any four link and go independent
I do not think the "benefits' of a triangulated four link even match the costs involved, let alone exceed them.
