Page 1 of 3 1 2 3
New Hemi blocks #1345389
12/03/12 12:36 PM
12/03/12 12:36 PM
A Banana Republic near you.
JohnRR Online rolleyes OP
JohnRR  Online Rolleyes OP
HP Performance had NEW hemi and wedge blocks at PRI , says they are finally in production ...
http://www.hpperformancellc.com/store#!/~/category/id=2880288&offset=0&sort=normal
Re: New Hemi blocks [Re: JohnRR] #1345390
12/03/12 02:10 PM
12/03/12 02:10 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
They have been working on having them done forever....I wonder if now they REALLY have em.
Re: New Hemi blocks [Re: domingo] #1345391
12/03/12 02:21 PM
12/03/12 02:21 PM
dogdays Offline
dogdays  Offline
3 cast iron
2 aluminum
4 aluminum big bore
That's what their online catalog says they have in stock.
R.
Re: New Hemi blocks [Re: JohnRR] #1345392
12/03/12 03:19 PM
12/03/12 03:19 PM
Delray beach, Florida
P
Performance Only Offline
P
My understanding was that it takes 6 weeks from the time you place the order until the time it ships. Each block is finished per order.
machine shop owner and engine builder
Re: New Hemi blocks [Re: Performance Only] #1345393
12/03/12 04:34 PM
12/03/12 04:34 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I've been holding off on a block purchase for almost 2 years as I am not a fan of the world block.
I've been waiting for this block to come out - tempting but I get nervous being one of the first.
Not to say it's a bad product - my uncle worked in a foundry and he shares his horror stories on how difficult it is to get everything right.
Re: New Hemi blocks [Re: SSAAHemiFan] #1345394
12/03/12 04:40 PM
12/03/12 04:40 PM
The block looks good , the company had a vendor problem that took time to settle which is why they have been silent for a couple years.
I heard that World is not going to be making them much longer, if they are even still ...
The HP block I saw looked like the later MP block that wasn't quite like the original blocks , it had the big round flat in front of the oil pump boss .
Re: New Hemi blocks [Re: JohnRR] #1345395
12/03/12 05:32 PM
12/03/12 05:32 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Thanks for the info John... Man I am tempted to pull the trigger
Re: New Hemi blocks [Re: SSAAHemiFan] #1345396
12/03/12 06:44 PM
12/03/12 06:44 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I live just up the road from David's shop. I stop by there when I can and that block they have, has the best of everything for a lower price than any of the others I have seen. Extra thick main webs, really thick deck area. Some extra oiling mods to get the oil out of the heads and back into the pan quicker than other blocks. Main caps have 6 bolts in them. When I do get my Hemi block, it will be one of his blocks. The foundary is in CA, but the machine work is all done in east TN at Milan Keasler's shop. Milan does a lot of testing, engineering and design work for Ford.
Forgot to add, they are a dry sleeve block and they even diamond hone/machine the aluminum cylinders before they install the steel sleeves. So, no o-rings to leak water into the oil.
Old Geezer Racing
Re: New Hemi blocks [Re: SSAAHemiFan] #1345397
12/03/12 06:46 PM
12/03/12 06:46 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
What is the weight? Anybody know?
Re: New Hemi blocks [Re: scatpacktom] #1345398
12/03/12 06:55 PM
12/03/12 06:55 PM
weight was talked about but I don't remember the NUMBER , pretty sure it was a water block , but has thick cylinder walls so it won't be as light as an original ...
Re: New Hemi blocks [Re: JohnRR] #1345399
12/03/12 09:06 PM
12/03/12 09:06 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
John, the solid block without sleeves in it was mine
Re: New Hemi blocks [Re: scatpacktom] #1345400
12/03/12 09:32 PM
12/03/12 09:32 PM
P
P
the water blocks are 137 lbs.
Re: New Hemi blocks [Re: Performance Only] #1345401
12/03/12 10:53 PM
12/03/12 10:53 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Is that Aluminum? My world cast block is almost 250....
Re: New Hemi blocks [Re: astjp2] #1345402
12/04/12 12:37 AM
12/04/12 12:37 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Is this the father and son company that was in Dickson, TN 10-12 years ago, think their company was "Rod and Custom" or something like that. They had a couple of CnC workstations and waiting on a couple more when I went to their shop, had maybe 6 block castings in various states of completion. Last I heard they were building new shop and neighbors raised cain about not being zoned commercial, lost touch after that but thought they were using Hensley to market them at one time.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: New Hemi blocks [Re: 23T Hemmee] #1345403
12/04/12 12:40 PM
12/04/12 12:40 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This company you are talking about I have called everyday for the last 4 months to get a timing cover I ordered and paid for. Nobody answers the phone and the voice mail is full.
2011 Drag Pak Challenger
Re: New Hemi blocks [Re: rickseeman] #1345404
12/04/12 01:15 PM
12/04/12 01:15 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Just found their old business card, it was "Rod & Custom Machine & Fabrication". They were originally doing the A' motor hemi-head conversion for street rodders, which if I remember was a pretty slick deal, not necessarily a race package but was pretty complete from head gaskets up. The son's name on the card was Jeremy, no last name, their number was 615-441-3903.
Ronny
John 14:6
Re: New Hemi blocks [Re: JohnRR] #1345405
12/04/12 01:29 PM
12/04/12 01:29 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
. Their website leaves a lot to be desired. Unless I'm missing something?
Chris from New Jersey
Re: New Hemi blocks [Re: fig426] #1345406
12/04/12 08:34 PM
12/04/12 08:34 PM
dogdays Offline
dogdays  Offline
Re: New Hemi blocks [Re: 23T Hemmee] #1345407
12/04/12 10:43 PM
12/04/12 10:43 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
No different business
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: New Hemi blocks [Re: moparts] #1345408
12/05/12 10:10 PM
12/05/12 10:10 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
My block is the back one standing up.
Page 1 of 3 1 2 3
