Do we have clearance, Clarence? #1345295
12/03/12 04:48 AM
12/03/12 04:48 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I'm putting a 440 in my 1970 coronet. I'm using the Edelbrock Performer RPM intake and a Thermoquad with a spacer to go from spread bore to square bore. Does anyone out there run this combo and is there clearance under the stock flat hood with a low profile air cleaner or air box (not ramcharger)?
Thanks,
Lindy
I’m listening.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345296
12/03/12 04:54 AM
12/03/12 04:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think that is fitting under a flat hood .
Re: Do we have clearance, Clarence? [Re: JohnRR] #1345297
12/03/12 04:43 PM
12/03/12 04:43 PM
Spokane Valley, WA
Spokane Valley, WA
That is my concern. Anyone out there have first hand experience with this combo or with running a Holley on this intake without the spacer?
I’m listening.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345298
12/03/12 05:07 PM
12/03/12 05:07 PM
scratchnfotraction Offline
I just put a performer rpm on my 440 in the 88 truck.
the base gasket of the carb sits a tad taller than the stock VCs or the M/T valve covers.
I would wager it does not fit.
Re: Do we have clearance, Clarence? [Re: scratchnfotraction] #1345299
12/03/12 05:19 PM
12/03/12 05:19 PM
I was able to use the stock throttle bracket with the 3 piece TP linkage. which I have read did not fit.
I do need to raise the throttle cable mount to level it but it is working at this angle with no binding or sticking. I am just going to weld a couple throttle clamp piece to some flat stock so it bolts to the stock bracket.
Re: Do we have clearance, Clarence? [Re: scratchnfotraction] #1345300
12/03/12 05:25 PM
12/03/12 05:25 PM
here is my drop base aircleaner to replace the v-stack.
I have lots of room in a truck along with a hemi scoop. it pushed the V-stack right to the touching point.
this is carb bolted to intake with just a paper gasket.
Re: Do we have clearance, Clarence? [Re: scratchnfotraction] #1345301
12/03/12 05:33 PM
12/03/12 05:33 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
This probably doesn't help because it a 73 b-body. But here is the clearance of my 440 with a performer rpm and holley. I bet with a drop base I could just get it to fit, maybe.
Re: Do we have clearance, Clarence? [Re: scratchnfotraction] #1345302
12/03/12 05:38 PM
12/03/12 05:38 PM
Spokane Valley, WA
Spokane Valley, WA
Youch! I didn't realize how arched the runners are compared to stock. Now what?? I guess I could put a Chevy cowl induction scoop between the N96 scoops... I may have to go with the Holley.
Grrrrr. I really love the look of the dual scoops. I might have to go with the A12 style six pack fiberglass hood. I'd hate that. I've got a lot of time and $$$ into that hood.
I’m listening.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345303
12/03/12 06:06 PM
12/03/12 06:06 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
My air cleaner in the picture is not a drop base.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345304
12/03/12 06:22 PM
12/03/12 06:22 PM
Spokane Valley, WA
Spokane Valley, WA
Really good pictures, guys. If anyone has a picture of their 70 b body...
The carb plenum I was going to use is this one.
I've seen that intake under a number of muscle car hoods at car shows. Just never paid attention to spacers, air cleaners, hoods and clearance.
I’m listening.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345305
12/03/12 08:45 PM
12/03/12 08:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A friend had a street dominator on a 440 in a 70 charger , the street dominator in not as tall as the RPM , had a holley , no spacer and a flat base air cleaner it had to run a 2" tall filter to allow the hood to close.
The RPM with the adapter might clear the hood without an air cleaner assembly.
Scratchy , you need to raise that throttle cable bracket and get that 90* turn out of the throttle cable
Re: Do we have clearance, Clarence? [Re: JohnRR] #1345306
12/03/12 10:06 PM
12/03/12 10:06 PM
I have always had to scratch up a longer cable from a /6 for SB,but this stock truck SB cable seems to be a little long on the BB.
I may try to find a short cable and raise the throttle clamp.
Re: Do we have clearance, Clarence? [Re: scratchnfotraction] #1345307
12/04/12 02:50 PM
12/04/12 02:50 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
Roger, over.
(Only 2 Airplane fans on Moparts ??????????)
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345308
12/04/12 03:27 PM
12/04/12 03:27 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
If it helps, on my 69 RR, I tried a performer RPM intake on an RB with an Edelbrock/AVS carb. It was not close to fitting under the stock hood. I also have a 1/3 inch heat insulator, but even without the gasket that combo was not going to fit. I eventually had to go with a performer (non-RPM) intake and a drop base air cleaner.
Re: Do we have clearance, Clarence? [Re: GreenBird] #1345309
12/04/12 06:26 PM
12/04/12 06:26 PM
Spokane Valley, WA
Spokane Valley, WA
Greenbrd,
That's probably the most accurate to my situation. I am sure there are differences between the 70 coronet and the 69 RR but it's gotta be close. I guess I will play wait and see. I will have enough umph in this engine that I don't want to go with the Performer. In fact I just sold one for under $100... And I have a lot of time into this RPM and the hood too. I'll either spend $1500 on a 6pack or $600 on as fiberglass hood I guess. Or maybe go to my body guy and see if he has any ideas. It's too bad that the hood doesn't have a power bulge like the 70 RR. hmmmmmmmm.
I’m listening.
Re: Do we have clearance, Clarence? [Re: ekim] #1345310
12/04/12 06:27 PM
12/04/12 06:27 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Roger, over.
And don't call me Shirley!
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345311
12/04/12 07:33 PM
12/04/12 07:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Greenbrd,
closer than you think , the flat hood between the 2 is pretty much identical, but the 69 RR may have slightly more clearance with the slight bulge in the center of the hood.
Also on the how close it is front , dodge and plymouth used the same air cleaner for both makes and the center section that holds the seal is also the same between the 2.
If you had a low deck there was potential for it to fit, sans spacer/adaptor, 440 no way .
Re: Do we have clearance, Clarence? [Re: JohnRR] #1345312
12/04/12 08:15 PM
12/04/12 08:15 PM
dogdays Offline
dogdays  Offline
That cast aluminum two-filter contraption may look decent but it's going to cost horsepower. There's not enough cross-sectional area and the air is coming in sideways, it'll mess up the carb's metering bad.
R.
Re: Do we have clearance, Clarence? [Re: JohnRR] #1345313
12/05/12 02:42 AM
12/05/12 02:42 AM
Spokane Valley, WA
Spokane Valley, WA
Greenbrd,
Oh joy... I guess I should have looked at the spec's before buying the darn thing. I couldn't have imagined that it's taller than say a Torker II. Frustration. Thanks for the posts John.
I’m listening.
Re: Do we have clearance, Clarence? [Re: Big Bad Bee] #1345314
12/05/12 02:49 AM
12/05/12 02:49 AM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
I had an M1 intake with a Dominator and it cleared with a drop base air cleaner, wouldn't fit in my Cuda until I modified the hood. I just put the RPM intake on and it is almost the same height. No way it fits with a spacer. ( opinion ) I think you'll be ok without a spacer and a drop base air cleaner.
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
